Green tube Testors Cox_ba12
Green tube Testors Pixel
by Ken Cook Today at 3:23 am
Green tube Testors Empty
Green tube Testors
Green tube Testors Empty Green tube Testors
Post  rsv1cox Wed Jan 21, 2015 7:37 am
Anyone tried this?
http://www.ebay.com/itm/Testors-Cement-Carded-5-8-oz-4505C-/131157944776?pt=Radio_Control_Parts_Accessories&hash=item1e899f69c8
Seems new.  I have the red/blue tubes but have never seen this.  Says bonds plastics, wood, metal, etc. although the blue tube stuff will bond wood to plastic.
Must be good, got the skull and crossbones on the label.  Smile
By the way... other vendors are selling the same thing for $12.95
Green tube Testors Empty Re: Green tube Testors
Post  TDbandit Wed Jan 21, 2015 9:41 am
The green tube cement has been around a while, I've used it before but only on models like guillows rubber models. does pretty good but it takes a while to dry. Don't know how resistant it is to fuel though. (Bandit)
TDbandit
TDbandit
Post  pkrankow Wed Jan 21, 2015 1:46 pm
That is the classic old standby glue. It is comparable and contemporary to Ambroid, but it is thicker.
It is somewhat stinky with a strong solvent smell. It dries fast enough to do field repairs and fly within the hour typically, and is much lighter than epoxy.
Post  rsv1cox Wed Jan 21, 2015 2:24 pm
Thanks, I hadn't seen it before. I thought it might be a better choice to reconstruct some of the nasty bent/broken plastic airplane models that I have recently bought. Hopeless causes for the most part, but I enjoy the work.
The red tube Testors appears to be toxic, the blue tube not so. Almost all of my models prior to the advent of CA's were assembled with Ambroid.
Post  getback Thu Jan 22, 2015 5:33 am
Ambroid. ????on plastic // Ca ?? I think I would go with the TOXIC one , always seems to be the best working glues
Post  RknRusty Thu Jan 22, 2015 6:47 am
I keep it in my flight box for covering exposed balsa to keep fuel out so I can keep flying. I used to use it for applying fabric hinges and always had good dependable results. I built my entire Stuntman23 and Li'l Devil years ago with it, and though the planes are now completely worn out, none of that is due to glue failure. I wouldn't substitute it for epoxy on the firewall and front end areas, because it won't withstand a long term barrage of fuel and oil.
Post  GallopingGhostler Thu Jan 22, 2015 6:57 am
IIRC, the balsa wood type solvent glues (Testors, Ambroid, Sigment, Duco, etc.) didn't seem to do as good of a job on my plastic models as the styrene solvent glues made for plastic did.
Personally I'd stick with a glue specifically made for plastic when gluing plastic together. If something stronger is required, like restoring where a wing was broken off, I'd think the clear version plumber's pipe cement for all plastics (PVC, ABS, etc.) might be a better choice. A small bottle is cheap at the local home improvement center.
You don't need the cleaner and primer, which cost extra. Primer puts a purple film that may be undesireable. I've used Acetone to clean up and etch the edges of plastic.
Whatever glue, I'd first try a test case somewhere unseen or on discarded parts, to see how well it works.
Post  rsv1cox Thu Jan 22, 2015 7:50 am
getback wrote:Ambroid. ????on plastic // Ca ?? I think I would go with the TOXIC one , always seems to be the best working glues
Hi Eric, I used Ambroid on balsa only, I never touched a plastic model airplane until I joined this forum, now it's Katy bar the door.....
I just thought the green tube stuff may be better for joining balsa to plastic like I did on fixing the broken piece of the back fuse on my PT-19 which worked well using only blue tube Testors.
Post  getback Thu Jan 22, 2015 10:36 am
Bob , I haven't used any Testors Glue in a long time there was something about it I didn't like cant recall right off ,Ambroid was my go to glue , I haven't work with plastic much in awhile . You seem to bee doing fine with it . I only have one plastic cox plane and don't know what it is !! Very Happy
Post  GallopingGhostler Thu Jan 22, 2015 12:28 pm
getback wrote:Bob , I haven't used any Testors Glue in a long time there was something about it I didn't like cant recall right off ,Ambroid was my go to glue , I haven't work with plastic much in awhile . You seem to bee doing fine with it . I only have one plastic cox plane and don't know what it is !! Very Happy
Now thinking about it, reason why I didn't use Testors wood glue is that it dried too quickly, didn't make as good of joints as Ambroid and Sigment did. Prior to my experiences with Epoxy, I'd coat both parts, say balsa and ply with glue, let it dry. Then recoat and assemble. Testors glue then didn't do as good of a job. It also didn't do a good job on stick assemblies like Comet kits. I don't know about the current fomula.
Post  Ken Cook Thu Jan 22, 2015 3:26 pm
I prefer the brown tube 3505X Testors cement. It dries faster than the green tube which makes a excellent choice for cloth hinges. It lays down beautifully, has a good shelf life and it doesn't turn amber in color when painted with dope. I do a lot of clear finishing and certain adhesives especially Ambroid really darkens the hinges if used for attachment. The Testors extra fast dry sands beautifully and is very clear. The green tube claims it can be used with metal and wood. Ken
Post  RknRusty Thu Jan 22, 2015 5:30 pm
rsv1cox wrote:... now it's Katy bar the door.....
Haha! I wonder if Ian's ever heard that one. A dab of Testors plastic cement, and Bob's yer uncle.
Post  Oldenginerod Fri Jan 23, 2015 12:53 am
"Bob's yer uncle" I know. Excuse my ignorance on the other. Strange language, English!!
Post  ian1954 Fri Jan 23, 2015 3:41 am
It is American idiom but strictly speaking it means "There may be trouble ahead".
This phrase is little used outside the USA. It may or may not have originated there. The first known use in print of Katy bar the door with the meaning of 'trouble is in store' is in James Whitcomb Riley's poem When Lide Married Him, 1894:
When Lide married him - w'y, she had to jes dee-fy
The whole poppilation! - But she never bat' an eye!
Her parents begged, and threatened - she must give him up - that he
Wuz jes "a common drunkard!" - And he wuz, appearantly.
Swore they'd chase him off the place
Ef he ever showed his face
Long after she'd eloped with him and married him fer shore!
When Lide married him, it wuz "Katy, bar the door!"
ian1954
ian1954
Post  Oldenginerod Fri Jan 23, 2015 4:53 am
Funny, we must browse the same websites. I almost posted that exact quote.
Post  rsv1cox Fri Jan 23, 2015 6:47 am
Smile Smile Yes, Eric, a dab of Testor's is nice but I have always heard that a little Hoppees #9 behind each ear really attracts the ladies....
Post  GallopingGhostler Fri Jan 23, 2015 9:01 am
ian1954 wrote:
RknRusty wrote:Haha! I wonder if Ian's ever heard that one. A dab of Testors plastic cement, and Bob's yer uncle.
Apparently it is used in UK but has a total different meaning: An exclamation used to show a satisfactory outcome..
http://www.britishslang.co.uk/slang/bobs-your-uncle
It's all sixes and sevens to me. Very Happy
