Crankcase upgrade/repair Cox_ba12
Crankcase upgrade/repair Pixel
by roddie Today at 1:34 pm
Crankcase upgrade/repair Empty
Crankcase upgrade/repair Empty Crankcase upgrade/repair
Post  ian1954 Fri Jun 14, 2013 2:46 pm
There I was starting to prepare for the Cox flight contest and deciding which engine I could use. Difficult decision in my case - too many options.
Anyway, it had to be beam mounted for the aeroplane I have chosen (this has arrived but I am still waiting for balsa cement and dope - no longer can I walk to the local model shop! - everything has to be mail order.
It also has to be quiet and so needs a good silencer (muffler) and a bit of throttle control. Matt had supplied me with a Hiscott muffley thingy and so I selected one of my restored Medallions to go with it.
Crankcase upgrade/repair Hiscot10
It looks the boy but was not to be a runner at the first attempt!
I was prepared for a lot of messing about with heads as the Hiscott system raises the cylinder and reduces the compression. Messing about turned into two and a half hours of flick - flick - flicking!
It started a couple of times, ran for a couple of minutes and then stopped abruptly. It would not restart while hot.
I thought it was compression and I had not chosen the right head, number of gaskets and so on.................
However. when it ran - the silencer was superb and the throttle control was excellent - along with idling.
After a while I notice fuel spewing from between the prop driver and the crankcase. Further examination showed that the crankshaft was a sloppy fit to say the least!
So ...... not being one to scrap anything - it was time to strip the thing a let it visit the workshop. Where it was.........
drilled and reamed
Crankcase upgrade/repair Bearin10
a suitable piece of brass selected
Crankcase upgrade/repair Bearin11
I made a mistake and turned it too small and so worked further on it for a Bee crankcase
Crankcase upgrade/repair Bearin12Crankcase upgrade/repair Bearin13
Crankcase upgrade/repair Bearin14
anyway - back to the Medallion
Crankcase upgrade/repair Bearin15
Crankcase upgrade/repair Bearin16
off to the mill!
Crankcase upgrade/repair Bearin17
Crankcase upgrade/repair Bearin18
Crankcase upgrade/repair Bearin19
Reassembly ready for testing. Too late to test tonight but fingers crossed for tomorrow. What am I saying? Better not cross my fingers while flicking the thing!
Crankcase upgrade/repair Bearin20
ian1954
ian1954
Crankcase upgrade/repair Empty Re: Crankcase upgrade/repair
Post  Cribbs74 Fri Jun 14, 2013 3:45 pm
Impressive....... I would love to bush some of mine.
Post  RknRusty Fri Jun 14, 2013 7:11 pm
Me too, nice work, Ian. Do you cut an oil groove in the bushing? I don't remember if the TeeDallion crankcase has one. Is brass as good as bronze?
Post  Jason_WI Fri Jun 14, 2013 7:24 pm
Nice work! Did you add an oil groove to the bushing or is it not needed? What material did you use. I need to get a collet system for my lathe Sad
Jason_WI
Jason_WI
Post  ian1954 Sat Jun 15, 2013 9:51 am
Bronze - phosphor bronze - is better than brass by far. It is easy to machine but very difficult to drill. The material "grabs" drills and it is difficult to get a straight and clean bore. Drills will wander off line. It also heats up quite quickly when drilling. It has to be done slowly with modified drill bits.
The Medallions and Tee Dees don't need a groove but the Bee might. I will run it without and see what happens!
ian1954
ian1954
Post  ian1954 Sat Jun 15, 2013 9:53 am
I got it running but it needs a bit more patience setting the head and gasketing.
A bit boring but the engine is quiet!
ian1954
ian1954
Post  reptile Sat Jun 15, 2013 3:57 pm
Nice muffler may work good on a cox car...do you have the site that sells them?
THANKS
reptile
reptile
Post  ian1954 Sat Jun 15, 2013 4:34 pm
I am afraid they are no longer easily obtainable.
ian1954
ian1954
Post  MeerschaumSteve Thu Jun 27, 2013 6:11 am
I was thinking the same thing, looks like a great car muffler!
MeerschaumSteve
MeerschaumSteve
Post  ian1954 Sat Jun 29, 2013 3:05 pm
I finally got around to building up the Bee. Thought it strange watching the fuel dancing in the filler tube!
ian1954
ian1954
Post  RknRusty Sat Jun 29, 2013 9:01 pm
Nice and steady, that's as smooth as they get. Sounds ready yo fly.
Post  sdjjadk Sun Jun 30, 2013 6:38 pm
Excellent work Ian! And thanks for the videos as well.
Shawn
sdjjadk
sdjjadk
