» Just found thisby batjac Today at 10:39 pm
» I Got Cheated!
by batjac Today at 10:35 pm
» WEN-MAC STORY
by GallopingGhostler Today at 10:09 pm
by Admin Today at 8:41 pm
by rsv1cox Today at 6:21 pm
» PSA propellors!!!
by roddie Today at 5:49 pm
» Wen Mac Aeromite/Challenger
by getback Today at 5:39 pm
by rdw777 Today at 12:05 pm
» COX FUEL ?????
stuck throttle ring on cox .049 car engine
can anyone help? the throttle ring on my cox car engine cylinder is frozen to the cylinder, the rest of the engine turns over like new
mitchg95- Diamond Member
Re: stuck throttle ring on cox .049 car engine
mitchg95 wrote:can anyone help? the throttle ring on my cox car engine cylinder is frozen to the cylinder, the rest of the engine turns over like new
1. Soak it in fuel for a few days.
2. Do the same with laquer thinner
3. Soak it in penetrating oil (liquid wrench)
4. Soak it in denatured alcohol.
There are many other ways, but these are the easiest. Heat it up before you attempt to turn it.
cool ill try soaking it in fuel for a few days, thanks for the tip
Take a hair dryer and warm it up on the high setting. Best is to use gloves as it can get hot. Once the engine is warm then it should start to turn.
Jason
Jason
Jason_WI- Top Poster
Blow dryer or boil it in water for 20 mins with 4 or 5 drops of automatic dishwasher detergent.
jsesere- Rest In Peace
PB Blaster works for me
http://www.blastercorporation.com/PB_Blaster.html
microflitedude wrote:mitchg95 wrote:can anyone help? the throttle ring on my cox car engine cylinder is frozen to the cylinder, the rest of the engine turns over like new
After seeing what months in Meths (denatured) does to glow heads I'd advise not leaving engines in it for more than
a day or two.
John Goddard- Diamond Member
ok, ill soak it in fuel for a couple of days then use a hair dryer to warm up the cylinder, thank you for all the suggestions guys
engine
Model covering heat gun works very well to free up froze up parts. Hair dyrer is used to dry hair not generate ample heat. Soaking in fuel is ok but really tight parts will stay tight. Just be careful with gun on plastic parts.
Dan
Dan
Last edited by dankar04 on Tue Feb 14, 2012 10:02 am; edited 1 time in total (Reason for editing : updated)
dankar04- Platinum Member
cool thank you dan
» 09 throttle ring
» cox 049 throttle ring
» Cox .049 Throttle Ring
» Cox Pee Wee .020 & throttle ring (homemade) and something else...
» 09 throttle ring
