"Fancherized" Twister build - Page 2 Cox_ba12
"Fancherized" Twister build - Page 2 Pixel
"Fancherized" Twister build - Page 2 Empty
Page 2 of 5 Previous  1, 2, 3, 4, 5  Next
"Fancherized" Twister build - Page 2 Empty Re: "Fancherized" Twister build
Post  fredvon4 Sat Feb 01, 2014 3:09 pm
Ron you go to enough swap meets....used mufflers are almost always freeeeeee... get a box full
match the mount tabs
Cut the muffler off the straight extension
JB the open end closed
Add a series of holes to the end near the JB closed plate Ken will surly post photos of his, number of holes, and diameter
can be very good looking and extremely inexpensive tongue muffler
Post  JPvelo Mon Feb 03, 2014 1:07 pm
The build is coming along nicely. Spoke with some local guys in the club over the weekend who fly advanced and expert stunt who agreed the LA .46 is perfect for a twister at this altitude and climate. Too late to move the wing forward but I have extended the tail by 3 inches:
"Fancherized" Twister build - Page 2 6YvzS4N
Took 4 days wetting and bracing to de-warp the initial wing build, but the basswood leading edge is installed and the basswood trailing edge is taped and drying as I type this. There's the tiniest warp left in the wing that I am sure I can take out when I cover it.
Rusty wanted me to detail the installation of the brass engine mount inserts. I ran into two problems:
1. The softness of the sig supplied plywood.
2. Lack of a proper tool.
The holes for the inserts are drilled with a 11/64 bit. The largest bit my dremel drill press will hold is 1/8 so I drilled my pilot holes with the press and followed through with a hand drill. Came out fine.  I then screwed a 1/4 inch long 4-40 Allen bolt into 4-40 nut and bottomed it. That is screwed into the insert and the whole shebang is then screwed into the pilot hole. I dabbed epoxy into all four holes and attempted to install with a long Dubro bohndus head driver. The insert wanted to cross thread and chewed up the lite ply. That's the bottom left hole. I abandoned that one and moved to the bottom right, with the insert mounted in a hand drill for more tourqe. Worked great but went deeper than I wanted, but no damage to the wood. The top two I was able to do with the Dubro driver. Once the insert is in hold the Allen with the driver and back the nut off with a wrench to loosen the bolt.
"Fancherized" Twister build - Page 2 3lNEjVi
Next time I do this I will make an installation tool by cutting off a Allen wrench and epoxying it into 1 inch dowel handle so the Allen part is much shorter. My next step is to fill in the damaged wood with epoxy mixed with teak wood sawdust I saved from refinishing my girlfriends patio furniture. Will probably laminate 1/32 ply over that for a secure mounting surface.
JPvelo
JPvelo
Post  RknRusty Mon Feb 03, 2014 3:03 pm
Thanks for the tips on the inserts. Boy, nothing is ever as easy as it looks, is it. I will definitely practice on scrap first.
Post  OVERLORD Mon Feb 03, 2014 3:14 pm
Why don't you use studs? By that I mean inserting a bolt from the other side and epoxied in place. The engine will be held by something solid that is secured into the fuse. Also, you can drill smaller holes and there is no wood butchering.
"Fancherized" Twister build - Page 2 Imgp3310
Post  RknRusty Mon Feb 03, 2014 4:54 pm
OVERLORD wrote:Why don't you use studs? By that I mean inserting a bolt from the other side and epoxied in place. The engine will be held by something solid that is secured into the fuse. Also, you can drill smaller holes and there is no wood butchering.
That is a good idea. I wonder if carriage bolts come in that size. The square shoulder would be added prevention against turning the bolt.
Post  Cribbs74 Mon Feb 03, 2014 5:19 pm
Thanks for the rundown Jim. Looks like a chore. I plan on placing a nacelle on the outboard side of the fuse. Like you, I don't want the bolts to slip.
I have seen that happen and you pretty much have to destroy the front end to gain access.
Post  GUS THE I.A. Mon Feb 03, 2014 5:42 pm
In the Old Days, when the engine bolts were turned up to perform as studs, the slotted heads were aligned, and a wire was soldered through them, to prevent the bolts from turning. Look on some of the old Sterling plans; it shows them arranged as such.
GUS THE I.A.
GUS THE I.A.
Post  JPvelo Mon Feb 03, 2014 6:02 pm
Cribbs74 wrote:Thanks for the rundown Jim. Looks like a chore. I plan on placing a nacelle on the outboard side of the fuse. Like you, I don't want the bolts to slip.
I will use these again. I like that there are plenty of threads for the bolts to engage before they are  even close to the inboard side.
JPvelo
JPvelo
Post  JPvelo Wed Feb 05, 2014 10:15 am
Cleaned up the engine mount holes last nite.
Area masked and threaded inserts plugged with beeswax:
"Fancherized" Twister build - Page 2 Ytbr9OK
Applied epoxy mixed with hardwood dust:
"Fancherized" Twister build - Page 2 MxFFELH
Sanded the whole thing flush and opened the bolt holes:
"Fancherized" Twister build - Page 2 QwrG9Vq
I will laminate 1/32 or 1/16 ply later today.
