Help, the vent hole on my GoldenBee plastic backplate opened up.  - Page 2 Cox_ba12
Help, the vent hole on my GoldenBee plastic backplate opened up.  - Page 2 Pixel
by rsv1cox Today at 10:20 am
by rsv1cox Today at 10:07 am
Help, the vent hole on my GoldenBee plastic backplate opened up.  - Page 2 Empty
Page 2 of 2 Previous  1, 2
Help, the vent hole on my GoldenBee plastic backplate opened up.  - Page 2 Empty Re: Help, the vent hole on my GoldenBee plastic backplate opened up.
Post  Paul_BB Wed Aug 31, 2016 9:37 am
Well I bought on eBay an original NIB Black Widow. I'm not sure if this engine is completely original but now I have a metal (looks like brass anodized steel) backplate for stunt fuel tanks.
Looks like a Babe Bee backplate whose vent holes have been "filled" with a drop of brass or another metal? Funny. Smile
Help, the vent hole on my GoldenBee plastic backplate opened up.  - Page 2 Bw_110
Help, the vent hole on my GoldenBee plastic backplate opened up.  - Page 2 Bw210
Help, the vent hole on my GoldenBee plastic backplate opened up.  - Page 2 Bw310
Paul_BB
Paul_BB
Bronze Member
Bronze Member
Post  pkrankow Wed Aug 31, 2016 10:20 am
The metal backs are die cast zinc alloy. There were a number of different molds used over the years, and that one was altered from having the fill tubes cast, instead of the fill tubes being cut off in a later machining step.
The brass color is a plating treatment that extends the life of the metal.
Post  Paul_BB Wed Aug 31, 2016 10:37 pm
pkrankow wrote:The metal backs are die cast zinc alloy.  There were a number of different molds used over the years, and that one was altered from having the fill tubes cast, instead of the fill tubes being cut off in a later machining step.
Thanks for the information Phil. Smile
So this backplate is an original one?
Paul_BB
Paul_BB
Bronze Member
Bronze Member
Post  Paul_BB Thu Sep 01, 2016 1:58 am
I have another question.
When I look at the cylinder list on the Cox model engine Wikipedia page:
https://en.wikipedia.org/wiki/Cox_model_engine
I see that the Black Widow pre 96 cylinder has:
- a thick wall
- open exhaust ports
- two bypass ports
- Sub Piston Injection
- number #1 engraved on the cylinder
- no bypass booster
And the Black Widow post 96 cylinder has:
- a thick wall
- slit exhaust ports
- two bypass ports
- no Sub Piston Injection
- no number engraved on the cylinder
- one bypass booster
But my cylinder has:
- a thick wall
- two bypass ports
- no bypass booster
So I what the heck? Smile
Paul_BB
Paul_BB
Bronze Member
Bronze Member
Post  KariFS Thu Sep 01, 2016 2:51 am
That is a good looking Black Widow. As for the number on the cylinder, sometimes it is not very deeply punched or engraved. Look closely on the sides of the exhaust ports, sometimes the number is stamped there.
I would say, if your engine is an NIB, that it is from the early eighties. You have the round prop drive, aluminum spinner and the metal backplate. Somewhere there is a list of changes on the Black Widows, not sure when the aluminum spinner was brought to replace the rubber one.
The metal backplates on all the tanked engines are rather crudely made and finished if you compare them to the rest of the engine Huh... But your backplate most likely is in its original condition, since the gold-colour plating on it is intact. Besides, I don't think the backplate metal can be soldered, brazed or welded.
I have a later "pre 1996" BW, it has the similar cylinder (with a very faint "1" on it), plastic backplate and a hex driveplate. And also the aluminum spinner.
Post  Paul_BB Thu Sep 01, 2016 5:19 am
Thanks for the reply Kari Smile
Paul_BB
Paul_BB
Bronze Member
Bronze Member
Post  Paul_BB Thu Sep 01, 2016 5:44 am
I also read on Martin Hepperle's site that one cannot put a muffler around a SPI cylinder because it will kill its performance.
Paul_BB
Paul_BB
Bronze Member
Bronze Member
Post  getback Thu Sep 01, 2016 6:27 am
http://www.mh-aerotools.de/airfoils/index.htm Go to Cox engines scroll down on the BEE 's to the BW for more info // I have never seen a NIB BW that the filler tubes have been removed and filled in , don't make since that they would go to that much labor $$ when they could just use the correct one . That one looks to have came from a non stunt tank engine ? But I don't know for a fact , Mark B. or Mud would probably have better info on this > .
Post  Paul_BB Thu Sep 01, 2016 7:12 am
Thanks getback,
You must be right, I have been tricked. With all the engines and the engines parts around, it's easy to find a sucker. Oh well... Sad
Paul_BB
Paul_BB
Bronze Member
Bronze Member
Post  pkrankow Thu Sep 01, 2016 7:45 am
Paul_BB wrote:I also read on Martin Hepperle's site that one cannot put a muffler around a SPI cylinder because it will kill its performance.
Yes and no...  You will loose some performance due to loss of the fresh air intake through the exhaust port during SPI.  Instead you will have exhaust gas recirculation (EGR).  The engine will run fine.  (It may even throttle better on an intake throttle, but with a lower peak rpm)
Post  Paul_BB Thu Sep 01, 2016 7:51 am
Thanks Phil.
