Cleaning old Cox .049ers Cox_ba12
Cleaning old Cox .049ers Pixel
Cleaning old Cox .049ers Empty
Cleaning old Cox .049ers Empty Cleaning old Cox .049ers
Post  ShugEmery Mon Apr 07, 2014 5:37 pm
Hey there Cox aficionados.....getting back into the hobby after a 19 year pause and have come across many of my old .049s.
Got many up and running even using old fuel. Wow! Love hearing that sound and smelling that smell.
My query is this......what are you folks using and doing to clean up the old engines? Is there a certain grease-off or magic potion to get them ready for the Cox Ball?
Any intel would be much appreciated.
I'll post some pix of them and even a video after my 7 day new-boy break-in period.
Thankee.
Shug
ShugEmery
ShugEmery
Moderate Poster
Moderate Poster
Cleaning old Cox .049ers Empty Re: Cleaning old Cox .049ers
Post  Admin Mon Apr 07, 2014 6:39 pm
Welcome to the forum! If you're mainly after a general cleaning to get them running well, soaking the parts overnight in fuel or Isopropyl alcohol should help loosen the gummy castor. If you are looking for a deeper cleaning, Hoppes #9 gun cleaner should help remove the more baked on castor oil residue. Others have also used brake fluid however the parts shouldn't be soaked more than a few hours. If you want to make them look like new, polishing the parts with Mothers Mag & Aluminum Polish and refinishing with fine sandpaper or a sctochbrite pad will give them that machined look.
There's guys on here who will go into much greater detail.
By the way, have you been up to Hub Hobby lately (I see you're in the local area).
Post  iamplanecrazy2 Mon Apr 07, 2014 7:35 pm
You mean in detail like this?
First off avoid rotating the crank at at any time during disassembly because it
is likely that there is dirt or debris inside the engine and you don't want it to damage
anything, especially the piston and cylinder.
To get started, fold up a rag so it is several layers thick and cover the engines case
with it so the engine can be LIGHTLY clamped (cradled is a better word) in a vise without getting scratched up.
Situate the engine in the vise in such a way that wrenches can be put on the cylinder
and the glow head. [at this time try to loosen the glow head. If it loosens remove it,
if it is stuck go to next step.]
Now it is time to heat the engine. I like using a propane torch but
a heat gun works too, it just takes longer. Take care not to set your rag on fire! Get the
engine pretty hot, to the point you can't touch it for more than a second. Heating is
something you kind of have to get used to doing.
Quickly, before the engine cools to much, put a wrench on the glow head and break it
loose. If the glow head breaks loose from the cylinder then quickly go ahead and put a
wrench on the cylinder and break it loose from the case. If the cylinder broke loose along
with the glow head then just quickly move on to the next step. Move fast so the engine
does not cool off.
With the engine still wrapped in the rag take it out of the vise and and break loose the
fuel tank screws. If it is a Tee Dee or Medallion then rotate the engine in the vise [be
sure to keep the rag in place and only snug the vise up] so you can put a wrench on the
rear cover and break it loose.
Now go ahead and remove the fuel tank or rear cover. If the cylinder broke loose with
the glow head wait until it is warm to the touch and with a cylinder exhaust slot wrench
and a glow head wrench the head should now loosen up without any trouble. [I heavily
edited this paragraph, read on to see why]
Now put a 5-40 screw in the end of the crank until it bottoms out. Stand the case up on
a piece of hard wood on a solid surface. Hit the screw head with a small hammer and
drive the crank shaft off of the prop driver. It should only take a few fairly light blows
to get it off. The engine is now completely disassembled and ready to clean.
I like using 90% or better isopropyl alcohol (rubbing alcohol) for cleaning parts.
A 10 to 15 minute soak followed up by a good going over with a stiff bristle brush
usually gets off most all residue. An assortment of brushes is essential to a good
cleaning. Be aware that the alcohol can alter the color of delrin parts, gives them
a whitish faded look. For really baked on residue I'll use Dawn Power Disolver. It
is a cleaner available at most grocery stores in the household cleaner section. Don't
soak parts it it for longer than an hour or so. It can ruin the finish on aluminum parts.
If any dirt or residue remains after soaking and brushing I may try another round.
If it comes out clean with just a few stubborn spots I will pick what remains off very
carefully with a pin. I use a T-pin, cut off the "t" and clamp it in a finger drill or pin
vise as some call them. Takes a bit of care and practice to  do it without causing scratches.
With this method I can disassemble and clean every part of the nastiest, grimmest, Babe Bee
you've ever seen in 30 - 40 minutes.
