» My N-1R build logby GallopingGhostler Today at 4:04 pm
by 1/2A Nut Today at 3:43 pm
by roddie Today at 2:13 pm
by sosam117 Today at 12:32 pm
by rdw777 Today at 10:24 am
by batjac Yesterday at 10:47 pm
by rsv1cox Wed Nov 20, 2024 4:21 pm
by 1975 control line guy Wed Nov 20, 2024 9:17 am
by rsv1cox Tue Nov 19, 2024 7:35 pm
by Cox International Tue Nov 19, 2024 1:01 pm
by getback Tue Nov 19, 2024 7:08 am
by roddie Mon Nov 18, 2024 10:05 pm
My second RR-1 aka RR-051
I really want to find a used silver/blue RR-1... maybe someday...
Anyway, I bought a second RR-1 last week on eBay and I'm not quite sure what to do with it.... I bought it for $75, but it has some issues...
The head, cylinder, piston and backplate are wrong. Since it has a newer backplate, the venturi had been modified. It's not a show piece by any means, but it has the presence, so to speak.
My questions are...
• Find the correct parts?
• Run it as modified?
• What cylinder should I put on it?
• Make it a hybrid, put a newer, venom type cylinder/piston and see what I get?
What are your thoughts?
My questions are...
Re: My second RR-1 aka RR-051
I'm actually getting excited about the hybrid.... just thinking about it
Put one of Bernie's TD cylinders on it, screaming fast. Go with a Nelson head and let's see what it will do!
JPvelo- Diamond Member
First thing that occurred to me was to build a "period hot-rod" out of it. That is, if it were mine Ditch the muffler and starter spring obviously, and find a genuine early-sixties TeeDee head, piston and cylinder.
I am thinking of re-creating something that an amateur competitor / hot rodder might have created 50 years ago. Then of course a period-style plane to go with it.
Just an idea
Just an idea
Hmmm... that's a very good idea as well. I defiantly ditched the muffler and starter spring. I'll have to look to see what cylinder was on it, it defiantly was done a while back.
Ok... I need some schooling, what does a early Tee Dee cylinder look like?
The Early Tee Dee cylinder were a thin wall, dual port design, they also used a hi-comp head. I'm not sure what the first versions had, if any for a stamp. I know later ones had a #4, I'll check later tonite when i'm home.
The RR-1 were a dual port but did not have a stamp, later ones did have the "1" like the Space Hopper and used a standard head.
Is this what you mean
This is a used rr1 blue and silver off ebay:
Type Cox RR1 .049 in ebay and it should come up
TopBannana- Gold Member
ok
WingingIt74 wrote:too much for my blood....
Mark is that the one with a lighter piston and oiler hole in the conn. rod ? Eric
I think the backplate is from the late 60s or early 70s... what are my options for that time period? I'll have to post a pic tonight.
My next question is, does anyone have a spare laying around? I may have one, but it's a whole engine.
It will be fun to see if any mods actually make it turn faster. I'll have to run it head-to-head with my stock RR-1.
Unless somebody drilled out a early stunt tank backplate its probably original. The ventless backplate first appeared in '58 with intro of Golden Bee. I've got a early RR-1 ventless backplate that has the clear plating on it.
Well... how about they modified the venturi to fit a newer backplate????
They did a pretty good job... made me cringe when I took the backplate off though....
Here is the modified tank. I also enlarged the intake hole to be the same size as on a Black Widow.
Here it is assembled with a #1 step cylinder and a high compression head.
Looks a lot better!
The backplates used on RR-1 are basically drilled out (don't remember, but it was a common size) to fit the intake tube, see above photos. However it looks like the tank may have been buggered up to fit the newer backplate. I wouldn't feel bad running this guy, it would be fun to see what it does. But if you ever wanted to restore it of sorts, you could try a blue felt tip pin on the tank and shoot it with some semigloss clear, it wouldn't be fuel proof but would look good.
I found a TD051 piston/cylinder set on eBay.... so it will be soon the RR-051
