U-control thrust-offset
I've been building a U-control 1/2"-scale (1/2A) P-38 Lightning. The model will be powered by identically-configured Cox .049 reed-valve engines, equipped with horseshoe backplates/carbs. The engines are basically stock product-engines which draw fuel from external tanks.
The model is my own design.. and has not been test-flown yet. There are no offset-angles built-into the fins/rudders.. and the radial-mount engine-firewalls were built with zero-offset.
There "is" a slight amount of positive-offset in the "yaw-axis" via the lead-out guide-placement.. but I wanted a "trimming-tool".. just in case the model exhibits any tendencies to roll-in if it gets breezy..
I had some wedges of composite-material.. so I cut two of them to match my model's firewall-size. The angle is very slight.. maybe 1 or 2 degrees.
I drilled an oversize pattern of the horseshoe backplate's mounting-holes.. which should easily facilitate installing the wedges.
Packs of wedges (wood or composite) can be found in the lumber-departments of home-centers. They are quite handy when you need them...
Re: U-control thrust-offset
Roddie,
When I scratch build my twin a couple of years ago, I didn't put any right thrust on the inboard engine, and I had about 3 degrees out thrust on the outboard engine. With this setup, the plane flew very well when the inboard engine quit. You can see that at about the 1 minute mark on the below video:
These were two Bee engines, but I can't see that it would be that different with product engines.
The Near-Sighted Mark
batjac- Diamond Member
That Bad Boy was carrying the mail nicely Mark!!
Thanks for the tip and posting the vid Mark. I don't remember seeing that vid before. Do you remember the line-length you used?
The photos I have of the BTC 4T show two R/H propellers (safety-yellow) installed. Are they what was used in the flight video?
roddie wrote:Thanks for the tip and posting the vid Mark. I don't remember seeing that vid before. Do you remember the line-length you used?
I'm pretty sure it was on 35' of 10 pound test Spectra. It was indeed running the yellow 5x3 rubber duckies (https://www.youtube.com/watch?v=f5d8pVg3Qtg). I really love those props. I thought about using a left and a right hand prop, but just stayed with the standard props.
getback wrote:That Bad Boy was carrying the mail nicely Mark!!
Eric, I was quite surprised at the time how fast the plane flew. It's a neat plane, and I continually think about going back to do some mods to it to make it a pseudo-German WWII bomber.
The Roomy Mark
I think if i were to build one i would put it on 40' lines to slow down the excitement
That was an impressive flight with two good engine runs. It went from 3 to 4 second laps when the first engine quit.
RknRusty wrote:That was an impressive flight with two good engine runs. It went from 3 to 4 second laps when the first engine quit.
Yeah, It would have been a longer flight, but I found out that if I don't get the engines synced just right, the harmonics cause the elevator to flutter horribly. I thought the plane was going to shake itself apart. I spent a good minute-minute and a half getting the engines synced. I think the next time that I fly it I'll put some kind of clip between the elevator and rudder to hold the elevator still until I release the stooge pin. That's what I get for making such a frictionless control system.
Shaky Mark
batjac wrote:RknRusty wrote:That was an impressive flight with two good engine runs. It went from 3 to 4 second laps when the first engine quit.
Shaky Mark
I wonder if having a twin-boom/tail might lessen that phenomenon? I planned on running L/H propellers on both engines. I have 5" x 4" left-hand propellers planned for running.. and can start the engines "left-hand" with my electric-starter.
I think about thrust-offset vs. rudder-offset.. and don't really understand how one is that-much different than the other...
» Steel or aluminum offset wedges
» 1/2a c/l beginner build/combat wing
» Rudder Offset
» Who is Building
» Carl Goldberg Hi Thrust Viking
» Rudder Offset
» Who is Building
