Cox TEEDEE .09 Cox_ba12
Cox TEEDEE .09 Pixel
Cox TEEDEE .09 Empty
Cox TEEDEE .09
Cox TEEDEE .09 Empty Cox TEEDEE .09
Post  mitchg95 Wed Jul 25, 2012 8:57 am
i just pickep up a mint condition one for $10 at my awesome lhs
glow hed works , and engine as killer compresion. Can you guys give me soe tips for when i go to start this engine, also what kind of rpm's should i expect with 30% nitro
thanks
mitchg95
mitchg95
Cox TEEDEE .09 Empty Re: Cox TEEDEE .09
Post  Cribbs74 Wed Jul 25, 2012 12:42 pm
mitchg95 wrote:i just pickep up a mint condition one for $10 at my awesome lhs
thanks
Have you started a TD before? If you have it's pretty much the same.
As to the RPM the prop you choose will probably have a bigger effect on RPM than Nitro content.
Post  microflitedude Wed Jul 25, 2012 1:03 pm
Don't forget ear protection, the .09 is a very loud engine.
microflitedude
microflitedude
Cox TEEDEE .09 Empty re: "special deal"
Post  happydad Wed Jul 25, 2012 1:38 pm
thanks
is this my special deal?? LOL.
p.s. the .09 will have a much bigger kick than an .020 or even an .049 engine. Two Cents happydad. Small Cox Logo
Futaba Radio
happydad
happydad
Post  Ken Cook Wed Jul 25, 2012 2:31 pm
Mitch, just like any TD the venturi has to absolutely be castor and debris free to work correctly. The TD engines use a true sprinkler venturi. My best suggestion would be to hold the engine upside down while pressurizing the fuel nipple. Open the needle and really flush out those holes with fuel. If all is clear, your good to go. Cox made a specific prop for the .09. It was a gray 7 x 3.5. These are a bit rare but the size is certainly something to reference to. Removing the venturi would be a good idea closely inspecting the threads in the plastic for cracks. If no cracks are present , tighten the venturi snugly. If bench running, keep the fuel line short and the same height as the centerline of fuel inlet. I like to use clear tubing. Place finger over venturi and pull through a stroke watching fuel come up the fuel line. Once the fuel is at the nipple, don't continue to pull choke. A small prime in the cylinder port and a quick flip should get the engine coming to life. Ken
Post  crankbndr Thu Jul 26, 2012 12:56 pm
Here is some of those 7-3.5s.
http://www.ebay.com/itm/251116728620?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_1225wt_1398
Post  gcb Fri Jul 27, 2012 10:31 am
glow hed works , and engine as killer compresion. Can you guys give me some tips for when i go to start this engine, also what kind of rpm's should i expect with 30% nitro
thanks
Any prop in the 7x3-8x3 range will work. You might consider the larger size for the first few rich runs. If you go for the smaller size, consider flipping it backwards and let it fire against compression (without flipping it over the top)...especially if you use exhaust priming.
Factory instructions using the gray 7x3.5 prop and Cox competition fuel lists RPM at 17,750.
Since it is a 50 year old design, don't use a very small prop and expect to match RPM of todays engine. It is a very powerful engine and used within design parameters should provide you with good service.
If you are flying it CL, something around a Flite Streak Jr. or a SIG Akromaster should be a good match.
gcb
gcb
Post  mitchg95 Mon Jul 30, 2012 9:55 pm
thanks
it came with a zonger 7x3 prop, i may build a flight streak jr or a sig akromaster in the future
thanks for the tips, 17,750 sounds good to me Smile
mitchg95
mitchg95
Cox TEEDEE .09 Empty re: Gnat
Post  happydad Mon Jul 30, 2012 10:31 pm
thanks
so mitch when is the maiden flight of the Gnat?? video please? "and remember the only thing to fear is fear itself" roosevelt?? happydad. Biplane
Futaba Radio RC Plane
happydad
happydad
Post  mitchg95 Mon Jul 30, 2012 10:33 pm
happydad wrote:
thanks
sometime soon i hope, its sitting on my book shelf right now
mitchg95
mitchg95
