First cox run! Cox_ba12
First cox run! Pixel
by rdw777 Today at 5:07 pm
by rdw777 Today at 4:51 pm
by getback Today at 12:05 pm
First cox run! Empty
First cox run!
First cox run! Empty First cox run!
Post  TopBannana Wed Jul 29, 2015 8:56 pm
Ive had a cox engine for at least 4 years (not very long) but i never bought the fuel for them in the amount of time.
Finally today my COX SUPERFUEL came in the mail
So, I was dying to try and run an engine so I used my 1/2 black widow (i call it that because i need a new backplate, im running a regular babe bee backplate as of now), because it had a built in gas tank
And once I figured out the needle valve position it started right up!-I Just Have To Say This Site Rocks! and I Love This Forum!  Babe Bee .049
I HAVE TO WEAR EAR PROTECTION NEXT TIME  lol!
-Trevor
TopBannana
TopBannana
First cox run! Empty Re: First cox run!
Post  TDbandit Wed Jul 29, 2015 9:39 pm
Very nice run man! love those insta-starts Very Happy July-27
(Bandit)
TDbandit
TDbandit
Post  Oldenginerod Wed Jul 29, 2015 9:45 pm
Trevor.
What size is your prop? The engine sounds like it's working a little hard like the prop is too big. It won't hurt it, but it will run a lot sweeter and faster with a smaller prop. Yes, you should wear hearing protection. Nice run anyway.
Post  TopBannana Wed Jul 29, 2015 9:47 pm
Im Running a 5.5x4 prop
TopBannana
TopBannana
Post  Oldenginerod Thu Jul 30, 2015 7:07 am
Well that's about right. Just that it sounded to be labouring the engine a little.
Post  getback Thu Jul 30, 2015 12:11 pm
Good Fun !! man that was a nice 3.5 mins. on a BB tank not bad , good starter too , If you have a 5X3 prop that would sling around alittle faster w/less effort tongue U going to fly it and on what ? Very Happy Eric
Post  TopBannana Thu Jul 30, 2015 1:00 pm
[quote="getback"]Good Fun !! man that was a nice 3.5 mins. on a BB tank not bad , good starter too , If you have a 5X3 prop that would sling around alittle faster w/less effort tongue U going to fly it and on what ? Very Happy Eric [/quote
Thanks, well I made a biplane from that plastic cardboard and once I get my servos and linkages in I'll be able to run it
TopBannana
TopBannana
Post  Sig Skyray Thu Jul 30, 2015 1:18 pm
Nice long run on the small tank. Way to go!
Greg
Sig Skyray
Sig Skyray
Post  TopBannana Fri Jul 31, 2015 9:00 pm
So yesterday I ran my medallion, but I used wooden screws on a 2x4 in the vid, so I figured I would go easy
So I pored something like 5ml to be safe and ran it
It was running smoothly then two of the darn screws came of from the left side
Then I stood to the side, lucky the fuel ran out before it flew off. Everything is fine no damaged engines
So I'm not sure if I could find a stand for it that's compact (as in it won't loosen) for under 15$
Does anyone know were I might be able to find one?
-Trevor
TopBannana
TopBannana
Post  roddie Sat Aug 01, 2015 9:59 am
Hi Trevor, I'm assuming you ran the "1/2" Black Widow" with a stock Babe Bee back-end (tank/back-plate). I believe that all Black Widows had a larger air-intake/venturi than the Babe Bee, because of the higher-performance cylinder-porting. Compare the venturis side by side.. (tanks disassembled..) and you'll see what I mean. No harm in running the engine the way you did.. but you'll see a marked gain in performance if you run a tank/back-plate that's designed for the Black Widow. When adjusting your needle, do it in small increments (1/4 turn at a time) and wait a second or two to see if there's a change in the way the engine runs. Usually an optimal needle setting will be achieved within 1/4-1/2 a turn of the needle.. once it's firing on every stroke.
These are two of my Golden Bee back-ends as an example. The parts on the right show a larger venturi. I believe that this was a "later" version which was succeeded by the Black Widow.
First cox run! Golden10
First cox run! Golden11
Post  akjgardner Sat Aug 01, 2015 4:44 pm
TopBannana wrote:Ive had a cox engine for at least 4 years (not very long) but i never bought the fuel for them in the amount of time.
-Trevor
Im getting ready to restore my 1948 ford 8N as well.maybee we can compare notes and progress pics
Post  TopBannana Sat Aug 01, 2015 10:32 pm
-Trevor
thats cool
TopBannana
TopBannana
