Take a step back Jack! Cox_ba12
Take a step back Jack! Pixel
by Ken Cook Today at 3:23 am
Take a step back Jack! Empty
Take a step back Jack! Empty Take a step back Jack!
Post  Cribbs74 Thu Oct 11, 2012 8:28 pm
Are you supposed to be stepping back while stunting? As it stands I just fly around and when the lines go slack, say in a loop then it just give a sharp tug. It's semi controlled, but seems kinda archaic an not fluid.
It seems all my planes loose tension from time to time. So I was just wondering what you seasoned guys do.
Take a step back Jack! Empty Re: Take a step back Jack!
Post  RknRusty Thu Oct 11, 2012 8:42 pm
Yes, you have to walk back. Sometimes in a backwards circle. That's why you need a spot marker, so you can get back to center after you've done it. Some 1/2A planes hang tighter than others. With the Streak, I don't have to back step during a single or a double loop but I do have to back up during the third of a triple loop or a bunch of 8s in a row. If you notice in my videos, I'm all over the place sometimes, especially with the Satan, Bean and Stuntman. If I don't get right back to center, I'll hit a tree, or as I did last week, wrap the lines around the stooge while landing. Depending on the plane, it can be like a ballet dance out there.
Post  Cribbs74 Thu Oct 11, 2012 9:09 pm
Ok,
So it's not necessarily a trim issue. Like I said all my planes do it to some degree. I guess I need to stop being lazy and move around a bit. Like you I have trees to contend with if I go too far off center.
Post  SuperDave Fri Oct 12, 2012 5:06 pm
Ron:
Sure, stepping back a tad while if flight is a common practice with experienced stunters in some manuvers and under certain conditions like a gust of wind. Line tension is always important but it can be excessive if too much offset is used.
In flight the plane should not appear to "crab" (fly slightly sideays) or anything except parallel to the flying lines. This is achieved by proper trim adjustment which very often requires some experimentation.
SuperDave
SuperDave
Post  RknRusty Fri Oct 12, 2012 7:30 pm
SuperDave wrote:Ron:
With 1/2A I think back-stepping usually happens on most flights, especially during landing, for me anyway. It helps if a flying buddy can watch your plane through some flat laps to see if it's crabbing. He or she can see it from the front and the tail. You as the pilot can see more easily if one wing is dipping. Wingtip weight, engine offset, and leadout position are the main things I know to check. My Streak is the first plane to have no rudder offset but it stays tighter than the others, and I hear the rudder offset idea was pretty much abandoned by 1960. May be something to that. I've seen a picture of a plane with a small adjustable tab in the trail edge of the rudder
Post  Cribbs74 Fri Oct 12, 2012 9:05 pm
I run all my rudders straight now. I don't notice any difference in the way they fly. I am also moving around now (as seen on my Clown maiden) and it helps a ton!!!
