MAGNUM XLS .15 Cox_ba12
MAGNUM XLS .15 Pixel
by sosam117 Today at 10:25 am
by rdw777 Today at 9:17 am
MAGNUM XLS .15 Empty
MAGNUM XLS .15
For Sale MAGNUM XLS .15
Post  JPvelo Sat Jan 21, 2017 6:55 pm
Good strong runner, $45 shipped conus.
MAGNUM XLS .15 PgiUZH8
MAGNUM XLS .15 K43oQ8Y
MAGNUM XLS .15 B9l2RvX
JPvelo
JPvelo
For Sale Re: MAGNUM XLS .15
Post  1/2A Nut Sun Jan 22, 2017 8:51 am
How many flights do you have on it and what fuel mix oil / nitro ratio?
What did you upgrade to?
Post  JPvelo Sun Jan 22, 2017 9:23 am
1/2A Nut wrote:How many flights do you have on it and what fuel mix oil / nitro ratio?
Probably 20-30 flights, powermaster 10/22.
Upgraded to a Norvel .15 with a Perry carb and 35% nitro Devil
JPvelo
JPvelo
Post  fredvon4 Sun Jan 22, 2017 10:36 am
Sorry Jim--- slight hi-jack
I am always curious about forum names and spend (probably too much) time trying to figure out what prompted the screen name
Because I know you from another site with, what I assume is, your real/given name...JPvelo has me just wondering
Cool little engine, I hope someone scarfs it up
Post  JPvelo Sun Jan 22, 2017 11:02 am
Fred,
JP= my first and middle initial.
Velo= French for bicycle
My other hobby/passion is restoring vintage bicycles. In fact I'm selling off airplane stuff to fund my most ambitious restoration yet, a hand built Roberts tandem bicycle from England.
JPvelo
JPvelo
Post  1/2A Nut Sun Jan 22, 2017 12:45 pm
I have one of these it's a good engine but can't seem to turn up the
rpm I had hoped for here is a bench test.
Published on Nov 29, 2015
Magnum XLS .15A APC 7x5 MACS Tuned Pipe
18,100 rpm / 86mph /.49hp / 2.3 lbs thrust / 366w
Break in bench test ran up for a rpm check
Options:
APC 7x6 est 17k / 97 mph
6.5x6.5 race prop if at 20k unloaded 123mph
Post  Surfer_kris Sun Jan 22, 2017 2:35 pm
1/2A Nut wrote:I have one of these it's a good engine but can't seem to turn up the
These engines are simply not timed for a tuned pipe, thats all.
I have an ASP .15XLS that does around 18500rpm on the APC 7x5 prop and 10% nitro. That's with a "super-quiet" muffler from an old MDS .17 engine.
If you want to use tuned pipes, take a look at some of the car engines. These are inherently timed to take advantage of a tuned pipe and they will really deliver also as an airplane engine. The Picco .12 for instance will spin an APC 7x4 prop at around 22000rpm. That's is a very useful propload/size as well.
Surfer_kris
Surfer_kris
Post  1/2A Nut Sun Jan 22, 2017 9:57 pm
Right the XLS .15 only has 150 deg timing Huh...
Not much of a window for pipe combustion pressure.
The rule of thumb if fuel starts dribbling out of the carb
while running on a pipe your timing is too low to function.
My test had the header a bit long by around 1.5 inches.
Was a quick check of the top end during break in procedures.
Prop would need to spin static at 21.4k to use what pipe
pressure could slip into the combustion chamber.
The engine will take some more prop testing to get to where I
will find it useful for speed.
APC 6.5x6 should be a better prop solution a carbon 6x6
will have it kicking some arse. Pipe length to MRP should be
10.4in. to hit 24k unloaded. Bench tested at 11.75in. MRP.
It will not be much effort to yield a 130 mph plane. The
up swing of less rpm is longer run times. Shh
