Cox engine collecting (The Bug!) - Page 2 Cox_ba12
Cox engine collecting (The Bug!) - Page 2 Pixel
by rdw777 Today at 3:35 pm
by rdw777 Today at 3:24 pm
by batjac Today at 3:47 am
by roddie Today at 2:50 am
by getback Yesterday at 6:05 pm
by rsv1cox Wed Nov 20, 2024 9:21 pm
by 1975 control line guy Wed Nov 20, 2024 2:17 pm
by rsv1cox Wed Nov 20, 2024 12:35 am
by Cox International Tue Nov 19, 2024 6:01 pm
by getback Tue Nov 19, 2024 12:08 pm
by roddie Tue Nov 19, 2024 3:05 am
by rsv1cox Mon Nov 18, 2024 12:40 am
Cox engine collecting (The Bug!) - Page 2 Empty
Page 2 of 2 Previous  1, 2
Cox engine collecting (The Bug!) - Page 2 Empty Re: Cox engine collecting (The Bug!)
Post  ian1954 Thu Jan 15, 2015 10:53 pm
In the UK, Cox engines were often repackaged. In this example and unusual silencer was included in the box.
Cox engine collecting (The Bug!) - Page 2 Cox_be18
ian1954
ian1954
Post  crankbndr Sun Jan 18, 2015 7:04 pm
ian1954 wrote:This is a petrol TD 049.
Cox engine collecting (The Bug!) - Page 2 Petrol10
I had trouble running this and did many experiments with fuel mix. I found, by accident, that it started very easily on just petrol -95 Ron. So I added 5% castor and ran it a little longer. I was a little unhappy that there wasn't enough lubricant but it wasn't happy with 10% castor and so I did 5% castor and 5% two stroke synthetic (motorcycle two stroke).
It started easily but seemed to have lost get up and go. I added a dash of paraffin (kerosene) and it ran quite happily. Still needs more work, I spent about two hours fiddling and after running I checked the plug. It was sooty and not the coffee colour I had hoped for so it was running rich but I wasn't able to lean the mixture any further.
I had run it on a 6 x 3 propeller.
There is one of these on eBay now, ends soon
http://www.ebay.com/itm/371234145886?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Post  balogh Sun Jan 18, 2015 7:47 pm
..................I had trouble running this and did many experiments with fuel mix. I found, by accident, that it started very easily on just petrol -95 Ron. So I added 5% castor and ran it a little longer. I was a little unhappy that there wasn't enough lubricant but it wasn't happy with 10% castor and so I did 5% castor and 5% two stroke synthetic (motorcycle two stroke).
I wonder how the 10% lubricant works out in a ringless engine, with regards to compression? I guess gas/petrol engines all have piston rings for a reasonable compression that the often 3% or even less lube oil content in 2-stroke petrol fuel alone would not be capable of sealing? 10% oil still seams too thin a sealant for a ringles engine.
Post  ian1954 Mon Jan 19, 2015 11:32 am
You maybe correct but this engine wasn't originally purposed to run on petrol. All I can see from my attempts to run it, it is not a happy bunny with too high an oil content. Also petrol has some lubricating properties itself unlike methanol.
Still in the experimental stage.
ian1954
ian1954
Post  sdjjadk Sat Jan 31, 2015 6:38 am
Hey Ian, would you be willing to trade 1 of each engine for 1 Mother In Law? She cooks, cleans and has a boat. I can send you a pic of the boat if you'd like.
Shawn
sdjjadk
sdjjadk
Post  GallopingGhostler Sat Jan 31, 2015 2:03 pm
ian1954 wrote:Cars prior to 1995 in the UK can suffer from the alcohol content in the bio fuels now sold predominately at supermarkets rotting seals and rubber.
My 1971 Honda CB100 new petcock needs new rubber seals, surprised me that it went bad in a short while. Mad
Post  TDbandit Sat Jan 31, 2015 3:41 pm
None of the bikes even current models like the green gas. My 02 CBR600F4i is currently having seal problems due to the alcohol.
Keep an eye on the carbs btw it eats them up too. (Bandit)
TDbandit
TDbandit
Post  GallopingGhostler Sat Jan 31, 2015 4:29 pm
TDbandit wrote:None of the bikes even current models like the green gas. My 02 CBR600F4i is currently having seal problems due to the alcohol. Keep an eye on the carbs btw it eats them up too. (Bandit)
I heard similar too, Bandit. My 2001 Kawasaki ZG1200 Voyager tourer's 4 carbs use better floats but had a rough idle when I bought it a little over a year ago with 33k miles on it. (Now it has almost 47k miles on it.) I thought I'd have to rebuild the carbs.
On the forums, they mentioned how the newer fuel with alcohol content and without MBTE gums up the carbs over time. I followed advice, now add Seafoam fuel treatment to the tank every couple months, it makes a huge difference. Now the bike idles smoothly, worth the $13 per can.
