» Jim Walker Bonanza etc.by roddie Today at 5:01 pm
» *Cox Engine of The Month* Submit your pictures! -August 2024-
by Kim Today at 3:13 pm
» “Aero Car” 3d printed, peewee powered plane build
by rdw777 Today at 11:48 am
by davidll1984 Today at 11:19 am
» Cox pt-19 pilot
by carolinaguy Today at 10:05 am
» Cox P-40 Warhawk - Tomahawk, Kittyhawk, Thimble drome etc. etc.
by rsv1cox Today at 9:32 am
» Sky Tiger Fun-Fly August 31st
by Kim Today at 2:07 am
» Size of cox pt-19 pilot
by carolinaguy Yesterday at 8:20 pm
by rsv1cox Yesterday at 7:23 pm
» Simple Gliders
by rdw777 Yesterday at 5:01 pm
by akjgardner Yesterday at 8:42 am
by roddie Yesterday at 8:26 am
July-2024
robot797's
robot797's
Airbrush setup
Airbrush setup
I decided to try some airbrushing using my shop compressor and run hose from compressor to filter and pressure regulator then on to airbrush.
Gathered some parts and just realized my fittings are all NPT and the airbrush and hose is BSP! OOooo balls!! Now I need a NPT to BSP fitting.
I doubt I will find that local, anyone else run into this?
crankbndr- Top Poster
Re: Airbrush setup
Unfortunately yes. I believe thats why I rolled the hose up and repacked the el cheepo air brush I inherited from my Step dad. There is a short 30” or so cloth covered hose that connects to the air source, but doesn’t fit anything I had available. I assumed it had to connect to a Freon can or something “not normal”. I figured if and when I find something I need to airbrush I’d just chop off the Odd fitting and clamp it on a barbed fitting. Did a quick google and found lots of BSP to BSP fittings but no NPT to BSP.
https://tcpglobal.com/collections/airbrush-fittings
E bay does have some:![Airbrush setup 108ccb10](https://i.servimg.com/u/f89/19/10/39/29/108ccb10.png)
Re: Airbrush setup
Thanks for your work on this, I think BSPT is different than BSP. The T means tapered and BSP is straight. AAAarrrrrggggggg
Re: Airbrush setup
At these low pressures the barbed fittings would probably work
Re: Airbrush setup
I have a cheepie Harbor Freight airbrush. Never went over 32 psi to spray dope. If it comes down to it, use the tapered thread BSPT and epoxy the thing into an adapter.
My motorcycle's case studs are held in with JB Weld. I doubt air at 32 psi is any harder to keep up with than those studs!
Oh, and the Harbor Freight air brush had all I needed to connect it to my Craftsman compressor.
Re: Airbrush setup
Probably some local craft store would have something. Here is just a random search that might have something? https://www.paascheairbrush.com/product-category/airbrush/airbrush-airbrush-and-sprayer-accessories/airbrush-airbrush-and-sprayer-accessories-adapters/ You would not get it by tomorrow though.
aspeed- Platinum Member
Re: Airbrush setup
There are adapters available that the air gun hose screws into one end and the other end is the male quick connect compressor fitting. When I get home tonight I will see if I still have one I can send you.
fit90- Diamond Member
Re: Airbrush setup
aspeed wrote:Probably some local craft store would have something. Here is just a random search that might have something? https://www.paascheairbrush.com/product-category/airbrush/airbrush-airbrush-and-sprayer-accessories/airbrush-airbrush-and-sprayer-accessories-adapters/ You would not get it by tomorrow though.
They do have the fitting,
https://www.paascheairbrush.com/product/hf-116/
![Airbrush setup Fittin10](https://i.servimg.com/u/f45/17/78/70/41/fittin10.jpg)
Re: Airbrush setup
fit90 wrote:There are adapters available that the air gun hose screws into one end and the other end is the male quick connect compressor fitting. When I get home tonight I will see if I still have one I can send you.
Thanks fit90, I found the part I need.
Re: Airbrush setup
Pipe thread info, confusing enough? Yes
https://www.cpcworldwide.com/Downloads/NPT.pdf
Re: Airbrush setup
It's good that this thread came up now, because last Thursday I went to Harbor freight and bought all the pieces to set up an airbrush so I can graduate from rattle cans. My new brush is a siphon style. I was disappointed they didn't have a gravity feed. I may have questions when I get around to putting some dope in it to test spray and get my pressure settings figured out. I'm using a 4 gallon Coleman compressor. I bought an additional inline filter and regulator.
Re: Airbrush setup
Rusty, Harbor Freight has a gravity feed gun that is ok if your compressor can put out the 3 CFM. https://www.harborfreight.com/adjustable-detail-spray-gun-92126.html I have a couple similar ones. One sprays air all the time and the trigger lets out the fluid. The other opens the air and fluid all at once. The second one is better in my case with a larger compressor. Some other style guns pressurise the cup, and use less CFM. I have one of those which came with my little diaphram style compressor that I bought for my airbrush. It worked pretty good for painting my car. Much too big for models. I never had much luck spraying dope, and rarely use it anymore. It seems to dry out in the gun while using it. I can't really get it any more locally. For models I normally use an old Badger 250 gun with no fluid adjustment as it cleans easier. I bought a bigger jar too. I don't do concours models though. You will have fun playing around for a while using different amounts of reducer and pressure....