Last edited by iamplanecrazy2 on Tue Apr 08, 2014 10:54 am; edited 2 times in total
iamplanecrazy2
iamplanecrazy2
Silver Member
Silver Member
Post  Cribbs74 Mon Apr 07, 2014 8:51 pm
I agree with everything above with the exception of heating the glow head to remove it.
Aluminum and iron expand at different rates so heating the head may cause it to bind as it will have expanded more/faster than the iron cylinder. I believe the Cox manual tells you never remove a head while the engine is hot as it will cause damage.
If anything I would heat the cylinder and then try and remove the head. Enough heat should have transfered from the cylinder to release the castor bond.
Just my thoughts and I surely don't want to contradict or offend anyone.
Post  Jason_WI Mon Apr 07, 2014 10:31 pm
I just use a heavy leather glove to hold the engine while heating with either a monokote heat gun or on the stubborn ones heat using a butane mini torch. Never clamp in the vice unless you like squashed crankcases. I have a few engines I got in engine lots that were junk because of being clamped in a vice.
Jason_WI
Jason_WI
Post  ShugEmery Mon Apr 07, 2014 11:02 pm
Thanks for all the info fellers.....appreciated.
I really was talking about cleaning up the outside of the engine. Got the insides loosened with a heat gun. Went with the isopropyl alcohol dip and a stiff brush. Thanks.
They look a lot better. Now.....what am I gonna put them on. That is the fun part.
ShugEmery
ShugEmery
Moderate Poster
Moderate Poster
Post  ShugEmery Mon Apr 07, 2014 11:05 pm
Admin wrote:Welcome to the forum! If you're mainly after a general cleaning to get them running well, soaking the parts overnight in fuel or Isopropyl alcohol should help loosen the gummy castor. If you are looking for a deeper cleaning, Hoppes #9 gun cleaner should help remove the more baked on castor oil residue. Others have also used brake fluid however the parts shouldn't be soaked more than a few hours. If you want to make them look like new, polishing the parts with Mothers Mag & Aluminum Polish and refinishing with fine sandpaper or a sctochbrite pad will give them that machined look.
Yessir....always Christmas shop at Hub and lately have been up there buying new bits and bobs as I am getting pulled back into the hobby. Some electric park flyers. Bought a P-51 Park Zone plane a few weeks ago and some control line stuff. Love R/C and Control Line,
See you up there.
ShugEmery
ShugEmery
Moderate Poster
Moderate Poster
Post  ShugEmery Mon Apr 07, 2014 11:06 pm
Whooooo Buddy....amazing in depth answer. Thankee.
iamplanecrazy2 wrote:You mean in detail like this?
with it so the engine can be LIGHTLY clamped in a vise without getting scratched up.
and the glow head.
does not cool off.
fuel tank screws. If it is a Tee Dee or Medallion then rotate the engine in the vise so you
can put a wrench on the rear cover and break it loose.
the glow head put a cylinder slot wrench in the vise and slide the cylinder onto it. It will
likely have cooled to much by now so heat the glow head up with the torch and remove
it from the cylinder. If the glow head won't break loose from the cylinder fairly easily
then heat again. Be especially careful with thin wall cylinders. Sometimes the head and
cylinder can be pretty stubborn coming apart. Stuck parts are something else that requires
some trial and error to master.
ShugEmery
ShugEmery
Moderate Poster
Moderate Poster
Post  Cribbs74 Mon Apr 07, 2014 11:07 pm
Shug,
There is a lot of info on this subject buried within the forum. Do a search when you have some time. There are a few on here that do remarkable restorations.
I like to clean mine then get them really dirty  Very Happy
Post  ShugEmery Mon Apr 07, 2014 11:11 pm
Cribbs74 wrote:Shug,
So I shall. Search on))))))
ShugEmery
ShugEmery
Moderate Poster
Moderate Poster
Post  iamplanecrazy2 Tue Apr 08, 2014 10:41 am
Oh come on now!  I all capt LIGHTLY and even said to wrap the engine in a rag before putting it in a vise!  lol!
I know there are some people out there that will still turn the handle until the case is distorted but
here is how I put the engine in a vise, the jaws are snugged up just enough to cradle the engine nicely.
It keeps me from having to wear a glove and saves my slightly arthritic hands some discomfort.
Cleaning old Cox .049ers 13717665494_dcd2530f3b
Ron! I had an epiphany moment reading your response about heating the head.