JPvelo
JPvelo
Post  JPvelo Wed Feb 05, 2014 4:39 pm
I installed 4/40 blind nuts for a sliding tank tray:
"Fancherized" Twister build - Page 2 7dd3JiV
Cheek block is cut and the fuse is now drying in my custom laminating jig:
"Fancherized" Twister build - Page 2 DxLGat8
JPvelo
JPvelo
Post  Mark Boesen Wed Feb 05, 2014 7:31 pm
If this is your first tank set-up doing this, you'll love it! Slicker then snot!!!!
There is a little 'art' to installing the brass inserts, once you've got it you'll use them all the time. You can see the benefits of using aircraft ply on the engine side instead of the liteply.
Post  JPvelo Fri Feb 07, 2014 1:09 pm
Starting to look like an airplane:
"Fancherized" Twister build - Page 2 Hkgu6Sz
"Fancherized" Twister build - Page 2 V0f1GRW
I ended up cutting new flaps from 3/16 hard balsa. I had enough left over to cut a new horizontal stab/elevators. I stretched the stab 3 inches to make a 21 inch span. Tha old stabilizer will make a perfect wing for a tee dee powered speed plane!
JPvelo
JPvelo
Post  Cribbs74 Fri Feb 07, 2014 1:11 pm
Sharp Jim, very sharp. I love the lines. What are you doing for tips?
Post  JPvelo Fri Feb 07, 2014 2:54 pm
Thank Ron,
Tips are on there. The twister comes with 1/8 ply flat plate tips. I sandwiched 1/2 inch balsa between the tip rib and the ply rib. I have brodak adjustable leadouts inboard and my cigar tube weight box outboard.
JPvelo
JPvelo
Post  Cribbs74 Fri Feb 07, 2014 3:05 pm
I see Jim, I mean't are you going to extend the tips? I am doing 3" carved balsa block tips on mine. I am unsure wether or not to use the stock ply tips sandwiched in between. I suppose it would be something sturdy to adhere the adjustable leadout guide to. Thinner ply might help save some weight though.
Post  JPvelo Fri Feb 07, 2014 3:48 pm
Ron,
Going with the stock wingspan plus the 1/2 inch tip blocks. I live in a 700 square foot guest house and storage space is a consideration. As it is I am going be hanging the Akromaster and the Twister from the ceiling of my porch.
JPvelo
JPvelo
Post  JPvelo Mon Feb 17, 2014 10:57 pm
Finnaly found some time to work on this one today.
Got the rest of the tail feathers cut out:
"Fancherized" Twister build - Page 2 SJjsK94
Also made fillets where the doublers meet the fuselage and installed a 4/40 blind nut in he back to hang ballast from if necessary.
Control surfaces spackled, polycryliced,and spackled again:
"Fancherized" Twister build - Page 2 EXaknsd
Mocked up the control surfaces with robart pin hinges and they seem to have a lot of friction, hopefully a solution will come to me.
JPvelo
JPvelo
Post  Cribbs74 Tue Feb 18, 2014 12:13 am
Friction eh? Weird. Did some glue seep into the hinge?
Looks great Jim.
Post  JPvelo Tue Feb 18, 2014 7:03 am
It was a dry mock up so no glue. The hinges seem to have a certain amount of built in resistance.
JPvelo
JPvelo
Post  JPvelo Wed Feb 26, 2014 5:06 pm
Doing detail work on the fuse and control surfaces. Two coats polycrylic, silkspan, three coats poly/cornstarch so far. Shooting for five poly/starch coats. Sanding... Sanding... Sanding...
"Fancherized" Twister build - Page 2 L3MgjNN
JPvelo
JPvelo
Post  Cribbs74 Wed Feb 26, 2014 5:14 pm
Looks like all that hard work is paying off! Good work Jim.
Post  JPvelo Wed Feb 26, 2014 5:24 pm
Hey Ron,
Happy Birthday, aren't you old enough to stop playing with those toy airplanes yet?
JPvelo
JPvelo
Post  Cribbs74 Wed Feb 26, 2014 5:28 pm
Thanks, not yet. I think 46 is the magic number... Very Happy
Post  Cribbs74 Sat Mar 01, 2014 10:00 am
Hey Jim, was flying for work today and took some old mags. Here is an advert for the new SIG Twister in the March '76 issue of Flying Models.
"Fancherized" Twister build - Page 2 JTmvZLwl
Post  GUS THE I.A. Sat Mar 01, 2014 10:41 pm
You know... I finished my F.T. a little while back, and have a few flights on it. I removed the K&B 40, and installed a Lew Fox 35. The .40 was too heavy, and made the plane too fast. It's doing lots better, now!
Anyway... I had parts left over from the Twister, that were not part to make it a Fancherized version, so, I built a profile Mustang! It will be painted in the "Miss America" colors, not purple. It is done, minus the red and blue. Couldn't let those parts lie around here, taking up space! Picture soon.
GUS THE I.A.
GUS THE I.A.
