Carl Goldberg Hi Thrust Viking Cox_ba12
Carl Goldberg Hi Thrust Viking Pixel
Carl Goldberg Hi Thrust Viking Empty
Shocked Carl Goldberg Hi Thrust Viking
Post  NEW222 Sat Nov 21, 2020 2:43 pm
Hi all. So with both winter, Covid, and our latest Covid restrictions put into place, I thought now would be a great time to start my Carl Goldberg Hi Thrust Viking build. As for now, I have just glued the two vertical tail pieces together, and started the horizontal tail assembly. I am NOT a fast builder, nor will this be a quick build, but will definately update it slowly as I go along. The only thing yet to be determined is whether to use a Babe Bee on it and leave it as was designed, use a Babe Bee with rudder control, or, cough, cough, power it with electrons set up for climb with throttle and rudder for turning. I have plenty of time to figure it out until I cover the model.
Carl Goldberg Hi Thrust Viking Viking10
Shocked Re: Carl Goldberg Hi Thrust Viking
Post  NEW222 Sat Nov 21, 2020 2:44 pm
As well, thanks to Levent, I now have decals I can print out and use on this when the time comes! Very Happy
Post  rsv1cox Sat Nov 21, 2020 2:55 pm
Should be - Hi risk Venture Chancey, Goldberg named it wrong.
Looks a little like the Vultures that used to circle my house in Florida. Smile
Eager to see the final product.
Post  Levent Suberk Sat Nov 21, 2020 3:55 pm
I have been redrawing tail decals and going to publish here:
Carl Goldberg Hi Thrust Viking Vintag11
Post  Ken Cook Sat Nov 21, 2020 7:32 pm
My Viking lasted one flight........ I never saw it again. If you don't have a large clear field, I would suggest a dethermalizer timer. Mine corkscrewed straight up spiraling, rolled out and flew level until I could no longer see it.
Post  davidll1984 Sat Nov 21, 2020 7:56 pm
Sad To hear you lost a model y no wow it feel m'y self lost one lost batry in flight hope u Find it one day
Post  706jim Sat Nov 21, 2020 9:10 pm
You didn't say how old you are......
During my days of free flight 50 years ago I remember doing a lot of running and chasing. And yes, I had one far heavier than yours (an American Junior Baby Yank with Pee Wee 0.020 power) go missing.
If nothing else at least install a rudder R/C so you can keep it within range.
Just my thoughts.
706jim
706jim
Post  NEW222 Sat Nov 21, 2020 10:26 pm
706jim wrote:You didn't say how old you are......
Just my thoughts.
If you are asking me, I am 42. As for the rudder suggestion, that was also a thought, but was unsure if rudder only would be alright on a plane such as this. Also, if I was to go that route, would I then have to make the tail assembly a solid fixture I guess? Thank you.
Post  706jim Sun Nov 22, 2020 12:56 am
The plans probably have the tail set up as dethermalized. It probably won't be much more work to have it steerable with the dethermalize function eliminated. Both are designed to get your model home.
706jim
706jim
Post  getback Sun Nov 22, 2020 7:10 am
She is a delaicant looking little piece Turkey I am in for the ride , the BB will probably do the trick. Babe Bee .049
Post  rsv1cox Sun Nov 22, 2020 7:10 am
Tissue probably?
Finish in something Hi Viz.  I would recommend against powder blue or white.  Smile  Good luck with your build Chancey, should be ready for next summers thermals. Put your name and telephone number in/on the fuselage.
Shocked Hi Thrust Viking and R/C
Post  Exsanitary Sun Nov 22, 2020 9:22 am
As far as R/C on the Viking...http://www.frannybrodigan.com/Goldberg_Viking.asp
Exsanitary
Exsanitary
Moderate Poster
Moderate Poster
Post  Levent Suberk Sun Nov 22, 2020 9:35 am
Post  NEW222 Sun Nov 22, 2020 10:32 am
Thank you all for the compliments, help, suggestions, and decals. They are all great and really appreciated.
Post  roddie Sun Nov 22, 2020 12:11 pm
NEW222 wrote:Thank you all for the compliments, help, suggestions, and decals. They are all great and really appreciated.
