Cox Pusher Props Cox_ba12
Cox Pusher Props Pixel
by Ken Cook Today at 3:23 am
Cox Pusher Props Empty
Cox Pusher Props
Cox Pusher Props Empty Cox Pusher Props
Post  Godsey3.0 Mon Mar 26, 2012 8:49 am
Hello. I recently bought a CL kit that will require a Cox engine set up as a pusher. Rather than get new spring and run my engine backwards, I would just like to get a 5x3 pusher prop. I checked exmodelengines.com and coxengines.com, neither have the fore mentioned prop. They only have three blades. Anyone out there have one I can buy?
Godsey3.0
Godsey3.0
Cox Pusher Props Empty Re: Cox Pusher Props
Post  Godsey3.0 Mon Mar 26, 2012 9:24 am
I actually just found this one on Bernie's ebay store. 390370583339
Godsey3.0
Godsey3.0
Post  WingingIt74 Mon Mar 26, 2012 10:03 am
Could use it as one, just mount it backwards on the engine.
Cox Pusher Props $(KGrHqJHJC4E7BcvgD)MBO2qETc4-g~~60_3
Here is the same, but normal rotation
Cox Pusher Props Cox%20049%205%20x%203%20saftey%20tip%20propeller%201
WingingIt74
WingingIt74
Post  Godsey3.0 Mon Mar 26, 2012 10:31 am
Pv: If you look at it you can tell it is a pusher
Godsey3.0
Godsey3.0
Post  Cox International Mon Mar 26, 2012 6:58 pm
WingingIt74 wrote:Could use it as one, just mount it backwards on the engine.
um... no... definitely a tractor prop. The image was digitally flipped so that we have two different ones but I can see what problem that causes lol.
Cox International
Cox International
Official Cox Dealer
http://www.coxengines.com
Post  Godsey3.0 Mon Mar 26, 2012 7:53 pm
So Bernie, do you have a 5x3ish prop for sale? I rather not do three blade. 5x4, 6x3 and all those work good too.
Godsey3.0
Godsey3.0
Post  Cox International Mon Mar 26, 2012 8:09 pm
Godsey3.0 wrote:So Bernie, do you have a 5x3ish prop for sale? I rather not do three blade. 5x4, 6x3 and all those work good too.
We have no real pusher props for sale, only a LH 3-blade that can be mounted hub-reversed and run RH to arrive at a pusher configuration.
We also have a 6X2 LH that can be used in this fashion (the one that was used on the PT-19) but do not have it listed because the surface fishish shows hairline cracks when bent.
The prop is solid and is break-resistant but should be boiled before first usage to get rid of this crackling.
They would cost 10 for $4.95.
Cox International
Cox International
Official Cox Dealer
Post  Godsey3.0 Mon Mar 26, 2012 8:29 pm
A 6x2? How well will that perform for CL?
Godsey3.0
Godsey3.0
Post  Cox International Mon Mar 26, 2012 10:41 pm
Godsey3.0 wrote:A 6x2? How well will that perform for CL?
That's what they were designed for; hight rate of climb, stunt and performance.
Cox International
Cox International
Official Cox Dealer
Cox Pusher Props Empty A 6x2 tractor prop?
Post  RknRusty Tue Mar 27, 2012 2:15 am
I want a 6x2 tractor prop. Anyone know if there is any place I can get a few of those?
I see APC has what they call a 6x2 free flight prop. Any reason that wouldn't make a good stunt prop? I wonder how well a 2"pitch prop would work if I cut it down to 5.5" or 5.25."
Post  Cox International Tue Mar 27, 2012 9:17 am
RknRusty wrote:I want a 6x2 tractor prop. Anyone know if there is any place I can get a few of those?
Cox International
Cox International
Official Cox Dealer
Post  nitroairplane Tue Mar 27, 2012 9:42 am
they call it that because they are commonly used for .049 ff planes.
nitroairplane
nitroairplane
Post  WingingIt74 Tue Mar 27, 2012 9:44 am
Cox International wrote:um... no... definitely a tractor prop. The image was digitally flipped so that we have two different ones but I can see what problem that causes lol.
