Bladders made even easier
Knot on the back end, o ring secures the nipple. Entire process takes about 30 seconds.
JPvelo- Diamond Member
Re: Bladders made even easier
An o-ring, excellent. I'll have to put that on my Lowes/Advance shopping list. I wonder if a silicon fuel tube donut would be tight enough. I've been using twist tie wire, but the o-ring is the simplest ever. If I ever make a revised video, I'll credit you with the idea, Jim. A 30 second job on a bad day.
RknRusty wrote:An o-ring, excellent. I'll have to put that on my Lowes/Advance shopping list. I wonder if a silicon fuel tube donut would be tight enough. I've been using twist tie wire, but the o-ring is the simplest ever. If I ever make a revised video, I'll credit you with the idea, Jim. A 30 second job on a bad day.
Maybe a size or two smaller tubing than you are using for the bladder and it would clamp pretty tight I would imagine. Used to use self cut tubing 0rings to secure fuel lines to fuel nipples on my 1/8 scale of road stuff,,it took a great deal of force to remove them and put them on. You don't want to lube them to slide them on,,or they will slip right off. they need to be slid over top of another dry.
a special tool made specifically for sliding o-rings/self cut rings onto fuel lines, big or small. I have seen this in action and works really easy. Doing it by hand is tricky and can be a exercise in paitence.
http://www.gmksupply.com/html/gmk0125.html
A band of supple heat shrink tubing would work,,just don't overhang onto the bladder tubing or it might rub and cut thru when shrunk with a filled bladder.
I essentially use the same method. I use a piece of fuel tubing like Rusty suggested. Instead of using a fitting, I use a long 1/8" pop rivet and remove the pin. The flared side of the pop rivet goes into the bladder and it makes for a great barb. Ken
All good ideas. What size O-ring Jim?
Not sure. I went to the hardware store and picked up what looked right. The tubing is 1/8 and I have to squeeze it to get the ring on.Cribbs74 wrote:All good ideas. What size O-ring Jim?
Ok Jim.
i would like to know what type of tubing you are using for bladders as most of the ones you use isent available here in Australia (not that ive found at least)
ekitten2- Gold Member
Surgical tubing is what most of us use. Should be readily available everywhere!
I use 1/8 inch surgical tubing purchased for $1 a foot at a fishing supply store.ekitten2 wrote:i would like to know what type of tubing you are using for bladders as most of the ones you use isent available here in Australia (not that ive found at least)
That's the stuff, it provides comparatively low pressure tor 1/2A engines. The combat guys that run bigger engines, .25s and up, use wider ID and thicker walled tubing that provides higher pressure. I don't recall the wall thickness on the 1/2A stuff I get from TexasTimers.com. Maybe 1/32 or 3/64".JPvelo wrote:I use 1/8 inch surgical tubing purchased for $1 a foot at a fishing supply store.ekitten2 wrote:i would like to know what type of tubing you are using for bladders as most of the ones you use isent available here in Australia (not that ive found at least)
» Big Box made it.
» Bursting Bladders
» A dozen reasons why airplanes are easier to live with than women
» On my way! (Made it!)
» Bursting Bladders