Re: Airbrush setup
I bought a bunch of all these from HF with coupons etc.... the 4 oz gun at $35 is a GREAT gun
many of the others I have spares of... get lazy and not cleay correctly...in the trash....grin
https://www.harborfreight.com/air-tools/paint.html
Re: Airbrush setup
Let us know how it goes. I have a little black brush like that one next to your silver one. I bought a new 6 gal. Craftsman(Porter Cable) compressor last weekend.
Re: Airbrush setup
Thats kidy like my set up , heck i run around 50# on my regulator to get an even spray with the mix 1 to 3 thinner sometimes less if you want more color / Have you had a chance to use the new one yet ?
Re: Airbrush setup
No I haven't used it yet, I have to prep the parts and figure out some kind of "tree" to hold 12+ little parts for spray.
Re: Airbrush setup
That looks like mine, maybe an increment larger... hard to tell in te picture. I have not shot any fluid through mine yet, but I have trouble regulating the pressure. I pump the 6 gal. tank up to 180 pounds, and set the output to 80. The 5 foot long fabric covered hose is the same as yours and it's rated at a max pressure of 85 pounds, and a bursting pressure a little less than twice that.
So I hold the trigger down and set the inline regulator(right where the blue hose begins) to 35 pounds, my guesstimated spraying pressure. When I let off the trigger, it climbs back up to the compressor output pressure of 80. So far so good. But when I press the trigger again, as I would to spray the next pass, I have to wait for maybe 5 or more seconds for the pressure to fall back to 35 pounds. That's a lot of wasted dope.
Do you have this problem? Do you think maybe it's because the blue fabric hose is swelling under pressure, or maybe just the wide volume of that hose is too much? Maybe that narrow little black hard plastic hose will solve the problem. What do you think, are you having similar pressure problems?
I would have tried it, but I had to abort the shop after I fell down on the concrete. I'can't be sure till my x-ray Wednesday, but it feels an awful lot like I've fractured that hip... the other one. The newly (twice-repaired)hip is doing great.
Re: Airbrush setup
Watch yourself. We are all getting older. I took a dive myself tripped on a stake and landed on a steel stake which gouged my hand and then I landed on the same steel stake with my butt. Still hurts, and my neck is sore, have trouble backing up the car, and I am only 60 going on 90. Building a toolshed. Anyway, I had a problem with my paint guns like you. It would blast hard, and then fizzle out to a more stable pressure. It was bad with my weak diaphram airbrush compressor but cured it with my 2 hp compressor. The bigger guns were worse, and the compressor could not keep up. Some of my guns required 8 cu. ft./min and would do that. My compressor only puts out 6 cu ft on a good day. An airbrush requires much less of course. Just put in some water and play around for a bit to see if it makes a difference. Water sprays much easier than paint but you can see what happens. I have a similar airbrush to the black one that just never worked. It would not pick up the paint at all. I have lots of guns now from over the years sales, garage sales...
Re: Airbrush setup
RknRusty wrote:That looks like mine, maybe an increment larger... hard to tell in te picture. I have not shot any fluid through mine yet, but I have trouble regulating the pressure. I pump the 6 gal. tank up to 180 pounds, and set the output to 80. The 5 foot long fabric covered hose is the same as yours and it's rated at a max pressure of 85 pounds, and a bursting pressure a little less than twice that.
Rusty,
I hope your hip is not serious, at least not fractured.
Two things you might want to try are having the pressure to the regulator only five or so psi above your air gun's operating pressure. And, see if your air gun is able to spray just air, no paint. This is done by pressing the trigger part way. If so, then you can spray just air until all pressures stabilize. When spraying with full size equipment I usually have a constant stream of air and only spray paint as the air gun is getting close to what ever is being painted.
Re: Airbrush setup
Last Saturday evening when a wrench slipped out of my vice and I fell onto the concrete, I just knew I'd fractured my "good" hip, which had been hurting pretty badly for a few days. Then I dumbly posted about it in this thread. It's not busted. I finally got an x-ray today, and it's just arthritis, which hopefully will clear up soon. I goofed.
My vivid imagination rarely takes a rest. That can be a good thing, in that the inside of my head is basically a never ending cartoon show, so I keep myself(and others) pretty well entertained. If you ever catch me laughing out of context, that'll probably be why. But other times it possesses me to blab dumb stuff such as the aforementioned example.
Sorry about that.
Sorry about that.
Re: Airbrush setup
I must have missed that. I am glad things are not worse. It’s never a bad thing to be hyper aware and don’t feel poorly for posting what you were feeling at the time.
Re: Airbrush setup
No such thing as "dumb stuff" on this forum!! Glad its not as bad as it could have been. Ive had a string of heath setbacks in last few years, saps my strength and is very frustrating.
I had to put hobbies aside for more important chores so haven't used the brush yet.
» 049 td runup
» RC setup question
» Tether car setup.
» cox rc cars gtp 049 mod
» CL line proper setup.
» RC setup question
» Tether car setup.
