umx a6m5 zero to cox .049 nitro
work on umx fomie is fast easy way to get scale to its best +pic coming y just get cg right wit engine lipo batry in noze lipo wit engine ha ha ha boom hope no
davidll1984- Diamond Member
Re: umx a6m5 zero to cox .049 nitro
Good job David! Should be a lot of fun.
great conversion !!
Just one point: if you don't have a landing gear, the wooden propellers can't stand the touch when landing, you may break it very soon on a landing. In that case, place a plastic one that will more properly support the landings! ... It is just a tip so you can fly and fly without rest.
MauricioB- Top Poster
more stuf coming
pic below see O ring its holding wing push in place lock wit pin on front use of special tool to get O ring on fuselage part
engine
not tested on cox nitro engine but wit its 300 brushles plane was heavy wil get final weight after its al set to go wit fuel cox swap save weight also changed servo to save on weight original it fly bad too heavy for control surface now it wil fly scale faster
I think converting foamies to glow engines is an admirable idea, some of them need pepping up.
Be careful though, although at first sight foam (epp) is fuel proof - it doesn't always cope well with the exhaust residue.The exhaust residue can be absorbed into the foam kernels or any joins in the model. This can make the foam soft and squidgy (not dissolving but mushy). Eventually any glue joints may give way and the foam can break apart. It may be advisable to apply some fuel proofer to be on the safe side.
epoxy
epoxy is use to fuel proof inside engine beay engine is secure like ez bee plastic fire wall hold in place wit two noze part my is foam wit epoxy glue al over inside except near cylinder y want heat to melt foam to its place y expect good result my engine is sort of kiler bee modified engine dont no witch prop use plane used slow flyer prop 7x? mabe 6x4 wil fit dont no if .049 can spin 7x3 prop without crank damage
The Cox Texaco spun a 7" prop ok, so I doubt that you would do any damage, although I think you will need to allow the engine to free up a little more by going no bigger than maybe the 6x4davidll1984 wrote:edont no witch prop use plane used slow flyer prop 7x? mabe 6x4 wil fit dont no if .049 can spin 7x3 prop without crank damage
first flight for my zero very powerful airplane unlimited vertical wit speed gain hard to trim for my last flight it was litle dark so it stop me during adjustment seting engine was litle hard wit cowl of engine on to dark but so mutch fun landed on soft grass second landing was litle hard on gravel just couple of scratch under cowling and bely of model y did use 6x3 prop first time second flight used a6x4 prop to fast hard to control very twitchy on stick no expo pre set nead fine tuning o and plane fly good wit engine staled great control to bring back in 1 pices now its don nex is miss monica on his way soon wil post more of madame monica
by the way just let u no just started working on new engine for engine of the month wil post my progres in time is going big one .15project sportsman cl to rc if not redy for nex month wil just post pictur of random engine chosing in my colection of new engine wit light modification
happydad- Rest In Peace
my umx zero weight is 280g just if tank is full tink it was like 268g dry size is same as oem umx a6m5 zero made by eflite my convertion is litle les weight its storage box is wel made very useful cox fuel cans fit in perfect rags tools al nead to go exept controler very good convertion tink
great
davidll1984 wrote:my umx zero weight is 280g just if tank is full tink it was like 268g dry size is same as oem umx a6m5 zero made by eflite my convertion is litle les weight its storage box is wel made very useful cox fuel cans fit in perfect rags tools al nead to go exept controler very good convertion tink
Guestimating the average wing chord of 3 1/2inches and 25inch wingspan from elite your wing area is 87.5square.inches
9ounces / 87.5sq. in. = .102 oz./sq.in. very good, low wing loading. Great job. my goal for a flying Corsair was 5ounces. Ain't there yet.
do you have landing gear? No, just checked. just a fuel tank or bomb underneath the plane. Oh a bomb for sure.
Again great job. happydad.
no posible scale landing gear for him bomb is just is stand pod for display witch not used is in is box think the eflite corsair is similar power tink is posible
had an idea last night, AND NOW A PROTOTYPE
davidll1984 wrote:no posible scale landing gear for him bomb is just is stand pod for display witch not used is in is box think the eflite corsair is similar power tink is posible
I couldn't sleep last night in the Southern California heat. I had an idea for a low weight, low cost ranging gear set up. it is very simple using 1/32SS rod, or wire, but stiff like I use for pushrods. and 1 of Bernies 1/2 wheels. Full plastic on oe side and cutout on the other. At one time they were on sale 10 for $1.00 or something like that.
I will repost later with a 2D drawing showing 2 views. The landing gear sort of clips on to the leading edge of the wing, follows the bottom profile of the wig until it gets to the C.G., (Center of Gravity), where the aircraft is evenly balanced fore and aft. The the rod or wire, depending on the size of the aircraft, my wingspan is 20inches and a chord of about 4 inches, so the CG should be 1/3 x chord, or 1/3 x 4 = 1.333inch back from the leading edge. Then the landing gear slopes down at an angle away from the fuselage for enough space to clear the propeller while taking off or landing. In my case about 1 to 2 inches to insure not hitting the propeller. A simple drawing will help.
Back shortly I wasn't expecting to do this now.
I'm back, I forgot to post the above part. I didn't get too much sleep last night. so below is a crude attempt at a drawing showing a clip-on type landing gear for a Corsair wing. Ignore the other parts. The guy who sold me a bunch of Cox Gravity Corsair parts attempted to add ailerons using 1 servo. anyway.
Corsair wing with clip-on landing gear. Note the the red wire actually form a "V" about 2inches at its widest point and the wheel is at the narrow point. I still need a frontal view and a lot of sleep, so you can see how the clip-on works.
More soon
edited 7-25-2020 at 9:34p.m. PST - I found the black wheels described above and some tiny piano wire and started bending to make a set of landing gear for My Corsair or any other of the Cox Gravity Series.
1 correction to the above text. The piano wire is 1/64inch, not 1/32, but could be heavier depending on the aircraft weight.
side view
front view
bottom view
front view of landing gear
side view of landing gear
it fits nicely onto the wing, but may need a trailing edge support to keep it from coming off during landings.
happydad
Last edited by happydad on Sun Jul 26, 2020 12:23 am; edited 1 time in total (Reason for editing : to add photo. more content)
» Buying used Cox engines
» does nitro go bad
» Nitromethane
» curious about cox engines
» first nitro car
» does nitro go bad
» Nitromethane
» first nitro car
