Elevator Warpage ? Cox_ba12
Elevator Warpage ? Pixel
by rsv1cox Today at 8:36 am
by Ken Cook Today at 8:10 am
by Coxfledgling Today at 5:46 am
by Coxfledgling Today at 5:18 am
by roddie Today at 1:32 am
by akjgardner Today at 1:27 am
by roddie Yesterday at 7:17 pm
by TD ABUSER Yesterday at 3:13 pm
by Ken Cook Yesterday at 2:41 pm
by roddie Yesterday at 11:43 am
by roddie Fri Nov 22, 2024 2:13 pm
by rdw777 Fri Nov 22, 2024 10:24 am
Elevator Warpage ? Empty
Elevator Warpage ?
Elevator Warpage ? Empty Elevator Warpage ?
Post  Sig Skyray Sun May 31, 2015 10:20 am
My son's 1/2A elevator has some serious cupping going on. Don't know how it got there. Must have been the hinge glue. Used Testor's brown tube fast dry.
Is this any big deal or how can it be corrected?
Greg
Sig Skyray
Sig Skyray
Elevator Warpage ? Empty Re: Elevator Warpage ?
Post  Ken Cook Sun May 31, 2015 12:30 pm
Is the wood bare or painted? Take a heat gun and bend it back while heating and hold it the opposing direction until it cools. You could also place some Testor's cement on the opposite side. When it dries, it shrinks. It will pull the warp out. This is a very non controlled method however. You could also bend it the opposing direction over a tea kettle with the steam blowing directly on it. Ken
Post  TDbandit Sun May 31, 2015 2:34 pm
*nods* I second what ken said. Smile (Bandit)
TDbandit
TDbandit
Post  Sig Skyray Sun May 31, 2015 4:37 pm
Ken Cook wrote:              Is the wood bare or painted? Take a heat gun and bend it back while heating and hold it the opposing direction until it cools. You could also place some Testor's cement on the opposite side. When it dries, it shrinks. It will pull the warp out. This is a very non controlled method however. You could also bend it the opposing direction over a tea kettle with the steam blowing directly on it. Ken
The wood is bare. Cupped pretty severely. Hey, now photos are working!
Elevator Warpage ? Img_9710
Sig Skyray
Sig Skyray
Post  KariFS Sun May 31, 2015 5:12 pm
Might be easiest just to replace the cupped part?
Post  Ken Cook Sun May 31, 2015 5:45 pm
I have a Dumas Baby Tomahawk that I fly and it's elevator is cupped even worse than that. I see little to no performance loss in it and I still fly it. I had it out today. I've had the plane for nearly 35 years.
Post  roddie Sun May 31, 2015 8:05 pm
If you're concerned about the cupping not levelling out.. or the way it looks.. you could opt to cut-off the hinges flush with the stabilizer's trailing edge.. and trace-out a new elevator replacement. Chances are; you've already got the scrap-balsa needed. It would also be a good opportunity to try using a sewn-hinge technique. Are there cloth/strap-hinges on it now? You might be able to remove them with tweezers and either re-do them.. or level-out the spots where they were, with filler.. then sand-smooth for an alternate hinging method. A sewn hinge is probably an easier "re-hinging" job seeing that the stabilizer is already glued into the tail.
Here's an example of a sewn hinge.. and there are threads (pardon the pun..) on how to sew them, here on the forum.
Elevator Warpage ? Mini-s10
Post  Sig Skyray Mon Jun 01, 2015 8:21 am
Man that is a Cool little speed racer Roddie!
Thanks for the suggestions guys. I like the idea of the threaded hinge. This is my son's Lil' Wizard trainer so not to get too involved with the correction I think I'll mask the stab so it doesn't soak up steam and try steaming the elevator a bit. It's cupped towards the side with the 4 hinge attachments on it, the other side has 2, so it was definitely the glue shrinkage. The stab is even cupped a bit the other way on the 4 hinges side. If it doesn't straighten out I'm sure he'll be okay with it for learning circles.
Thanks again! Greg
Sig Skyray
Sig Skyray
Post  rogermharris Mon Jun 01, 2015 9:13 am
that's a cool little bird there roddie!
rogermharris
rogermharris