Paul_BB
Paul_BB
Bronze Member
Bronze Member
Post  getback Thu Sep 01, 2016 8:16 am
Paul_BB wrote:Thanks getback,
Not to worry, its a good looking engine use it for what it was intended for or you may can find another back plate to replace that one if you don't want to run it , Smile
Post  crankbndr Thu Sep 01, 2016 11:42 am
Thats just a casting flaw, I have a few the same.
Post  roddie Fri Sep 02, 2016 2:12 am
For what it's worth...... when Estes purchased Cox Hobbies.. there were some unorthodox combos of engines being produced. I don't really know.. but from what I've read; engine parts were mixed without regard for "functionality". The Cox engineers who had been involved in the "evolution" of the engines.. were "likely" no longer employed by Estes. The Estes guys were "rocket" people.. and certainly not glow-engine proficient. I would imagine that they were given the task of liquidating the engine parts.. without regard for important technical data. Worse still.. there may have not have been much presence of engineering at all. Engines were likely assembled by untrained workers that were given parts that had not been batched/checked by QC. Estes' glow-engine production of the leftover Cox engine parts-stock didn't last for very long. I'd venture to guess that scads of parts were sold-off.. which is evident by what we've seen emerge from various vendors over the last couple of decades.
The "Black Widow" and "Killer-Bee" were the most ambitious high-performance reed-valve engines that Cox produced in their later years. Kustom-Kraftmanship (KK) was a cottage-industry devoted to the further performance enhancements of the Cox engines. Those were certainly the "golden-years". Cox had produced the "Golden-Bee .049 reed-valve engine with integral stunt-vented tank.. which was basically a "Babe-Bee" that could fly inverted.. without fuel leaking out of the tank vents.. and an additional 3cc's worth of fuel. It was a breakthrough in 1/2A stunt engines that would enjoy many years of success. I believe that this engine underwent some changes in it's final year(s) of production; that included increasing the ID of the venturi.. and a more aggressive intake-ported cylinder. This (I believe..) lead to the production of the "Black-Widow" engine.
I have two Golden-Bee engines; one having a backplate with an .062" air-take.. and the other having an .082" air-intake.. (the .082" air-intake has a matched-size venturi-tube on the tank.. and is "gold" anodized on the inside.. and "not" drilled-out)
I've posted these pics a few times.. but I think that they may have some evolutionary merit.
The backplates..
Help, the vent hole on my GoldenBee plastic backplate opened up.  - Page 2 Golden10
The tanks..
Help, the vent hole on my GoldenBee plastic backplate opened up.  - Page 2 Golden11
Unfortunately.. I do not recall the cylinder-porting configurations between the two engines. They've been disassembled several times and their parts interchanged before I knew the importance of archiving their original configuration. These two engines have been in my family for 40+ years.
I honestly don't know what to make of your Black Widow's backplate. It's obviously a Babe Bee part that has had the two vent-tubes cut-off and filled by some means. Possibly brazed? Not sure.. but it looks to be of a good molten-metal seal. Much better; that it's a metal backplate though. It will outlast a plastic one indefinitely. That metal is known as "Zamac" (I believe..) which is similar to "white" or "pot" metal.. and was cast into that shape.. then machined. They have survived the test of time. Scoop them up if you can find them.. if you want to run your "tanked" Bee engines into the future!
Post  Oldenginerod Fri Sep 02, 2016 3:00 am
crankbndr wrote:Thats just a casting flaw, I have a few the same.
I agree, although I don't have any like that pictured. It looks to me like the casting "pattern" was modified to delete the nipples and what you see on this backplate is the post-casting result.
Post  KariFS Fri Sep 02, 2016 4:13 am
I too am pretty sure that Paul's backplate is not a modified Babe Bee one. Looks like it is made of the same casting though, with the original fill nipple not drilled through but instead cut off. Later Babe Bee metal ones only have one nipple and a small hole right next to it. The small hole would be in the flat area on the left side of Paul's backplate, right next to where the nipple would be. I see no signs of plug or mod in that area. The indentation on the right side could be some crap in the mold, or maybe the mold was modified or repaired, or some residue was left in there from a previous casting. In any case I am sure the part came out of the plant like that. This is of course just a theory, and something only a former Cox employee could confirm.
This engine is probably one of the last ones to get a metal backplate, so the molds were already beginning to wear out, and often you can see that the line where the mold halves were joined shows as a visible ridge on the sides of the backplate.
Roddie, I think your "golden" large-venturi stunt tank could be a Black Widow one that was anodized in gold colour either by a mistake by the anodizing company, or by Cox. So there was a batch of "more powerful than usual" Golden Bees out there at some time Smile
Post  Paul_BB Fri Sep 02, 2016 6:38 am
Thanks for all the informations guys. There is a picture in the instruction manual and I can clearly see that my cylinder is the same as that on the picture. I was suspicious because of the lack of rust on the cylinder, but they use to make good steel back then.
I'm back from breaking-in my Black Widow. I use only 12% Nitro and a Cox black 6x3 prop. I got a steady max rpm of around 13500 which is nice I think. Very steady and not sensitive.
I tried out the muffler and the max rpm dropped to 1200 which is not too bad but the peak is not really steady, pretty sensitive.
Paul_BB
Paul_BB
Bronze Member
Bronze Member
