» Retail price mark-up.. how much is enough?by roddie Today at 13:10
by getback Today at 12:52
by 1/2A Nut Today at 12:51
by roddie Today at 11:43
by rsv1cox Today at 8:35
by GallopingGhostler Yesterday at 16:04
by roddie Yesterday at 14:13
by sosam117 Yesterday at 12:32
by rdw777 Yesterday at 10:24
by rsv1cox Wed 20 Nov 2024 - 16:21
by 1975 control line guy Wed 20 Nov 2024 - 9:17
by rsv1cox Tue 19 Nov 2024 - 19:35
after run cleaning?
after run cleaning?
Hi Guy's what methods do you use for cleaning your models after running them?
so far I been spraying rubbing alcohol swabbing with a brush and wiping the rest clean with a rag ....well that's for cox cars but still would like see how you guy's remove the oily mess.
reptile- Gold Member
Re: after run cleaning?
run electrics?
Windex or like window cleaner, used to add rubbing alcohol to it, but it didn't seem to help much.
Pure sulfuric acid abd a belt sander...NOT! Windex like Mark said works great.
jsesere- Rest In Peace
I use denatured alcohol soaked liberally on a soft T-shirt rag. For hard to reach areas like around the engine and behind the tank I wrap the rag around a pointed bamboo skewer. It still looks filmy after it dries, so that's when I dry wipe it. I like to use the inside of sweatsuit material for that. I've used Windex too but it still leaves it looking filmy so I dry wipe it. If there's dirt or goo in the nooks and crannies on the engine, I'll cover the venturi and carefully hit it with brake parts cleaner. If I do that I quickly oil the driveplate and finish with after run oil down the venturi. On Tee Dees, I remove the venturi and NVA and blow BP cleaner through the sprinkler holes. If I get really industrious I'll remove the needle(counting the turns) and blow out the NV, but I usually just leave it alone so the needle stays set for cranking. Us bladder users generally never change the needle setting between outings, so it cranks on the first flip next time out.
Dry rag. Sometimes windex if they are getting bad.
I'll second the dry rag. I fly enough that it's a waste of time to make them look really pretty. I do it more to protect the decals than anything else.
» Bore cleaning .049's
» Cleaning old Cox .049ers
» RTF models
» cleaning up a old glowhead
» RTF models
