TD 010 Crankshaft. Cox_ba12
TD 010 Crankshaft. Pixel
by batjac Today at 10:05 pm
by gkamysz Today at 9:29 pm
by roddie Today at 9:22 pm
TD 010 Crankshaft. Empty
TD 010 Crankshaft.
TD 010 Crankshaft. Empty TD 010 Crankshaft.
Post  ebeneezer Sun Feb 03, 2013 12:14 pm
Guess whose just broken off the piston drive spiggot on my TD 010. Being a mechanical engineer I thought I'd have no problems. I know it's going to be difficult to get one, any ideas? Sad Sad Sad Flying
ebeneezer
ebeneezer
TD 010 Crankshaft. Empty Re: TD 010 Crankshaft.
Post  pkrankow Sun Feb 03, 2013 12:26 pm
Center punch, drill, tap, locktite, pray...
or
Center punch, drill, ream (or not) and press/shrink fit the new stud from hardened rod...
use a hardened bolt that is cut down as the new part, good luck finding a truly hardened bolt in these sizes though. small diameter drill rod is much easier to get. I have a whole index full.
Not that much to loose by trying.
Post  ebeneezer Sun Feb 03, 2013 1:19 pm
Sadly some of the crankshank flange chipped away with the spiggot. so I would have to reposition the spiggot by 90 degrees. Would that matter? Flying
ebeneezer
ebeneezer
Post  pkrankow Sun Feb 03, 2013 2:14 pm
You're the engineer...
Unless you source another crank I guess it is what you have. Is this a reedy? Is the crank web a disk or is is relieved for balancing? I don't have an 010.
If you change the location and the intake is through the crank then you will make it a reverse runner.
Post  Surfer_kris Sun Feb 03, 2013 2:21 pm
The .010 are TD style only, i.e. the intake is in the crank. The crank pin has to be where it was, unless you convert it to a counter rotating crank. Even then I believe that the rotation should only be about 90° from where it was (Enya 09 engines have this feature where you rotate the intake in the crankcase).
Surfer_kris
Surfer_kris
Post  ebeneezer Sun Feb 03, 2013 2:33 pm
Thanks, replacement crank it is. Oh well, that puts the Lil Stingray on hold. Sad Sad Sad
ebeneezer
ebeneezer
Post  ian1954 Tue Feb 05, 2013 10:33 am
A replacement crank will be hard to find.
Please post a picture of the damage and broken bits (if you could find them all). It may still be repairable.
Ian
ian1954
ian1954