Hi Chancey! If you decide to build it as-designed; for a dethermalizer... see if you can source a DT "timer" for the model, rather than the lighted-fuse method. Not sure how Ken's was set up.. but if it was a fuse-type DT, it may have have gone-out (extinguished) before doing its job. Those things can happen.. unfortunately.
Here's a couple of links.. but I have no experience with them.
https://www.faimodelsupply.com/product-category/timers/
http://www.texastimers.com/
Post  NEW222 Sun Nov 22, 2020 1:21 pm
Thank you roddie. All options are still on the table.
Post  NEW222 Sun Nov 22, 2020 7:02 pm
Left wing mostly framed up and drying. Once dry, I gotta set the dihedral angle and glue it in the correct place before removing it from the board. Then as was the tail, I will be gluing the bottoms of the spars.
Carl Goldberg Hi Thrust Viking Htv110
Post  NEW222 Thu Nov 26, 2020 7:49 pm
Wing building was pretty straightforward, so never snapped a picture of the other one being built. So now, the whole tail is built, as well as the wing. As I was building each wing panel, I made a dieheral gauge/block from a piece of foam to set the correct angle. When I was joining the two wing halves, I also made 2 more of these and set the final angles, glued and allowed them to dry properly, then added the gussets where they are supposed to be on the plans. While they are still in the 'rough', they will remain that way till spring when I can go outside and sand them. Next up will defiantely be the fuselage as that is all that remains. I am hoping to start that this weekend. More pictures to follow.
Carl Goldberg Hi Thrust Viking 12649510
Post  getback Fri Nov 27, 2020 7:20 am
Looking Good Chancey , weird how the wing spars cross at an angle in the sections . Its moving along pretty fast for now / shame you have to wait so long to get the sanding done . RC Plane
Post  OhBee Fri Nov 27, 2020 12:45 pm
Friend  of mine built one of those when we were kids.  We lived up on a hill surrounded by open fields. It's first flight was also the last we saw of it! We were clueless as to setting a turn into control surfaces. Filled the tank on the Babe Bee and let it go. It was gaining altitude and clearing a big woods the last we saw of it headed NW. Everytime I drive past that wooded ridge I think of that . It was over a mile away last we could see it with binoculars. Every summer there's flocks of vultures circling over the corner of that ridge,so there must be some great thermals that develop there for some reason!
OhBee
OhBee
Post  Marleysky Fri Nov 27, 2020 8:49 pm
getback wrote:Looking Good Chancey , weird how the wing spars cross at an angle in the sections . Its moving along pretty fast for now / shame you have to wait so long to get the sanding done . RC Plane
Those crossed spars do look strange. I think they were designed that way to give a little more “ surface area” for glue strength in that area, rather than just making a face to face joint, or “butt Joint” ! Those two spots were the “weakest link” on the wings I built many years ago on a Goldberg 1/2a Blazer. After the first flight I had to repair both sides exactly at that joint! They couldn’t take the stress of “falling “ out of the sky after the de-thermalizer released the elevator.
Post  NEW222 Sat Nov 28, 2020 12:12 pm
Yep, those spars do indeed look wierd for sure. They are not straight either. The are actually 'punched out' of one of the die-cut balsa sheets and are tapered as well, so the thinner end is at the outboard edge of each panel.
Thanks for the note of them being a 'weak' spot in the design. I did personally glue it very well. I wonder if I drilled a small hole and inserted a toothpick into them to help strengthen it?
Post  Cribbs74 Sat Nov 28, 2020 7:44 pm
If it’s a big concern then just wrap the spar ends with cloth soaked in epoxy. It’s probably fine as is, or join a Free Flight forum and ask if anyone recommends anything.
Post  Ken Cook Sun Nov 29, 2020 6:46 am
Out of all the polyhedral wings that I've built, the spars cross as in this design. Some rubber powered planes angle the end ribs so that they can be butt together. Many used Ambroid as it was preferred, reason being is that it provided some flex without breaking the spar itself. On a joint where they cross, when CA is used, the wood breaks directly outside of where the glue wicked in.
Post  NEW222 Sun Nov 29, 2020 11:20 am
Well, I have since decided to just leave the wing as was originally designed. I did not use any CA glue, all of my joints are done with Gorilla Glue wood glue which itself has a bit of flex to it as it is a PVA glue. The only spot I had used any CA is a drop on teh spar joints where they do intersect just to hold together while drying alongside some clamps. Thanks for the input.
