» Tee Dee .020 combat modelby TD ABUSER Today at 3:38 am
by batjac Today at 12:47 am
by roddie Yesterday at 11:50 pm
by rdw777 Yesterday at 7:51 pm
by getback Yesterday at 3:05 pm
by rsv1cox Wed Nov 20, 2024 6:21 pm
by 1975 control line guy Wed Nov 20, 2024 11:17 am
by rsv1cox Tue Nov 19, 2024 9:35 pm
by Cox International Tue Nov 19, 2024 3:01 pm
by getback Tue Nov 19, 2024 9:08 am
by roddie Tue Nov 19, 2024 12:05 am
by rsv1cox Sun Nov 17, 2024 9:40 pm
what engine is this?
I just need to Know what he engine is, i'm fairly sure every thing is original except the firewall mount i think that's after market. Thanks for looking. Oh and the cylinder has 1 bypass port and no booster port.
Balsa to Foam- Moderate Poster
Re: what engine is this?
Hello Balsa to Foam welcome to the forum
You have to wait a little bit to post pics (think it's a week) from your mention of a single bypass cylinder sounds like a babe bee or product engine but without a pic i may be very wrong. Can you describe it for us we can help ya that way.
(Bandit)
(Bandit)
TDbandit- Platinum Member
sorry about that they came up on my computer but i didnt check others. anyway it has a red postage stamp back plate, extruded aluminum crank case with a babe bee style crank shaft with standard, not hex prop drive plate. the reed is original and is a copper-berillium star held in with a wire retaining clip. the needle valve isa lot like the killer bee's but has an extra knob below the tube atatchment point.
hope this helps:)
Oh and the cylinder has teedee exuahst ports
hope this helps:)
Sounds like a product 190 engine. Email me a picture to jsesere@yahoo.com.
Joe
Joe
jsesere- Rest In Peace
Balsa to Foam wrote:sorry about that they came up on my computer but i didnt check others. anyway it has a red postage stamp back plate, extruded aluminum crank case with a babe bee style crank shaft with standard, not hex prop drive plate. the reed is original and is a copper-berillium star held in with a wire retaining clip. the needle valve isa lot like the killer bee's but has an extra knob below the tube atatchment point.
hope this helps:)
Like this?
gcb- Platinum Member
yep it is exactly like that, thanks george
If your engine is as pictured then it was was likely pulled from a Cox RTF. The porting is probably dual and the exhaust cut outs, while like a TD, are just standard Cox.
The engine can be mounted to just about anything if an aftermarket mount is added. Carl Goldberg made a plastic mount for those and better yet we have a forum member here that makes an aluminum mount for that engine.
It's a good engine for what it is and I hope you can mount it on something and enjoy it.
Welcome to the forum!
Here's mine. I always thought it was a 290 Not sure what would be the difference except that the 290 was sold as a separate engine and the 190 was a part of the RTF models.
Hmm, I thought I could copy those pictures BtF tried to post and make them work, but no luck on this end either. Sorry about that, but welcome to CEF,l glad you found us.
Welcome to the forum balsa to foam !! there is a lot of good info here http://www.mh-aerotools.de/airfoils/cox_frameset.htm there are several ways to use that site , but if you scroll down to the bottom look for BACK TO HOME PAGE (highlighted ) and click on it to get to Cox engine or use the data base
» **Black Lynx Engine Giveaway June 2017** Cox Engine of the Month
» **Black Lynx Engine Giveaway June 2019** Cox Engine of the Month
» **Black Lynx Engine Giveaway Jan-June 2022** Cox Engine of the Month
» *Cox Engine of The Month* Submit your pictures! -December 2016- *ENGINE GIVEAWAY*
» *Cox Engine of The Month* Submit your pictures! -December 2014- *ENGINE GIVEAWAY*
