» TEE DEE Having issuesby balogh Today at 7:42 am
by rsv1cox Today at 7:36 am
PT 19, sloppy elevator
I have a PT 19 and the elevator sure seems sloppy. I know they take a beating, but how loose are they normally? And, is there a specific size of rubber bands to be used? Being that I have bashed this one back together by ordering a new engine, etc., is there a specific size prop? Many thanks. Al
althepal88- New Member
Re: PT 19, sloppy elevator
Greetings Al, Welcome to the CEF.
The elevator is supported inside the “tube” created when the vertical stab (tail) is inserted into the fuselage. So, yes that fit can be sloppy. There shouldn’t be a lot of left to right movement, just the rotating up and down of the elevator. If your getting a lot of left/right movement you may have the little cup shaped pieces broken off the tail or rear of the fuse. How is the action when you’ve connected the push rod from the bellcrank to the elevator? It should move up/down quite easily. On mine, with out tension of the string attached to the bellcrank, the elvator does just flop down.
Not sure if there is a recommendation on the rubber bands, small enough to fit the little posts, long enough to go back and forth a couple of times.
If I remember the prop isa 6”. X 3, but let me verify.
Thanks, guys. I just noticed that while I slide the front of the rudder/vert stab in the slot; I neglected to get the rear of the stab in it's slot. Thanks for the info on the prop; it has been a loooong time since I flew one of these.
Actually.. the prop is a 6 x 2 "L/H". If you can't source one.. then try to find a 5 x 3 L/H prop. The idea behind the left-hand propeller, is that it torque-rolls the model in a clockwise way (if looking from the rear). This aids in line-tension.. and was purposely designed into the Flight Trainer. The snap/spring-starter was a left-hand unit as well. Remember that the reed-valve engine will run in either direction equally well.. and without harm. My PT-19 is a late 1980's version.. and was designed with NO outboard wingtip-weight..
The airplane will fly with a 6 x 3 R/H prop.. but I would personally search for a left-hand propeller. If a breeze blows-through, you'll have a little more help keeping the lines tight.
Glad that you figured-out the tail-assy. Regarding rubber-bands.. you can find packages of small ones in the hair-care aisle at most stores. Good luck!
I am wondering about this one here. I do agree with all parties here on the fact it is a 6 x 3 RH propeller, as well as a 6 x 2 LH propeller. I personally wonder if at one time they used a LH rotation propeller then at some poing switched to a RH propeller or vise versa? The instruction/parts book posted by Marleysky does truly indicate 6 x 3 RH propeller, as well the picture even looks like it, but I also remember some that used a 6 x 2 LH propeller as indicated by roddie. If the OP could post a picture of the engine, we could verify which propeller they need *IF* there is a spring starter installed. If no spring starter, either could be used.
So, how about a picture althepal88? We all like pictures.....
I have a black 6/3 left prop, w/spring starter. I got the engine from cox engines, Canada, and had to adapt it to the airplanes firewall. I purchased a new cylinder head that will accommodate a standard size glow plug. (I can only assume a Hot plug). I still need to get some sections of fuel line to go from the built in tank to the engine. Pictures?? Well, as soon as I get one of my grandkids to show me how to do all that stuff, look out. Thanks for all you guys and your help. BTW, anyone have a yellow vertical stab??? Al
Cox PT-19 propellers
Hey Al, I think that "NEW222" (Chancey) is correct about some of the PT-19 models having 6 x 3 right-hand propellers. I think that it's safe to say that the "earlier" generation models had the right-hand propellers. The 1st-generation PT-19 Flight-Trainer was designed to use the Cox .049 Babe Bee engine with its' integral fuel tank.
You've mentioned your model having an external fuel tank.. but also needing to adapt the engine from "Cox International" to your models' firewall. I'm trying to figure out the configuration that you have.
You also ask if anyone has a "yellow" vertical-stab. A yellow "replacement" part would indicate an older model.. but I'm not sure by how much.
Just an "FYI".. The genuine Cox glow-heads are superior to the conversion-heads which use standard-1/4"-32 glow-plugs. Watch the eBay.. for Cox parts-engines which include glow-heads. If all else is junk.. the glow-heads are usually salvageable.. and they're not cheap to buy new.
As "Chancey" mentioned; photos will really help us to figure-out what you have.
Again, without pictures roddie, I am just going on assumption of this being a latter version and presumably that Al had put in an engine with horseshoe backplate. As well, if you take a look at the picture posted earlier, you can see a fuel line in the top center corner, then look that part number up in the bottom left corner, (last number) it does indicate 'fuel line' in the description amongst other things. Part number 5773. I like a good ol' little mystery! We'll get this figured out and help get him back on track one way or another.
I had to put the engine to the horseshoe backing plate that was oem when I got the a/c......the current vert stab is blue; just wanted to get a yellow one to match my friends 30% rc PT-19.
» Gnat rc plane
» P-40 broken elevator; how I fix it
» Elevator Warpage ?
