by rsv1cox Today at 10:07 am
cox gto and camaro engine question
hello I finally received my 1968 cox GTO and Camaro , they are in great shape with nice boxes but sadly some one at some point decided to put fuel in the engines. no big deal I dont think they even got them started but the old fuel did make a mess of the reed valve . this leads to my question I do not know how to remove the reed from this engine . it's a .020 with a metal tank but is different than my other pee wee motors . it has a E clip like a standard pee wee but it also has a what looks like a steel cage that covers the edges of the reed . very much like the newer .049 with the plastic back plate where you install the reed and just slide a sleeve over to retain the reed . I have never seen this on a pee wee and was wondering how to remove this steel cage , I don't know if it's threaded or pressed on . the reed can not be serviced without removing it and I don't want to force anything . has anyone ever seen this setup on a cox .020 and know how to properly service this engine . thanks Roger
RAMJETT- Bronze Member
Re: cox gto and camaro engine question
At the behest of Roger, we are posting the pics of his cars. We have never seen Cox cars with 020 engines and actually, until now, did not even know they existed.
thanks Bernie for posting the pictures for me .Roger
Mudhen- Gold Member
for sure has a metal cage I will post a picture ,it does not show this piece in the cars motor break down , they look to be original parts with thimble drome on the tank . both cars have the same sleeve , the reeds can not be removed with them in place . I missed that picture when I sent them to Bernie . I will see if he s kind enough to post the fuel tank picture for me .Roger
Mudhen- Gold Member
I just sent Bernie the picture I am sure he will post it when he has a spare moment . I know what tank you are talking about with the undercut lip. this one is sort of like that and to be honest I am not sure my .020 should have a e clip though the spacing would be too great with the E clip out , the reed could fall forward with the clip out. the front of the tank is turned down somewhat from a normal pee wee where it fits in the back of the block then there is a metal cage that overhangs the reed by quite a bit and is pressed (or screwed on)down the sides of the reed block about 3/4 of the length of the part that goes into the back of the engine block ,when you see the picture you will see the void where the cage ends just before the bolting face of the tank .I have soaked it for 2 days and nothing , stumped on this one .it's not so much this would ever be run it's the fact that I cant figure out how they did it LOL. I just have to know now . regards Roger
I have a .020 car engine with a funky tank. It has a larger crank also.
Jason_WI- Top Poster
there you go that's the one , that is the same motor I have in my 2 cars , you can see in your picture the metal sleeve . that engine for sure is from a GTO or Camaro . how the heck do you change the reed on it. does it look like that sleeve comes off on your motor. thanks for the picture .Roger
Mudhen- Gold Member
Bernie looked it up on his cox database and could not find any mention of this change either . it's obviously a cox alteration ,you and I both having one with the same setup eliminated a home mod ,but as you were saying , what was the reason for the change and how do you service it . the only thing I can think of is to use a mylar reed and flex it to fit . I am thinking the reason for the change must be because in car engines there is nothing driving the crank forward like on the prop versions ,this metal sleeve may just be a a bearing surface for the crank pin to wear against. Roger
I'm aware of cars, but never owned one or seen engine.
Here's a link to a collecter buddy: http://gascarman.blogspot.com/
Mudhen- Gold Member
Nice cars.
jsesere- Rest In Peace
Seeing those cars makes me want to build mine and put them in my display cabinet, they look great .Shame cox never made a 1969 Pontiac Firebird I have a full size one in mint condition ,would love to have the model to match.
Here is a pic of the tank. Dan Sitter, in his publication, refers to that tank as "ECJ #151" early 60's, with a note that the reed holder is similar to the Space Bug Jr. one.
» Engine question
» Texaco engine question
» A Mid-70’s engine question.
» OS Max .010 10 FSR RC Engine question
» Yet another engine question....
