Modifiying ''Horseshoe'' backplates Cox_ba12
Modifiying ''Horseshoe'' backplates Pixel
by Ken Cook Today at 3:23 am
Modifiying ''Horseshoe'' backplates Empty
Modifiying ''Horseshoe'' backplates Empty Modifiying ''Horseshoe'' backplates
Post  Mark Boesen Mon Jan 06, 2014 8:35 pm
In the early seventies (c. '72) Cox introduced a new plastic backplate we now referred to as the "Horseshoe" for their RTF's. In a cost savings measure (c. '76) the needle was changed from brass to aluminum and in '79, to reduce machine costs changed the threads from 124 to 90 tpi, threads per inch.
These backplates can easily be converted with the older fine thread (124 tpi) brass needle that everybody seems to have laying around from the early "postage stamp" backplate.
Grab a heat gun and carefully get it warm, using a small needle nose pliers, from the fuel line side pull spray bar out.
While backplate is still warm carefully press in 124 tpi spray bar making sure fuel hole is facing engine and is centered. You can mark it with a Sharpie or look down venture as you start to pull it up.
You can also open up intake with a Dremel stone prior to new spray bar, use a piece of fuel line as a spring/retainer.
The only issue with this is if you get plastic too soft you could damage/enlarge hole, as the fine needle spay bar is actually slightly smaller and you may need/want to touch a little JB weld on the top just to make sure the spray bar is locked in.
Modifiying ''Horseshoe'' backplates 15380610
Modifiying ''Horseshoe'' backplates 15084210
Modifiying ''Horseshoe'' backplates 15961010
Modifiying ''Horseshoe'' backplates 16067810
Modifiying ''Horseshoe'' backplates 15374710
Modifiying ''Horseshoe'' backplates Empty Re: Modifiying ''Horseshoe'' backplates
Post  JPvelo Mon Jan 06, 2014 10:37 pm
That's how I modify them to run on a pressure bladder. Once you put them on pressure you can bore the Venturi all the way through to 13/64 and from the back to just past the spraybar with a 7/32.
JPvelo
JPvelo
Post  anm2 Tue Jan 07, 2014 6:03 am
Mark Boesen wrote:In the early seventies (c. '72) Cox introduced a new plastic backplate we now referred to as the "Horseshoe" for their RTF's. In a cost savings measure (c. '76) the needle was changed from brass to aluminum and in '79, to reduce machine costs changed the threads from 124 to 90 tpi, threads per inch.
Mark, Thanks for this information. Its very helpful. I have a few questions.
Are all of the old postage stamp backplates using the fine thread needle valves?
From your description, some of the horseshoe backplates have fine threads and some do not, is that correct?
What is the best way to determine if the needle valve and the needle are fine thread?
What is the advantage of the fine thread needle valve?
Were the KK Fine Thread Needle Valves 128 tpi or 124 tpi?
Thanks again, and sorry for all the questions. Andy
anm2
Post  Mark Boesen Tue Jan 07, 2014 8:22 pm
Hmm...good questions, I didn't catch that till I saw your post. I got the 124tpi from a old ECJ article by Dan Sitter, but I see the Texas Timers web site quotes "128tpi" and I guess I always referred to it as 128, not thinking about 124 tpi as per the article till you mentioned it?
So based on that:
The article is in error and should be 128 (tpi) not 124?
That maybe at some point in recent years it's been changed, it's now 128 and maybe it was 124? All my fine threads are the same, KK or Cox, but I've not bought a 'fine' thread needle in twenty years.
Or maybe 128 is also known as 124 and that they're one and the same?
The Shadow knows...so until we find out more, lets just refer to them as 'fine' threads and 'standard' threads
Here's your questions and answers:
Yes, they seem to be...a great source for a fine 'fine' thread needle.
Yes, the early horseshoes were fine thread spraybar/needle, but I don't think they're as common.
Try to see if they fit? Look at pics, the KK and Cox look very much the same... 124 or 128 whatever?
They're easier to needle as the air/fuel ratio changes more slowly, especially if your running a higher compression engine, too little to too much, can be tricky?
Again, I believe they were 128...and Coxes are 128 and the article I got info from is in error...or that they're 'one-and-the-same'?
no problem, your welcome!
Modifiying ''Horseshoe'' backplates 20140110
Modifiying ''Horseshoe'' backplates 20140111
Modifiying ''Horseshoe'' backplates 20140112
Modifiying ''Horseshoe'' backplates 20140113
Post  pkrankow Wed Jan 08, 2014 5:59 am
I have 2 different thread pitch "fine" NVA's for my TDs. The one Texas Timers sells, and a different pitch that does not interchange.
So be careful with mix and match.
Post  Mark Boesen Wed Jan 08, 2014 8:06 am
hmm...so maybe the new ones are 128 and the old kk's/postage stamps are 124?
Post  pkrankow Wed Jan 08, 2014 8:40 am
Mark Boesen wrote:hmm...so maybe the new ones are 128 and the old kk's/postage stamps are 124?
It is possible. I don't have an accurate way to measure pitch that fine, and I have no desire to count threads directly. I am just warning caution with mixing parts that were not already fitted together because they might be different, even though they look very similar.
If two male threads against each other, the grooves will mesh if the pitch is the same. If the pitch is different the threads will not perfectly mesh. With this fine of thread pitches (124 and 128 tpi) one would need to compare at least 1/4 inch of thread, and I am not sure if the naked eye will perceive a difference, although 1 full turn of thread shift should be visible.
I'll look and see if I can find the different NVA (hopefully it is not the one I broke the needle on) and take a pic next to a TT NVA
Post  Mark Boesen Wed Jan 08, 2014 9:06 am
Hi Phil,
You can see in the first two photos, the old 'postage stamp' needle and a KK needle that there the same, my question is are they 128 or 124?
Post  pkrankow Wed Jan 08, 2014 9:26 am
Mark Boesen wrote:Hi Phil,
I don't know. Short of measuring out and counting I don't know how to determine thread pitch for this size. I suppose using calipers to measure out 1/2 inch and counting 62 or 64 threads in a picture might be easiest. You take very good "macro" pictures.
All I know for sure is one of my NVA's is different from the Texas Timer NVA, and the needles are not interchangeable. I found the broken needle and it appears to be a Texas Timer needle. I need to get the three engines out of the garage and look very, very carefully at the needles to tell which is the different one. Two are Texas Timer and one is something else.
Post  Mark Boesen Wed Jan 08, 2014 12:13 pm
yep, ain't modern technology nifty, that's the cel phone! I think it takes better pics then a digital camera of ten years ago.
Post  duke.johnson Wed Jan 08, 2014 1:25 pm
Here's the stupid question. What does the postage stamp backplate look like? Is it the red ones with no mounting holes?
duke.johnson
duke.johnson
Post  Mark Boesen Wed Jan 08, 2014 1:28 pm
duke.johnson wrote:Here's the stupid question.  What does the postage stamp backplate look like?  Is it the red ones with no mounting holes?
yep, 'bout the size of a stamp. The ones used on the P-51, Stukas, Corsairs, etc.
Post  duke.johnson Wed Jan 08, 2014 2:08 pm
Mark-
Cool, I'll keep an eye out for those in the future.
PM'ed you
duke.johnson
duke.johnson
