Question about lines
I,m building a Banshee and am down to getting my lines tied.My question is with Sig line kits do I still have to measure them from end to end,or can I measure back from the ends to make my terminations.
[/url]
[/url]
deanthree5- Moderate Poster
Re: Question about lines
I don't quite understand your question. If I may add some advice. I'm assuming you have the Sig lines and both ends need to be terminated. This plane only requires .015's. One thing I found with Sig lines is to always pay careful attention to the terminations prior to flying. I've had many break and fray right at the termination. To avoid this, I chamfer the aluminum crush sleeves using a #11 blade. I then properly do the termination and use the proper swaging tool for the crimp. Don't use wire cutters or regular pliers for that matter. You will receive a lot more durability from the lines if you provide heat shrink tubing over the crush sleeve and back onto the wire. Heat shrink tubing about 1 1/4" long is more than sufficient.
For the Banshee, depending on your engine choice a .35 engine would require the line sets to be 60' center of your handle to center of plane. If your using a larger engine like a .40-.46, 63' would be a better starting choice. Most importantly, your plane looks terrific. Ken
The Sig lines as you know are on a spool, my question is do I have to unwind them to tie them at 60' ? I,m sorry but lots of info on how to terminate but not much for if you must cut them to length or not.
I've only done one set of sig lines, 52s, and they were dead even in length. I would still unspool them to be sure though, mine may have been the anomaly.
JPvelo- Diamond Member
Yes, they need to be unspooled and measured individually. I usually terminate two ends and then jam a metal rod through the eyelets and into the ground. I slip the loop of my 100' tape measure over the rod and run it and the lines all the way out.
After that it's just a matter of terminating the lines at whatever length you require. The line kits are usually not equal length or the right length out of the package.
Edit: Nice Banshee!
Edit: Nice Banshee!
Nice looking Banshee, they're a great plane, but in case you forgot don't forget to bob the nose.
Thanks guys I thought that I would still have to measure them.I didn't shorten the nose...but with my Fox it balanced at 1/4 inch ahead of spar.I usually research before I build, but not this time.
» Running Lines
» Weighted lines
» Control lines
» Ebay Ringmaster Resto (finishing pics!)
» CHECK YOUR LINES!
» Weighted lines
» Control lines
» CHECK YOUR LINES!
