VIDEO: Cox 010, artisanal replacement backplate part - Page 2 Cox_ba12
VIDEO: Cox 010, artisanal replacement backplate part - Page 2 Pixel
VIDEO: Cox 010, artisanal replacement backplate part - Page 2 Empty
Page 2 of 2 Previous  1, 2
VIDEO: Cox 010, artisanal replacement backplate part - Page 2 Empty Re: VIDEO: Cox 010, artisanal replacement backplate part
Post  MauricioB Wed Mar 23, 2016 4:50 pm
Admin wrote:Very nice! Thumbs Up If you want to make more, I bet they would sell well.
Hi, thanks for your comment. It is possible, but the idea is to share a method that whoever has no way to get an original spare can manufacture it himself. It is a humble contribution. Greetings, thanks, Mauricio.-
Post  getback Wed Mar 23, 2016 5:03 pm
cheers cheers Thank You for sharing you are very good craftsman !! getback Thumbs Up
Post  MauricioB Fri Mar 25, 2016 5:51 am
getback wrote:cheers cheers Thank You for sharing you are very good craftsman !! getback Thumbs Up
Thank you very much!, Mauricio.-
Post  MauricioB Fri Mar 25, 2016 5:53 am
Here in the video, you can see step by step and the engine running, greetings,Mauricio.-
Post  ian1954 Fri Mar 25, 2016 7:18 am
Another excellent video - it takes a lot of work to put something like this together.
Background music - text - stills - video and sound. You and Jose are well up on this one - I have trouble maintaining the patience to edit video.
Music - I get easily sidetracked
https://www.coxengineforum.com/t9564-baccara#121553
ian1954
ian1954
Post  getback Fri Mar 25, 2016 7:45 am
Thank You very much Mauricio !! Excellent Video and run , It works Easter Bunny Eric Small Cox Logo
Post  1/2A Nut Fri Mar 25, 2016 6:40 pm
Thank you another Greenie for you ! Small Cox Logo
Can you make a few to sell? If so add me to the list =) = )
If you have Pay Pal can send you say $35.00 shipped  Small Cox Logo
Easter Bunny Cant Resist The Bunn Easter Bunny Cant Resist The Bunn Easter Bunny Cant Resist The Bunn Easter Bunny Cant Resist The Bunn
Post  706jim Sat Mar 26, 2016 10:53 am
Nice work. But I had to laugh at that digital tach. +/-10rpm resolution, but varies from 8000 to 30000rpm while engine rpm stays virtually constant! A good case for an analogue tach.
706jim
706jim
Post  MauricioB Sat Mar 26, 2016 11:39 am
ian1954 wrote:Another excellent video - it takes a lot of work to put something like this together.
Hello !, thanks! ..... It is true, requires a little patience to make a video, and often is not as one would like to present and have to start over. But somehow more or less quality one can share and we can all learn from each other!
A hug, Mauricio Thumbs Up .-
Post  MauricioB Sat Mar 26, 2016 11:42 am
getback wrote:Thank You very much Mauricio !!  Excellent Video and run , It works Easter Bunny  Eric Small Cox Logo
Eric Hello !, thanks for letting me great greetings message for you ! Mauricio.-
Post  MauricioB Sat Mar 26, 2016 11:45 am
1/2A Nut wrote:Thank you another Greenie for you ! Small Cox Logo
Hi, Thanks for rating this work, now I have the possibility to pieces, because I do not have the time they need, but if you ever do something, I will be reporting! thank you very much !..greetings, Mauricio.-
Post  MauricioB Sat Mar 26, 2016 11:51 am
706jim wrote:Nice work. But I had to laugh at that digital tach. +/-10rpm resolution, but varies from 8000 to 30000rpm while engine rpm stays virtually constant! A good case for an analogue tach.
Hi, thanks for your message !.
Actually it is not a problem tachometer, but a misapplication of me, I will try to explain, I find myself in the workshop that has artificial lighting and simultaneously provide natural light through the window and therefore the tachometer that works perfectly with natural light (sunlight) commits read errors.
I really should not have used the tacometro inside the room to avoid this mistake, but I repeat, it is not a problem tachometer, but misuse for my part, I apologize.
Greetings, Mauricio.-
Post  MauricioB Sat Mar 26, 2016 10:05 pm
Mr.706jim:
You can see the same tacometro as it behaves in this video with natural light!.
.Mauricio.-
Post  1/2A Nut Sat Mar 26, 2016 10:43 pm
With the metal back plate the seal is good rpm readings with the Cox Grey 3x1.25 prop 27,131 rpm
I was able to get a solid reading with my audio app. Best peak was 27,293 rpm.
These are real good readings, attributes from the metal back plate. The plastic ones are prone to
heat up and then leak loosing some venturi suction.
Post  MauricioB Sat Mar 26, 2016 10:50 pm
1/2A Nut wrote:With the metal back plate the seal is good rpm readings with the Cox Grey 3x1.25 prop 27,131 rpm
This is a real good reading attributes from the metal back plate. The plastic ones are prone to
heat up and then leak loosing some venture suction.
Hello !, here I am on the connected PC and just read your message. It's very interesting what you mention, so the metal remains the most constant rpm !, great!
What is your name? thanks !, greetings, Mauricio.-
Post  1/2A Nut Sat Mar 26, 2016 10:59 pm
Your welcome its Brad,
Amp Abuser on RC Groups
Pond Skipper on RC Universe
1/2A Nut on Cox Engine Forum
Today I hit 102 mph with a TD .010 - how about 1 back plate $40.00 shipped?
Post  MauricioB Sat Mar 26, 2016 11:12 pm
1/2A Nut wrote:Your welcome its Brad,
Awesome! ....is a missile enraged! Very Happy
You use Skype¿?
Post  1/2A Nut Sun Mar 27, 2016 1:21 am
No I don't use Skype you can send PM me a message using this site
https://www.coxengineforum.com/privmsg?mode=post&u=1200
Note there is a PM tab under our Icon pics.
Post  MauricioB Tue Mar 29, 2016 9:50 pm
1/2A Nut wrote:No I don't use Skype you can send PM me a message using this site
okay, no problem, the idea was to chat and share video via camera, anyway keep in touch around here.
I did tests with .15 Sportsman, works great !, thanks !, greetings, Mauricio.- Beer Cheers
