Brodak Mustang Build
Page 3 of 4
Page 3 of 4 • 1, 2, 3, 4
Re: Brodak Mustang Build
Rusty,
Yes it has some sort of particulate in it.
Once I put polyspan on the wings my son said the red stuff looked like bacon! He was right.
JPvelo- Diamond Member
I like CF control rods, they give that bit of extra precision to your control input. And it looks professional too. I even use a tiny CF tube on my Li'l Satan. Cute. Which reminds me, I have a 1/2A Mustang and another Li'l Satan still in the box.
Hey Jim that's the same stuff I have used for years , are you cutting it or put it on straight , as a kid I put it on straight man that's some thick stuff I've been cutting since on CEF . Rusty they still make colors just not that many ... http://midwestproducts.com/collections/paint //// I like Midwest Wood but that's high even if there are more than one piece per bundle . I go to this one swap meet in Jan. and there is one guy there has Aero colors ole stock but still good , price is right too !! no clear though getback
Eric,
I'm using it full strength, what do you cut it with?
Dupont 3608S thinner
I thought 3806S was taken off the market 15 years ago? Lol, i remember everybody freaking out and stockpiling the stuff?
White fillets on pink tissue packs the aesthetic punch of 1970s feminine hygiene product packaging. Should spray primer Monday.
Nope, you can still buy it here and the last gallon I purchased was under a new label by Chroma Color. The numbers are still the same 3608S.
hmmm...from everything i'd read, seen or heard, it was a foregone conclusion that DuPont was taking it off the market? I guess that goes to show you don't believe everything you read, hear or see.
Jim I use Aero Gloss Thinner about 1/2 and 1/2 ,, I tried to get that DuPont stuff and no one at the paint stores know of it . EricJPvelo wrote:Eric,
Shootin' primer.
Base coat on, no more photos until decals are on.
Ya doin' Bob Hoover's bird from days gone by... Rockwell International scheme?
ARUP- Gold Member
Not tellin', it's top secret until finished.ARUP wrote:Ya doin' Bob Hoover's bird from days gone by... Rockwell International scheme?
Wicked Jim! Nice to have paintin' weather. That can put a damper on finishing a build. Looking forward to seeing it all decked-out!
Looks good Jim,
Are you expecting a trim problem?
Cribbs74 wrote:Looks good Jim,
No, I just wanted to experiment on this one. If I build a full fuselage stunter I'll know what I'm doing, hopefully.
Jim, that's a Brodak kit? Is John Miller the CAD designer? I'm very curious as to why the small sheeted leading edge and not a full D tube back to the spar. Did the kit offer the fairings from the leading edge to the fuse? Ken
Ken Cook wrote: Jim, that's a Brodak kit? Is John Miller the CAD designer? I'm very curious as to why the small sheeted leading edge and not a full D tube back to the spar. Did the kit offer the fairings from the leading edge to the fuse? Ken
Yes, it's a Brodak. The kit has two little triangle fairings for the leading edge. They install over the landing gear. I was going to leave them off.
roddie wrote:RknRusty wrote:
I think the adjustable trim tab and the anchor point is a good idea. Hopefully you won't need it, but I usually seem to. I think every plane I have except the Shoestring and the Magnum(R.I.P) needs one. I carry several aluminum ones in my flight box of various sizes and degrees of deflection.
I've read here about trim-tabs before. How does the adjustment part function? I was trying to envision a way of doing it. What I was thinking; is a thin steel strip/tab mounted chordwise inside the wing, and extending out a slot in the T/E. A captive sheet-metal screw would thread through the inside center of the strip. Turning the screw in/out would cause the strip to bow in either direction. Is that thinking way too far outside the "tip-weight" box?
Here's the finished trim tab, 4-40 all thread with adjustable ball links:
That'll do it.
I think I'll add one to my Twister wing, now on the table. I'll probably use #2 hardware with a small 1/2A horn, and punch through the wing as close as I can, to avoid drag as much as possible, Maybe anchor it to a ply web between the top and bottom spars. As far as weight, that's just some you don't have to add to the box.
That looks anchored through the weight box lid.
Good idea.
Good idea.
pkrankow wrote:That looks anchored through the weight box lid.
Good idea.
Thanks Phil,
I was trying to figure out how make a hard attachment point and realized I had one already.
Good job Jim, very clean.
RknRusty wrote:That'll do it.
You could just fly it and see if it even needs one.
» Anyone ever try this F-82 Mustang from Brodak?
» F-82 Twin Mustang build thread- preliminary
» Brodak Ringmaster S-1 build
» New Build, Brodak Shark 402
» brodak stunt man build
Page 3 of 4
