Removing dried Epoxy
Anyone have any tips/tricks on removing dried epoxy from iron on coverings? No matter how careful I am that stuff always seems to run places that I don't want it or stick to my fingers which causes me to leave fingerprints/smudges on the finish.
Re: Removing dried Epoxy
Don't get the epoxy on the covering in the first place. (har har)
Most epoxies loose integrity with application of heat. However this may be less useful since the film is altered with heat. However the film is "shiny"so once the epoxy starts peeling it should continue to peel off.
Now, if you haven't epoxied yet you can mask off the parts that don't get glue, you can use a release agent such as wax or highly diluted white glue (PVA).
Unmixed or unkicked (mixed but hasn't started to gel yet) epoxies frequently clean up with soap and water (seriously, soap and water, read the instructions)
You know not a bad idea, masking off the areas I don't want glue. Soap and water you say? Funny, as I have tried to get it off my fingers using soap and water and it never works. I use alcohol for that or just a dry rag.
Ron, the first tip, would not be getting it on there in the first place. Easier said then done. Epoxy is easily cleaned with rubbing alcohol as long as it's not kicking off . It comes right off using alcohol and a towel or Q-tip for finer work. Now that it's dried, I know with Monokote, lacquer thinner doesn't affect the covering. I've taken a rag soaked in lacquer thinner and laid it on the affected area. I can usually get it off with a little scratching then. Don't allow the towel to come into contact with any paint. It usually comes off in it's entirety. I can't speak for the other coverings when using solvents though. I'm a Monokote user. It's amazing how clean you can do a repair once you discover how easily epoxy cleans up after using alcohol to wipe it off. This works great for new construction and repairs. I used to dismiss the idea of using epoxy because of the mess. Now I make inconspicuous repairs using the alcohol. Ken
cribbs74 wrote:You know not a bad idea, masking off the areas I don't want glue. Soap and water you say? Funny, as I have tried to get it off my fingers using soap and water and it never works. I use alcohol for that or just a dry rag.
Once it has kicked soap and water won't work. This is really only useful on long pot life formulas. It works with the Locktite 30 minute product in the large bottles, and West System.
I have used soap and water on unmixed epoxy with good results a number of times.
» Can anyone identify this wood? Hoping it's good stock for beams.
» umx a6m5 zero to cox .049 nitro
» 30, 15, 5 Epoxy
» 2 part epoxy
» 30, 15, 5 Epoxy
» 2 part epoxy
