VIDEOS: AMA´S by Frank Ehling . Cox 010 (pag. 4) and Cox 020 (pag.5)
Page 3 of 5
Page 3 of 5 • 1, 2, 3, 4, 5
MauricioB- Top Poster
Re: VIDEOS: AMA´S by Frank Ehling . Cox 010 (pag. 4) and Cox 020 (pag.5)
central reinforcement with dope and paper silkspan:
Hello, here I leave photos of accommodation for aileron servo:
hello ... I started the coating step .... the pictures!
More well photographed steps.
Which covering material did you use?
I can see that it is iron on but did you apply anything to the balsa wood before applying the covering?
Beutiful airplane of the Great Frank Ehling, but I think that with the big angle wing diedral it is not necessary ailerons. But really have a vintage shape.
ian1954 wrote:More well photographed steps.
Hello Ian,
MONOKOTE use.
Do not put anything in the wood, the coating material goes directly to the timber and is applied by means of temperature.
I use a clothes iron for gueso and a welder for smaller places like the engine cowling, greetings, Mauricio.-
I drew a picture of internet board, printed and made assembly sequences.
https://www.google.com.ar/search?q=tablero+de+avi%C3%B3n&espv=2&biw=1366&bih=637&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwjKnJXD1a7MAhXFIJAKHRTSBD0QsAQIJA#imgrc=swbJP6LvpZx8SM%3A
The board was printed on photographic paper and then has a transparent plastic adhesive to protect the print:
windshield: use a piece of polycarbonate that are available in bookstores, draw approximate and snip, is attached with superglue, then place a strip of adhesive ORACAL black color, there the sequence:
jmcalata wrote:Beutiful airplane of the Great Frank Ehling, but I think that with the big angle wing diedral it is not necessary ailerons. But really have a vintage shape.
Hola!, eres de España!, hablo castellano así que si me escribes puedes hacerlo en español, de todas formas por respeto al sitio dejare la traducción para que se siga compartiendo.
Es verdad, el modelo original no lleva alerones, solo tiene timón de dirección, pero hice esta modificación por gusto personal, tambien modifique el diedro original, ya que para poseer alerones era mucho.
Voy a ver como resulta, me gusta más el vuelo con alerones que solo con timón.
Te envío un abrazo y gracias por dejarme tu comentario. Mauricio.-
Hello !, you are from Spain !, I speak Castilian so if you write me you can do it in Spanish, anyway out of respect to the site'll leave the translation to continue sharing.
True, the original model does not include spoilers, just rudder, but I made this modification by personal taste, also modify the original dihedral, ailerons as to possess was a lot.
I'll see how it turns out, I like the flight ailerons with rudder only.
I send you a hug and thanks for letting me your comment. Mauricio.-
Thanks for the info. Monokote isn't available in the UK - the nearest we have is Solarfilm for weight but it isn't fuel proof.
It also doesn't stick very well to raw balsa especially sheet material and so I have to seal the surface first.
The other iron on products tend to be a little too heavy for small planes but they stick and are fuel proof.(within limits!).
Very very nice Mauricio! Thanks for sharing so many details! They are very helpful to the scratch-builder! I also enjoy your "spirit" of challenging design-spec. for alteration/improvement. "Nothing ventured.. nothing gained".
Great job what it the frame weight all covered?
ian1954 wrote:Thanks for the info. Monokote isn't available in the UK - the nearest we have is Solarfilm for weight but it isn't fuel proof.
Ian Hello !, as always, a pleasure for me to share with you all through this excellent forum.
How strange that in England not get MonoKote ?? !!, is an excellent material to work in large and small models.
roddie wrote:Very very nice Mauricio! Thanks for sharing so many details! They are very helpful to the scratch-builder! I also enjoy your "spirit" of challenging design-spec. for alteration/improvement. "Nothing ventured.. nothing gained".
Roooddiiieeee!!!!
1/2A Nut wrote:Great job what it the frame weight all covered?
Hello !, which is good as being like you!
Here weights:
grams:
Difference: (net weight of the coating)
Grams: 28
Ounces: 0.98
Pounds: 0.0617
Grams: 28
Ounces: 0.98
Pounds: 0.0617
» Timer´s Nightmare (Frank Ehling) 1942
» My Cox Powered RC Planes
» Cox Videos
» R/C airboats
» Cox Videos
» R/C airboats
Page 3 of 5
