.049 Black Widow gummed up Cox_ba12
.049 Black Widow gummed up Pixel
.049 Black Widow gummed up Empty
.049 Black Widow gummed up Empty .049 Black Widow gummed up
Post  MoonDaddy Fri Aug 03, 2012 8:31 pm
Dear Cox Engine Enthusiasts,
Twenty-Two years ago my boys lost interest in model control line planes. They discovered women. We hung up the planes in the basement. My first grandson was born in June and I felt it was time to get back into the fun.
Three Cox .049 Black Widow engines were on the planes. The engines are in good shape, but are gummed up. I did not want to try the “Old Time” fixes of soaking them in diesel fuel or Coca-Cola. Does anyone have a solution to un-stick these great little engines?
Best regards,
Full Moon Boat Work
MoonDaddy
MoonDaddy
MoonDaddy
New Member
New Member
.049 Black Widow gummed up Empty Re: .049 Black Widow gummed up
Post  dckrsn Fri Aug 03, 2012 8:52 pm
Hey MoonDaddy,
Welcome to the forum. Now you're an enthusiast!
Good place to start might be here, though I'm hoping
some of the gang might chime in.
https://www.coxengineforum.com/t2204-stuck-from-long-term-storage?highlight=stuck
You might also scour the forum by way of the search feature.
Have fun, and again Welcome .
Post  Godsey3.0 Fri Aug 03, 2012 8:53 pm
You can apply heat to the cylinder and squirt in some fuel into the exhaust ports. The heat will begin to soften up the castor and allow it to move. The methanol (alcohol) in the fuel will liquify and thin some of the castor and add lubrication and make things easier to move. Be careful doing it. If it really does not want to go then do not force it. Move it a little bit at a time until it gets easier. I have heat alone get them freed up. I would still oil them up so they would not beat themselves to death on the first run.
And welcome to the forum!
Rolla
Godsey3.0
Godsey3.0
Post  RknRusty Fri Aug 03, 2012 9:00 pm
You can get everything you need to tune them up here: http://coxengines.ca
and here: http://www.exmodelengines.com/home.php
The owners of those sites are members here.
Post  lousyflyer Fri Aug 03, 2012 9:15 pm
Welcome to the forum!
Cox reed valve engines are amazingly resilient, but 22 years is a long time to sit, especially if they have old fuel residue in them.
I'd take them apart and soak them in alcohol or fresh fuel, oil them with 3-in-1, put them back together and try them.
Good luck!
lousyflyer
lousyflyer
Post  Cribbs74 Fri Aug 03, 2012 10:04 pm
Taking them completely apart and thoroughly cleaning each part is really the best way to do it.
It's very easy to do provided you use the correct tools and suggestions from members here.
These engines are very simple and durable even 22 Yrs sitting idle won't slow them down.
Post  JPvelo Fri Aug 03, 2012 10:13 pm
Welcome to the forum. Make sure and read the "Gibeault mouse race program" post located here:
https://www.coxengineforum.com/t753-the-revised-2011-gibeault-mouse-race-program
before dissasembly/reassembly. Great tips regarding Venturi gaskets and other things that will have your 'widows screaming.
JPvelo
JPvelo
Post  PV Pilot Sat Aug 04, 2012 4:33 am
A few new gaskets and a good cleaning and they will run like champs again. There is a plethora of info on this site for getting them up and running again.
Welcome in Moondaddy,,you have arrived!
PV Pilot
PV Pilot
High Tech Balsa Basher
Post  Kim Sat Aug 04, 2012 7:45 am
Welcome to the Forum Moondaddy !!!
Post  SuperDave Sat Aug 04, 2012 12:55 pm
For soaking my far and away prefrence is Hoppe's #9 gun cleaning solvent available at your local gun store or an outlet like Cabela's. I buy it by the quart because I use it very frequently of guns and Cox engines
Additionally I recommend the appropriate sized Cox wrench for disassembly/assembly work.
DO NOT use common pliers or you'll very likely cause permanent damage to your engine. "Tool marks" devalue your engine considerably.
Use the "Trouble Shooting guides at: www.coxinternational.com
SuperDave
SuperDave
Post  dckrsn Sat Aug 04, 2012 2:29 pm
Couldn't agree more with SuperDave on the Hoppe's #9.
This stuff is great.
Amazon has it here. http://www.amazon.com/gp/product/B00109AAN2/ref=ox_sc_act_title_1?ie=UTF8&smid=ATVPDKIKX0DER
Figure in shipping and compare against your local gun shop's price.
If you have a Cabella's nearby, it'll be cheapest there.
Post  gcb Sat Aug 04, 2012 5:10 pm
MoonDaddy wrote:Dear Cox Engine Enthusiasts,
Two months is too young to use as an excuse! Now three months, that's a different story. Smile
Best regards,
Full Moon Boat Work
MoonDaddy
You have been given some excellent solutions. I would try the easiest first. Squirt some fuel in the exhaust and see if it will turn over. (Good use for old fuel if you have any left.) Hoppes #9 or any gun cleaner is also an excellent choice.
If it does not turn over, try the heat from a hair dryer on the head and the crankcase around the crankshaft. Keep heat away from plastic parts (and tank). Also remember to wear some protective gloves to handle the hot parts.
If you can turn it over you can put fuel in the tank and try to run it or disassemble it and clean all parts. Use new gaskets if you have them and be careful to not lose the little seal between the intake on the backplate and the tank.
Good luck and welcome back.
gcb
gcb
.049 Black Widow gummed up Empty Thanks
Post  MoonDaddy Sat Aug 04, 2012 6:00 pm
Dear George,
Thanks for the tips, I have the #9, I’ll give it a whirl.
Best regards,
Full Moon Boat Work
MoonDaddy
MoonDaddy
MoonDaddy
New Member
New Member
Post  dckrsn Sat Aug 04, 2012 6:56 pm
Have fun MD, and keep us posted.
Any questions along the way,.....ask away.
Airplane
