» My N-1R build logby rsv1cox Today at 7:02 pm
» Does anyone know what this contraption is???
by davidll1984 Today at 6:14 pm
» Cox extra 300s
by akjgardner Today at 5:29 pm
» Cox Corsair - No guts no glory
by 049kid Today at 4:38 pm
» COX .020 POWERED SPEEDSTER
by TD ABUSER Today at 1:56 pm
» Sunday Morning Comin' Down
by roddie Today at 1:21 pm
» It's a "Flash-Back Friday"
by Kim Fri Oct 25, 2024 1:02 pm
by Jerry Fri Oct 25, 2024 10:13 am
» The Wood Shovel
by rsv1cox Thu Oct 24, 2024 3:01 pm
» Cox Icon RC TRansmitter and servo
by Cox International Thu Oct 24, 2024 11:55 am
by LooseSpinner99 Thu Oct 24, 2024 8:42 am
» Cox p39 Airacobra
by 1975 control line guy Wed Oct 23, 2024 1:17 pm
cox plastic fuel tank
I have this gas tank and the nipple is broken off were you would put the tubing to the engine.Its a clean BREAK and whas thinking of using aplastic tube to put back on with either plumbing pvc cement or five minute epoxy.I thought maybe the pvc cement because its very strong on house pipes but may melt the tank to much.could someone give me some ideas I alredy have those two cements thats why Im mentioning them.thanks craig
craig bernard- Gold Member
Re: cox plastic fuel tank
craig bernard wrote:I have this gas tank and the nipple is broken off were you would put the tubing to the engine.Its a clean BREAK and whas thinking of using aplastic tube to put back on with either plumbing pvc cement or five minute epoxy.I thought maybe the pvc cement because its very strong on house pipes but may melt the tank to much.could someone give me some ideas I alredy have those two cements thats why Im mentioning them.thanks craig
Is the tank removable Craig? (like the snap-in one's on the later-model PT19's were) If so.. and if you have a small "Perfect" style lead-out guide, you could remove the tank and drill-out the existing hole with a 3/32" drill and install the guide from the inside and use a piece of small silicone fuel line snugged-up tightly to hold it in place. It may drip a little.. but it's not going to break off.
Its a small tank from my skycopter
Small to say the least!craig bernard wrote:Its a small tank from my skycopter
Oh wait, here's one.
I picked up a Skycopter rotor assembly a while back for the .020 engine.
You need, I don't, it's yours.
PM your address. That's the best fix I could come up with.
dckrsn- Diamond Member
Thanks Bob dickerson fixed me up with an undamaged tank but people could throw ideas out for future fixes. craig
That's great! Was gonna say clean well and used plastic cement to glue nipple, make sure glue is slightly softening plastic, stick a piece of music wire or equivalent thru nipple and press nipple onto tank together, after glue is dried pull out wire, nipple is centered and fuel hole isn't plugged.
craig bernard wrote:Thanks Bob dickerson fixed me up with an undamaged tank but people could throw ideas out for future fixes. craig
I did this on another plane for a friend of mine... You might be able to do something similar.
» OK Cub plastic tank
» Plastic tank Repair
» Plastic tank issues
» sealing leaky plastic tank?
» Cox fuel tank
» Cox fuel tank