Looking back I know the vast majority of the time when I would heat the engine
and try to loosen the glow head it invariably took the cylinder with it. Many times
I have said to myself, "why do people have to put those heads on so damn tight?"
All the while I think it was just the heat binding that head up in the cylinder. Wow!
I don't always eat crow.
But when I do,
I eat a very large portion.
 DAMMIT!  I'm gonna go out to the shop, lay my finger on the work bench, and hit it with a hammer.
No, seriously what I actually did was went out the the shop and experimented with glow head removal.
I had plenty of gummed up engines to work with.
Cleaning old Cox .049ers 13717285685_6d8c4333b5
Experimentation did prove that it is definitely true that the heat can bind the head up in the cylinder.
It also taught me that the first thing to do is try to loosen the glow head without any heat. I did that
to every engine in that jar and all but a dozen loosened up easily.
So I had 12 engines with glow heads that were stuck tight to experiment with. I heated them up one at
a time and tried to loosen the glow head. All of them remained stuck to the cylinder and the cylinder
loosened from the case. So I went ahead and removed the cylinders from the engine.
I put one of the cylinders on an exhaust slot wrench (noticing it was still warm), put a wrench on the
glow head and it loosened right up. The other 11 glow heads also loosened right up with some variation
in the amount of torque required to break them loose. Probably because some of the heads were initially
torqued down harder that others.
I then snugged the heads back down and one at a time I heated them up and tried to remove the head
when it was hot. Each one was stuck too tight to get off. After waiting for one to cool down to the point
that it just felt warm, the head would loosen right up.
Conclusion, to get a stuck glow head loose from the cylinder heat it up good and hot then let cool until
just warm to the touch and it should loosen right up.
iamplanecrazy2
iamplanecrazy2
Silver Member
Silver Member
Cleaning old Cox .049ers Empty Re: Cleaning old Cox .049'rs
Post  VUgearhead Tue Apr 08, 2014 11:14 am
Correct me if I'm wrong, but didn't the Cox user's manual say to squirt some glo fuel over the head before removing it?
I would think that little bit of advice would be to contract the glow head, relative to the still hot cylinder. This would serve to help loosen the threaded connection.
Added: MAN! I want a cookie jar like that!
VUgearhead
VUgearhead
Post  roddie Tue Apr 08, 2014 11:28 am
 lol! I was thinking the same thing!!  Damn!    I saw that photo and had a "kid in a candy shop" moment!
Post  iamplanecrazy2 Tue Apr 08, 2014 1:14 pm
Ha Ha! I stole that idea from my buddy Steve Bennett. He filled an old penny gum ball machine up
with a mix of 1/2a engines like Cox, Wen Mac, Atwood, Anderson ect. Its really a neat idea but I
didn't have a gum ball machine so used the jar. A gallon pickle jar would be cool too.
My stash is a result of years of snatching up every bargain (some not) priced Cox engine I could
lay my hands on.
iamplanecrazy2
iamplanecrazy2
Silver Member
Silver Member
Post  RknRusty Tue Apr 08, 2014 1:30 pm
VUgearhead wrote:Correct me if I'm wrong, but didn't the Cox user's manual say to squirt some glo fuel over the head before removing it?
Yes, but that would be referring to an engine that hadn't been sitting and congealing for a long time. To cool it immediately after a run if you want to remove it to adjust your shims or some such reason.
Post  ShugEmery Sat Apr 12, 2014 9:26 am
Here are some pictures and videos of my old resurrected Cox engines. They shall fly again))))))
Took the muffler off the Black Widow and put it on the QZ.
Shug
Cleaning old Cox .049ers 13468572705_7bf62d77c0
Cleaning old Cox .049ers 13468671503_5882a05733
ShugEmery
ShugEmery
Moderate Poster
Moderate Poster
Post  SuperDave Sat Apr 12, 2014 11:02 am
"Engine cleaning" has been covered MANY times in the "search" function.
Check there for lots of good answers.
(Most importantly DON"T use common pilers and screwdrivers but only Cox tools designed to suit the intended purpose.)
Why permanently damage a perfectly good engine by poor use of tools?
SD
SuperDave
SuperDave
Post  ShugEmery Sun Apr 20, 2014 9:22 am
SuperDave wrote:"Engine cleaning" has been covered MANY times in the "search" function.
SD
Got the old tools. These engines will fly again soon.........
ShugEmery
ShugEmery
Moderate Poster
Moderate Poster
Post  SuperDave Sun Apr 20, 2014 10:26 am
That's the spirt we like to see Shug!
Be patient and seek advice when needed.
SD
SuperDave
SuperDave