Bernie, you better check that, the text in both pics are correct and not just flipped/mirrored.
WingingIt74
WingingIt74
Post  RknRusty Tue Mar 27, 2012 9:54 am
Oh, I misunderstood. I thought LH meant pusher. So I can e-mail Nichole and get some of those. 10 should be a lifetime supply. Thanks Bernie.
Post  Cox International Tue Mar 27, 2012 11:07 am
LH = Left Hand, meaning you will need to run the engine counterclockwise, which all Cox reedies do.
I will pull the box from storage and list some tomorrow but you can email Nichole and she will take care of you.
Cox International
Cox International
Official Cox Dealer
Post  PV Pilot Tue Mar 27, 2012 11:10 am
I might grab a 5 pack of those also.
Put all them up Bernie, with the no guarantee wording and boiling suggestion. can't sell them if they are not shown,,but I understand your concern as well.
PV Pilot
PV Pilot
High Tech Balsa Basher
Post  Cox International Tue Mar 27, 2012 11:10 am
It's a vertical mirror-flip through photoshop. The COX HOBBIES INC is the give-away. Cox never made a pusher 5x3 safety tip prop.
Cox International
Cox International
Official Cox Dealer
Post  Cox International Tue Mar 27, 2012 11:31 am
Here is the listing:
http://coxengines.ca/cox-.049-propeller-left-hand-pusher-6-x-2.html?&cat=9
69 cents each (minimum order quantity = 5) or 10 for $4.95 if you email Nichole.
Cox International
Cox International
Official Cox Dealer
Post  RknRusty Tue Mar 27, 2012 6:47 pm
Unfortunately, I'm running a Tee Dee and a Medallion. I guess I'm stuck with the APC free flight props. I hear APC is really good if you can avoid getting cut. Since I'm anticoagulated, I think I'll be extra careful.
Post  Godsey3.0 Tue Mar 27, 2012 7:19 pm
Hey Bernie, what will shipping be on 10 props? Typical 3.95?
Godsey3.0
Godsey3.0
Post  Cox International Tue Mar 27, 2012 7:50 pm
Our shipping costs ( C & P from our website):
Our shipping costs belong to the lowest in the industry and we are pleased to provide flat-fee shipping. Maximum shipping costs are as follows, regardles of how many items you order:
•USA: $3.95 ($1.45 if under 5 mm thick)
•International : $5.95 ($1.95 if under 5 mm thick)
•Canada: $9.95 ($2.95 if under 2 cm thick / $0.95 if under 5 mm)
Exceptions for RC sets:
•USA and Canada: $9.95
•International : $19.95
Exceptions for airplane kits:
•USA: $12.95 ($19.95 for Banana)
•Canada: $14.95 ($19.95 for Banana)
We ship within 24 hrs, Monday to Friday, excluding holidays. Our shipping cost includes professional packaging, 100% recycled fibre bubble mailers, as well as insurance to full value of the merchandise.
Cox International
Cox International
Official Cox Dealer
Post  Godsey3.0 Tue Mar 27, 2012 8:07 pm
Bernie, I will be ordering 5 6x2 props tomorrow. Would tonight but the account is 1 cent short. Lol. Will load up account and get it sent.
Rolla
Godsey3.0
Godsey3.0
Post  Cox International Wed Mar 28, 2012 3:46 pm
Just out of curiosity, where did you find that top picture as I am unable to find it in our store?
Cox International
Cox International
Official Cox Dealer
Post  Godsey3.0 Wed Mar 28, 2012 3:56 pm
http://item.mobileweb.ebay.com/viewitem?itemId=390370583339&kw=390370583339
Took me awhile to find it the first time
Godsey3.0
Godsey3.0
Post  WingingIt74 Wed Mar 28, 2012 3:56 pm
Cox International wrote:Just out of curiosity, where did you find that top picture as I am unable to find it in our store?
http://www.ebay.com/itm/390370583339
WingingIt74
WingingIt74
