Product engine question Cox_ba12
Product engine question Pixel
by rdw777 Today at 9:35 am
Product engine question Empty
Product engine question Empty Product engine question
Post  akjgardner Sat Apr 25, 2015 7:02 pm
While trying to spring start a product engine i bought off ebay, It would pop but not start. after several trys (around 30) out of frustration ,I jusrt gave it a quick flip with my finger and to my surprise it started right up. Has anyone ever had this happen.Is there a chance that the spring was fliping it over too fast or was it just dumb luck?
Product engine question Empty Re: Product engine question
Post  TDbandit Sat Apr 25, 2015 7:38 pm
I've had that happen to me a few times. Can happen if the clip is not making a good connection or its primed with too much fuel which causes it to cool the plug off if you kept trying it would of cleared out enough to start if the plug is hot you should hear a strong sizzle coming from the exhaust. The start from your flip maybe from the pause which allowed the plug to heat up and any fuel in the chamber vaporizes so when you flip it, it just busts off. The way I do it it when it gets stubborn is I take hold of the prop and slowly turn the prop over with the clip attached until I feel it bump do it two or three times and try the spring starter again and it should start. (Bandit)
TDbandit
TDbandit
Post  RknRusty Sat Apr 25, 2015 8:22 pm
Lots of times for me, they start more reliably with only a half turn than a full turn on the spring. When I flip Tee Dees, I always back flip from tdc. They usually fire right up. I never assemble a Bee without a spring.
Post  pkrankow Sat Apr 25, 2015 10:07 pm
Yes, frequently.
I also frequently have it the other way around.
Post  Cribbs74 Sat Apr 25, 2015 10:31 pm
It's normal,
Keep in mind it takes a few primes before it will draw from a tank. Just play with it for a while and develop a sequence that works for you.
Post  RknRusty Sat Apr 25, 2015 10:46 pm
Product engine question 160-6010
Hey Ron, I've never seen that Who picture or logo in your avie. Where'd that come from?
Post  Cribbs74 Sat Apr 25, 2015 10:57 pm
That was an exhaustive search through Who logos on the internet.
I tried to load up one of Pete doing a mid-air windmill, but it wouldn't shrink down so I settled on that one.
Long live rock! Be it dead or alive!
Post  RknRusty Sat Apr 25, 2015 11:03 pm
If you send it to me or a link to it, maybe I can fix it for you.
EDIT: Product engine question Pete_s11
Post  pkrankow Sun Apr 26, 2015 6:38 pm
Just checking:
prime by closing the exhaust and hanging a drop in the port, NOT by squirting fuel into the open exhaust.
flip slowly over then flip to start.
If the engine was running well, then isn't, pull the NVA and flush back through, this will
1 flood the engine
2 flush stuff out the intake
clear the flood and it should be back in business.
Post  akjgardner Sun Apr 26, 2015 7:18 pm
I ended up taking the backplate off and soaking it in denatured alcohol overnight.Couldn't believe how much junk came out of it.put it back together and it runs like a charm..thanks for the help
Post  pkrankow Sun Apr 26, 2015 7:30 pm
akjgardner wrote:I ended up taking the backplate off and soaking it in denatured alcohol overnight.Couldn't believe how much junk came out of it.put it back together and it runs like a charm..thanks for the help
I ALWAYS do that unless it comes from someone I know.  Then I probably will do that depending on if it was run in the last couple months or not.