Post  TDbandit Sat Jan 31, 2015 5:02 pm
Sea Foam the "Anti-coke kit in a can" as I call it. As an A&P, I recommend it to pilots with uncertified light sport and Ultralite aircraft that use Rotax engines. If used regularly, you won't ever have to De-coke it (pull the cylinders and clean the combustion chambers and piston crowns and check the rings/replace if necessary) I pulled the exhaust to do an visual inspection on a Rotax 582 blue head two stroke that was 200 hours past Rotax's recommended 300 hr TBO that used seafoam religiously and it didn't have a spot on the piston, rings were free and the cross hatching on the cylinders looked like it was fresh from the factory  The stuffs magic worth every penny you give for it and it works wonders with carbs and FI. (Bandit)
TDbandit
TDbandit
Post  dinsdale Sun Feb 01, 2015 6:57 am
Marleysky wrote:wOw, I'm almost speechless. That collection must have taken many years to assemble. My wife is a quilter and collects fabric and designs. She had a sign that reads " She who dies with the most fabric wins! "  she IS trying to win, as are you with a collection like that ( substitute Engines for fabric ) I am impressed and in awe that you can't even store it in one place.....or is that for safety reasons so you won't loose the complete collection in one mishap?
My wife's way ahead of yours in that race I'll bet!!
dinsdale
dinsdale
Account Deactivated by Owner
Post  dinsdale Sun Feb 01, 2015 7:08 am
ian1954 wrote:Also petrol has some lubricating properties itself unlike methanol.
I'll try not to make too much of a habit of this, but today seems to be my day for contradiction.
Petrol is an abrasive - no 2 ways about it.  Just one of the reasons why diesels generally last for many more miles.  Diesel fuel is a lubricant.
dinsdale
dinsdale
Post  Marleysky Sun Feb 01, 2015 5:14 pm
My wife's way ahead of yours in that race I'll bet!![/quote]
Hijacked
Well, I certainly don't want to fuel that competition, so I'll agree, yes she has more! My wife has been on a "I'm going to complete every quilt I've started campaign " lately. So she only has to buy fabrics to match or compliment the design she's working on! She claims to be using her "stash" for the majority of the projects.
Post  Scotty68 Tue May 07, 2019 5:43 am
ian1954 wrote:Is it a bug? I think so!
It starts with the simplicity of acquiring a classic vintage engine. Ironically, one of these
Cox engine collecting (The Bug!) - Page 2 More_c10
A Space Bug but more importantly a Cox Bug! This combined with such an informative forum accelerates the illness/addiction and this is fueled by comments, topics and articles constructed in such a way as to prevent cure!
WARNING! Do not continue reading unless you have developed an immunity, have an appropriate anti serum or have the will power to resist.
You acquire an engine and discover that there are different varieties. You see one that is better than the one you have, you find one that needs a little tender loving care ...................... The addiction begins.........
Cox engine collecting (The Bug!) - Page 2 More_c11
It gets out of control. It is reinforced by the smell of fuels, castor oil residues, Hoppes No 9, cleaning fluids. It provides excuses to use blow torches and buy tools that you can't live without! To generally make a smell, a mess and a noise.
Another warning - this is often defines as a hobby but it extends beyond the hobby room. You will spend hours on this forum - enter competitions and as "The Bug" bites deeper it will take over the home. You will create undesirable relationships that will encourage and feed the addiction - it will accelerate to the point where you will be unable to resist.
It has taken several weeks to bring my Cox engines together as I don't keep them at home. The engines have not been stored in a logical manner and mixed with other engines. I still haven't brought them all together as I still have more distributed in storage but this exercise has gone a long way to correct that.
I have also to mention that after seeing Jason's pictures of his engines laid out another side effect of "The Bug" took over and I have wanted to do the same. Jason has increased his collection, a fellow sufferer, and I saw a posting encouraging him to lay out a display again (need I say more!). However, this takes hours!
Excuse my photography. I found it difficult to lay the symptoms of my disease out in a picturesque way and so I just sorted them and dumped them. I don't have a table big enough and so I used the settee (also not big enough).
Another warning! If you are using household furniture for this - make sure that it is easy to clean afterwards! After run oils, fuel residues and oils smell nice but "soft" furnishings don't agree with them!
Cox engine collecting (The Bug!) - Page 2 Engine10
Cox engine collecting (The Bug!) - Page 2 Engine11
Cox engine collecting (The Bug!) - Page 2 Engine12
As much as I would LOVE to hang around here and drool over your beautiful collection of Cox engines, after having looked at it, it is clear that I have ENTIRELY TOO MUCH WORK TO DO!!! Lol!
Thanks for the pics,
Scotty68
Scotty68
Scotty68
Silver Member
Silver Member
Post  Oldenginerod Tue May 07, 2019 5:53 am
Wow Scotty.  You managed to find a really old post here.  Haven't heard from Ian for ages.
Post  Scotty68 Tue May 07, 2019 6:17 am
Oldenginerod wrote:Wow Scotty.  You managed to find a really old post here.  Haven't heard from Ian for ages.
Yeah it goes back a ways. But it matters not! It is still a beautiful collection. And I thought I was doing well with around a hundred total and a couple of dozen displayed in a shadow box. I am so embarrassed. : )
Scotty68
Scotty68
Scotty68
Silver Member
Silver Member
