» Jim Walker Bonanza etc.
by Ken Cook Today at 5:03 pm
by rdw777 Today at 2:52 pm
by rsv1cox Today at 10:52 am
by roddie Today at 10:30 am
by roddie Today at 10:02 am
by TD ABUSER Today at 9:25 am
» 1940's?...............
by rsv1cox Today at 7:46 am
» Lesson learned
August-2024
Hobby King Mini-Stick 580mm "Electric to Cox" Conversion
Page 1 of 3
Page 1 of 3 • 1, 2, 3
http://www.hobbyking.com/hobbyking/store/__18653__Hobbyking_Mini_Stick_580mm_ARF_.html
![Hobby King Mini-Stick 580mm "Electric to Cox" Conversion Ministickarf-main](https://2img.net/h/www.hobbyking.com/hobbyking/store/catalog/ministickarf-main.jpg)
Here is a sneak pic of my project. I haven't started it yet.
![Hobby King Mini-Stick 580mm "Electric to Cox" Conversion Photo10](https://i.servimg.com/u/f34/17/34/43/31/photo10.jpg)
Re: Hobby King Mini-Stick 580mm "Electric to Cox" Conversion
Initial thoughts... the 049 looks huge on it. I think I'm planning on a product engine of some sort and aux fuel tank.
Another thought... it may work well with a 020, but I don't have a backplate for one to find out. If someone has one, please let me know.
This may be the 2nd project:
http://www.hobbyking.com/hobbyking/store/__15182__J3_Cub_Balsa_Ply_EP_1190mm_ARF_.html
Yeah, that is going to be too much.
You have a TD .020, right?
WingingIt74 wrote:No I don't have one, surprisingly.
I thought you just bought one on eBay?
...long story... he refunded my purchase since it wasn't a 010, not quite what I was expecting. I still wanted it... oh well...
That's too bad.
If you ever come across another one, I think it would be a great match.
It does look like its a bit small for a 1/2a, I'm guessing less the 200 sq. in.? I think the .020 would be a better set-up.
Dunno, 580mm is 22.8". That should be in the neighborhood right?
Here is one that has been done already, I just sent him an email to see if I can get pics of his set-up.
WingingIt74 wrote:This may be the 2nd project:
Anyone with experience shipping from HK International Warehouse (China??) vs. USA warehouse? This plane doesn't even show when you set your location to US.
There is also a kit version (as in laser cut parts) of this that doesn't show either, as well as several other small ARF's, some just bare airframes, that would be prime for Cox conversion.
I guess they don't stock them in the US warehouse: perception being I guess most Americans (and you Canadians too!) can't be bothered to install their own servos, etc.
ahrma_581- Gold Member
re: cox .020 backplate
WingingIt74 wrote:Initial thoughts... the 049 looks huge on it. I think I'm planning on a product engine of some sort and aux fuel tank.
i have a red tank, metal backplate and needle for the .020, cheap. not the TD obviously. it may need a reed. pics on request. happydad
![Small Cox Logo](/users/3015/29/34/60/smiles/7356.png)
![RC Plane](/users/3015/29/34/60/smiles/3918962684.gif)
![Futaba Radio](/users/3015/29/34/60/smiles/354952.png)
happydad- Rest In Peace
WingingIt74 wrote:Here is a sneak pic of my project. I haven't started it yet.
Might document the build as you go, could make a good article for the new e-zine. Maybe even the start of a regular series of 'electric to glow' conversion articles, since half-a ARF's seem to be thin on the ground.
peewee should be substantial
PEEWEE POWER
PEEWEE POWER
mitchg95- Diamond Member
At 23" & 6-7" cord, that would make for a pretty small wing and a fast plane, looking at the video, with a sick running reedie it still manages to climb up into the wind pretty easy, 1/2a pylon racers are 200 sq. in.
I guess it depends what your looking for, if you wanted something slower I'd look at that J-3 but again, may just a stock Sure Start w/ a 6x3 might be ok, if you can keep it light with small flight pac, a Tee Dee .020 would work, I guess you'll have to figure out what you have, what you want and wheres the CG gonna end up?
...I do like the 'Stick' and think it would be a fun project!
re: radio?
WingingIt74 wrote:I plan on it
what type radio do you have? some of the new 2.4GHz receivers weigh 4grams without the case. i use 3.7gram servos for 30inch and under planes and 9grams servos for up to 50inch wings. anything needing extra torque will get a 1 1/2 to 2ounce servo. my 6channel RX + 2 servos weighs <2ounces + battery, (4cell 2/3AAA 220mAhr, <1ounce). for larger planes i use a larger battery pack at 1.6ounces, (4cell 4/5AA 700mAhr).
there are many 72MHz radios with micro 4channel RX in the <1ounce range.
there are 2.4GHz 6channel DSM2 RX available in CA from just under $7 each to about $6.50 each in 2x or 4x quantity. shipping was free, but now is $1.60 to $1.90. DSM2/DSMx are current formats for 2.4GHz frequency hopping TX used by Spektrum and Blade, (HP6DSM), transmitters.
happydad
I use mostly Spectrum with a couple OrangeRX receivers.
All Good Travis.
Junk the case from the orange and save a few grams.
My Baccaruda (only two hs50's) flys 5 x 3min flights with a 220mah batt then needs a 75/80 mah top up.
It weighs 15 grams. A 700 mah batt is plain unnecessary and pointless weight.
If you're looking to throttle, Bernie's rotating cylinder sleeves work well.
Looking forward to the Utube.
John Goddard- Diamond Member
I have a few original cylinder throttles as well as Bernie's throttled sure-start back plate (shown front center of the pic below).
![Hobby King Mini-Stick 580mm "Electric to Cox" Conversion Img_2319](https://i.servimg.com/u/f44/17/34/43/31/img_2319.jpg)
As for the receiver battery, I'm looking into a Life 200mah 6V battery.
Anybody want to buy/trade the Mini Stick? I'm thinking about going a different route.
How much? would you trade for a TD .051 or a Medallion .049?
» Hobby King PT-19 ARF
» Electric to Glow conversion
» Hobby King, for better or worse
» Black Hawk Models
» z-37 cmelak, rc electric to nitro conversion
» Black Hawk Models
Page 1 of 3
