by getback Today at 5:25 pm
» Ode to a dead cat
by rdw777 Today at 3:28 pm
» COX .020 RC PROJECT
by rdw777 Today at 3:21 pm
» Peewee power
by rdw777 Today at 3:04 pm
by rsv1cox Today at 8:53 am
» some pics....
» Thrust Washer
Piston weight
Piston weight
Slow Sunday so I decided to check some piston weights, all are in grams. All are new and never run.
Killer Bee .049 2.76
Venom 2.8
Lightened piston from EX CI 2.85
Old TD .049 tapered 3.16
Old TD .051 tapered 3.3
Medallion .049 3.15
Standard modern piston 3.15
Venom 2.8
Medallion .049 3.15
crankbndr- Top Poster
Re: Piston weight
crankbndr,
Thanks for doing that.
Maybe your weights and these could go into a sticky to
be added to. Cranks, cylinders, etc.
Re: Crankcase styles
dckrsn on Mon Apr 30, 2012 8:57 am
I weighed 4 different cranckcases this morning, and this is what I found.
Thin taper 6.553g
Cast case 6.977g
Thick taper 7.318g
Surestart 7.351g
Thin taper 6.553g
Cast case 6.977g
Thick taper 7.318g
Surestart 7.351g
dckrsn- Diamond Member
Re: Piston weight
Cool, I was wondering crankcase weight also.
» Wanted: Cox .15 piston, or piston/cylinder - FOUND!
» .010 piston or piston/cyl. assy.
» Cox PT-19 weight?
» Cox PT-19 weight?
