Wrench/exhaust web question Cox_ba12
Wrench/exhaust web question Pixel
by roddie Today at 1:34 pm
Wrench/exhaust web question Empty
Wrench/exhaust web question Empty Wrench/exhaust web question
Post  wha-tah-hey Mon Oct 31, 2016 10:50 am
I have 2 older Cox wrenches with cylinder removal spanners measuring .282 and .289 widths.
My old GB cylinder's webs measure .271 so no problem.
I have 2 cylinders (both #1) with exhaust port webs measuring .291-.298, depending on which web I measure.
I can dress the spanners with a file, but for you fellows who can make precise measurements I'm curious what your wrenches and webs measure.
wha-tah-hey
wha-tah-hey
Wrench/exhaust web question Empty Re: Wrench/exhaust web question
Post  Surfer_kris Mon Oct 31, 2016 11:55 am
I can see a potential for another "Cox accuracy" discussion here Shh
Checking two of my tools (both unused) I get the following numbers:
Black tool: 0.310"
Shiny metal: 0.282"
This likely shows some evolvement through out the years, and measuring on a few "thicker walled" (with and without a step) cylinders gives me typical values between 0.298-0.304" i.e. fine for the blackened tool. Only the earlier thin walled cylinders (at least out of my engines) have a width of about 0.270 (i.e. suitable for the older shiny metal tool).
The best way is never to use the tool anyway, as you risk to damage the cylinder if you do. In any case, do heat up the cylinder and case first (with a heat gun) as that really lower the force needed to loosen cylinders and heads.
Surfer_kris
Surfer_kris
Post  wha-tah-hey Mon Oct 31, 2016 2:18 pm
I opened one wrench with a file to .303" then noticed the jaws barely extended past the cylinder bore on the opposite side, so I filed the slot 1/16" deeper (to 17/32") so that it fits all the way across the cylinder.
A round needle file cut in the center rear let's it fit even better.
Took about 5-6 mins.
It may not completely prevent web damage but with care to fit the wrench in position properly and a little heat it should minimize it.
Wrench/exhaust web question Cox_wr11
wha-tah-hey
wha-tah-hey
Post  Surfer_kris Mon Oct 31, 2016 4:20 pm
The old tool has shorter jaws as it was intended for the thin walled cylinders, while the later "black" tool has longer jaws to match the thick walled cylinder in you picture.
I prefer to cut two flats on the top cylinder cooling flange and use the tool there instead. Much lower risk of damaging anything...
Surfer_kris
Surfer_kris
Post  wha-tah-hey Mon Oct 31, 2016 4:36 pm
That's a modified black tool in the pic, Kris, I suppose older and made for the stepped cylinder?
Here's before.
Wrench/exhaust web question Cox_wr12
wha-tah-hey
wha-tah-hey
Post  ian1954 Mon Oct 31, 2016 4:46 pm
I would advise not using one of the tools to remove a cylinder using the exhaust ports. The cylinders are relatively soft metal and easily damaged.
Fine if you are going to replace the cylinder and throw the old one away but some of the cylinders are not easily replaceable. I use a leather strap around the cylinder after heating the crankcase but even that requires care.
I also use nylon and teflon bars machines the fit exactly and patience with soaking and heating.
It is easy to end up with a burr inside the exhaust port and even distort the cylinder with too much force. Especially the thin walled cylinders.
ian1954
ian1954
Post  RknRusty Mon Oct 31, 2016 8:17 pm
The only times I have used the exhaust port fork, I clamped the tool horizontally in my big vice so it was held lengthwise against both narrow sides of the tool, preventing the fork from spreading. Then, holding the crankcase, I slid the exhaust slits between the trapped fork and turned the crankcase. Don't take this as an endorsement of the tool, but it's the safest way I know of, if you do want to try it. The fork can not spread while applying leverage this way.
