by getback Today at 5:25 pm
» Ode to a dead cat
by rdw777 Today at 3:28 pm
» COX .020 RC PROJECT
by rdw777 Today at 3:21 pm
» Peewee power
by rdw777 Today at 3:04 pm
by rsv1cox Today at 8:53 am
» some pics....
» Thrust Washer
ok cub co2 engine size
how can i tell the size of this engine?
thanks
thanks
mitchg95- Diamond Member
Re: ok cub co2 engine size
Technically speaking, its a motor, not an engine. That should stir things up!
daviddiag- Silver Member
good point, still there is a Piston, Crank case, Crankshaft, and Cylinder
Pi times radius square times stroke will give you displacement, as you know. Measuring bore would be simple enough. measuring the stroke would be difficult, as cylinder head does not appear to be removable. What a sweet little motor! Have you run it yet?
i need to find a 8g co2 cartridge for it, the cylinder head is not removable as the cylinder head is part of the cylinder as one whole piece
How about this?
http://www.ebay.com/itm/10-8g-CO2-soda-chargers-8-gram-C02-seltzer-cartridges-sparklets-carbonated-water-/160720096408?pt=LH_DefaultDomain_0&hash=item256baa0c98#ht_1218wt_1041
those might just work, ill try to get my old man to order them later tonight
this might help, the piston even has a wrist pin
Mitch,
Did you just unscrew the cylinder by hand? I haven't tried to disassemble mine yet, but I would love to check out the inards.
Be careful when you run it as your reassembly might leave the cylinder in such a position that the ball check valve is almost always pressed out of its seated position. As stated, this might cause a frozen piston upon charging. Be sure to start high and screw it down only a quarter-turn at a time. I'm sure you already know this, though. It's just a thought...
KP
KP
kpriddle- Bronze Member
Mark Boesen wrote:The OK CO2 'engine' was a .019, intro'd in '61, used .024 crank.
so its a .019?
i used a cox .09 wrench (the part that is used for the carb body)
awesome i ordered the co-2 cartidges that Mfd posted the link to, so hopefully these will work. I definetly want to run this engine
can i use 3 in 1 oil?
re: old man
mitchg95 wrote:those might just work, ill try to get my old man to order them later tonight
be nice to us old men. i have RC cars to. big ones. LOL hd
happydad- Rest In Peace
lol, ya. Im glad he ordered the co-2 cartridges
3 in 1 is 20 weight. Way thicker than Singer or any other sewing machine oil.
ok, ill look for Singer oil
Or any brand of sewing machine oil. MMO might be okay too.mitchg95 wrote:ok, ill look for Singer oil
cool, ill look the next time im at the store
But it's still motor. Its motive force is created outside the machine.mitchg95 wrote:good point, still there is a Piston, Crank case, Crankshaft, and Cylinder
Mitch,
Remember that you can also use air tool oil or even light bicycle oil. If you are looking for the sewing machine oil, I found mine at Jo-Ann's Fabric and Craft store.
Good luck,
KP
Good luck,
KP
kpriddle wrote:Mitch,
Good luck,
KP
Harbor freight has some air tool oil at a very decent price. I use it along with sewing machine oil as after run for my Coxes. Sewing machine oil is supposed to very light and slippery opposed to other oils.
Couple of comments:
I think the OK CO2 motor was introduced in ~1951, perhaps the '61 is a typo.
The fins are for heating, otherwise the engine would freeze up (literally).
Mine, unfortunately, does not have the cartridge holder.
gcb- Platinum Member
wow '51 this thing is sweeter every time i think about it
» fox engine size, help
» What size is this engine?
» Size of battery needed for Ignition Engine - O&R 60
» Need advice re. engine size
» Engine size and pulling power
