by getback Today at 5:25 pm
» Ode to a dead cat
by rdw777 Today at 3:28 pm
» COX .020 RC PROJECT
by rdw777 Today at 3:21 pm
» Peewee power
by rdw777 Today at 3:04 pm
by rsv1cox Today at 8:53 am
» some pics....
» Thrust Washer
Driveplate Assembly Bracket
I found that driveplate can wobble if I use a propeller to assemble it, because the front and back hub surfaces of some propellers are not parallel with each other.
I use a metal flat corner brace for this purpose. Both surfaces of these corner braces are parallel. I cut a washer from thin plastic sheet and sanded both sides, then open a hole with a paper punch. I place this thin plastic washer in front of driveplate to avoid flattening knurled surface. Two pieces of electrical tape can also be used for this purpose. Then I place corner brace and two washers. Flat corner brace can also be attached in a vise.
Levent Suberk- Diamond Member
Re: Driveplate Assembly Bracket
I always thought there must be a better way, than using a prop.
Thanks Levent!
Thanks Levent!
dckrsn- Diamond Member
That is a great idea, as I too have had that problem when using a propeller to install the driveplate.
» Mounting bracket for cars
» Crankcase dis-assembly and assembly
» WTB: Medallion .049 Driveplate
» Modeling COX engines with 3D Printer
» Killer bee driveplate.
