A Traveling Engine plane.
Since I signed up for a turn on the Traveling Engine, I figured I needed a safe, stable plane so I wasn't the one who pranged the engine. I thought a White Lightning would do the trick. The plans say it's for a .049 to .061 engine, and it has a lot of wing area for slow and stable flight. We'll see.
As usual, I forgot to start taking any pictures until I was well underway with the build. Here's the wing being cut out:
And the stab:
The fuse with the slots cut for the stab and wing, and with the hardwood engine bearers in place:
And the kit ready to start assembly:
The Cautious Mark
And the stab:
The Cautious Mark
batjac- Diamond Member
Re: A Traveling Engine plane.
I have been contemplating one of those planes. Maybe when I get the engine I will do similar...
Current status
So, we jump ahead to assembly. I would normally do these posts over a few days, but I was more interested in building than documenting, so you guys get to see "start to finish" in one sitting.
Parts covered and ready for final assembly:
Left side view of assembled plane:
Front:
Right side. The plans call for a 1 ounce tank, but that tank seems awfully big. I'll definitely be short tanking for the first few flights. One ounce will probably seem like forever when its going roundy-roundy:
Rear view:
And bottom. Inverse colors of the top:
I went with the standard Batjac Aeroworks© Paint Scheme. Red seemed a good color for this. Trendy. Sophisticated. Eye-catching. Besides, I have three rolls of red to use up.
Final thoughts: For a plane that's targeted at .049-.061 engines, it seems awfully heavy, even for a TD or a Norvel. When I looked at building it, I figured I'd also use this as a test frame for an electric plane. After that, I think maybe I'll try a Medallion .09. It seems sized better to take an .09 than an .049. But that's for later. First I need to fly it with the Carbonite Engine.
Copyright © 2013 The Trademark Mark
Front:
Rear view:
Cool! I'm planning on getting the engine out there soon. Just waiting on some things.
I'll fly it on my Li'l Satan, as I did with the traveling prop. It has a screw-on backplate mount, so all I have to do is grab the old Tee Dee and unscrew the crankcase from it and screw the new one onto it.
I'd be willing to bet it flies great with the "Carbonite" Tee Dee or Norvel. Maybe not with a reed-valve engine... What is the wing-span and sq. in. area of that design? It looks to be around a 24" w/s 150 sq. in.? (am I close?) I'd love to scale that design down; just a little... and eliminate some of the "real-estate" in the stab. for reed-valve power. It's a real nice looking airplane! Can't wait to get a flight report!
It has a 28" wingspan. Chord averages out to about 6" for ~ 168 sq. in. on the wing. I just balanced it, and all that wood in the tail makes it mucho tail heavy. I had to add an ounce and a half to the nose to balance it out. If you build one, definitely go for a built up stab. You might also taper the bottom of the fuselage from the wing t.e. to the end where it would just clear your control horn. Hopefully my son and I will be able to test fly it this weekend. I'll make a mount for an electric motor soon, and hopefully the weight of the motor and battery will balance it out better. But, now that this iteration is finished, I'll move on to another idea that's been kicking around in my head for a while. I should be able to get it built this week, if I can get to the office supply store sometime in the next couple of days.
The Balanced Mark
The Balanced Mark
I've never monocoated a profile fuselage. How do seal the edges around the engine area to prevent fuel from lifting the covering?
JPvelo- Diamond Member
I've never had Monokote/Econokote that's been ironed over other Monokote/Econokote lift due to glow fuel. For the areas around the engine that are bare wood and where the film edges are, I just fuel proof the wood with thin CA, and it also keeps the film from lifting. Even though I really prefer Monokote to Econokote, the Econokote is better for profile fuselages as it take sharper turns without wrinkling as much, and shrinks up more than Monokote. It's also a few bucks cheaper, a little lighter, and irons on at a lower temp. The big drawback for me and the reason I'm not partial to it is that the color smears pretty easily if you're not careful. The white on the plane is Monokote, and the red and black are Econokote.JPvelo wrote:I've never monocoated a profile fuselage. How do seal the edges around the engine area to prevent fuel from lifting the covering?
The Koting Mark
1oz will last around 4-5mins with a TD. My latest build was almost 9oz and the TD still pulls it easily.
Looks good!!
Looks good!!
Growing Fleet Mark- Nice looking plane. I have the plans for this plane and thought of making one for the cox engine contest.
duke.johnson- Diamond Member
where can i get plans for a white lightning??alan
bullit132- Gold Member
http://www.hippocketaeronautics.com/cl_sp_white_lightening.htm
Here ya go.
Here ya go.
thanks a bunch duke!
No problem, that was easy.
» Poll: Traveling Engine 3 engine selection .15 displacement
» ***The World's Smallest Traveling Engine*** SIGN UP!
» *Cox Engine of The Month* Submit your pictures! -May 2020-
» ***The Traveling Engine TD .049*** SIGN UP!
» Follow The Traveling Engine!
