TD .049/Medallion .049 differences - Page 2 Cox_ba12
TD .049/Medallion .049 differences - Page 2 Pixel
by rsv1cox Today at 10:07 am
TD .049/Medallion .049 differences - Page 2 Empty
Page 2 of 2 Previous  1, 2
TD .049/Medallion .049 differences - Page 2 Empty Re: TD .049/Medallion .049 differences
Post  mitchg95 Tue Mar 13, 2012 4:28 pm
Puffie40 wrote:If you look closely, you can see some flaws in the data that show some inconsistency. For instance, one medallion uses 30% nitro and the TeeDee used 25% nitro, while the rest use 15%. The difference in years will also affect data as well.
There is a margin of error here that I would say renders this chart unusable for power output.
I think if you set up a test stand and test all the motors at the same time, with the same fuel, that the motors will start to appear to put out the same power. The Tee Dee would have a higher power band, but I would think it should be closer to the others in power output.
cribbs74 wrote:
Surfer_kris wrote:It's all about horse power and bragging rights as usual...
TD .049/Medallion .049 differences - Page 2 Cox_performance_2
Lol Kris,
True, numbers don't lie. My position is that both are very good engines. What makes them better to one person may not be so for the next.
Based on pure stand alone performance the TD is clearly the winner.
i caught that two puffie40, someone should do this cox engine power graph with all the same settings, ie the same fuel content and the same size prop
mitchg95
mitchg95
Post  Cribbs74 Tue Mar 13, 2012 4:43 pm
SuperDave wrote:Similar but in so many ways different.
The former being more highly regarded than the later.
I'd like start a discussion as to why. You first. This could be very informative for all.
Dave,
I totally mis-interpreted the original intent of your post. In my clouded brain I thought you were touting the superiority of the TD over the Medallion. I see now that I was mistaken. You were actually attempting to drum up some good discussion. So publicly I would like to say "Sorry" to you. In true SuperDave fashion you kept the conversation going even when it went way off topic. Thanks for the good post and I will try not to do that again!
Post  Surfer_kris Tue Mar 13, 2012 4:46 pm
Yes sure, there would be some minor differences to those curves depending on the fuel etc. But the graph shows most of the important trends very clearly. The early Babe Bee with a single transfer (and small venturi bore) are down on power compared to later bee's with dual transfers and larger bore (killer bee). All reed engines have an upper limit though in the rpm where the reed is the limiting factor. To get higher power you need a higher operational rpm and that's what you get with the TD (large intake and a large bore in the crank).
The medallion has a better fuel draw and makes for a better sports engine than the TD which is all about maximum HP and needs pressurized fuel delivery etc.
Surfer_kris
Surfer_kris
Post  SuperDave Tue Mar 13, 2012 4:50 pm
"i caught that two puffie40, someone should do this cox engine power graph with all the same settings, ie the same fuel content and the same size prop" - mitch
Mitch: Remember that differenent engines are designed for different purposes. What is good for one may not be good for others. Smile Not all engines are "created" equal.
SuperDave
SuperDave
Post  nitroairplane Tue Mar 13, 2012 4:51 pm
SuperDave wrote:"i caught that two puffie40, someone should do this cox engine power graph with all the same settings, ie the same fuel content and the same size prop" - mitch
Yup you won't win a texaco event with a mouse racer :-)
nitroairplane
nitroairplane
Post  mitchg95 Tue Mar 13, 2012 4:54 pm
good point, although it would be funny to see someone try
mitchg95
mitchg95
Post  nitroairplane Tue Mar 13, 2012 4:56 pm
Well I mean with the right prop yo could definitely climb quicker Smile
nitroairplane
nitroairplane
TD .049/Medallion .049 differences - Page 2 Empty chart value
Post  fredvon4 Tue Mar 13, 2012 5:34 pm
I think the nitro content is one variable that is not normalized and makes the chart unreliable. That is unless you had read the original MAN or Aero Modeler text. IIRC they did try to have a standard prop dia and pitch but I cannot attest to that.
I have operated several motorcycle and large full chassis dynos and fully understand the variables and relationships to HP, a calculated value, and Torque a direct measured value.
I personally think the chart is of little value for true comparison other to note that there are differences and the TD does have a more robust power band.
I dare say you could take the same engines and tune each to the correct nitro and prop combination to bring all .049s in the series to very close maximums and the anomalous TD reading would not be a distinctly different
One of the current magazine writers uses a computer controlled engine test stand that measures thrust, cyl head temp, rpm, and barometric pressures. I trust his/those comparisons much more than the simple tests from the 60s
Back to the topic... I believe the TD series included a 128TPI NVA while the Medallion series used the standard coarser thread NVA
Post  nitroairplane Tue Mar 13, 2012 5:36 pm
No the medallions used a fine thread needle it is killer bee compatible.
nitroairplane
nitroairplane
Post  Surfer_kris Tue Mar 13, 2012 5:50 pm
Yes, there is more info to read in each individual test (including rpm readings for different props). I really like the performance curves though and the direct comparison between the different cox engines. The TD was by far the strongest .049 engine at the time (here with an even higher power than the tests shown above);
TD .049/Medallion .049 differences - Page 2 Scan1010
Surfer_kris
Surfer_kris
Post  SuperDave Tue Mar 13, 2012 6:16 pm
Ta da!
"I'd like start a discussion as to why. You first. This could be very informative for all." - SD
Have I accomplished my mission????
SuperDave
SuperDave
Post  Surfer_kris Tue Mar 13, 2012 6:26 pm
I don't know, is there any new information here?
Surfer_kris
Surfer_kris
Post  SuperDave Tue Mar 13, 2012 6:35 pm
Kris:
If this forum were only about "new information" it would not be as active as it is. For anyone new to the Cox hobby 'recyled" information is helpful.
Smile and be happy! Very Happy
SuperDave
SuperDave
Post  microflitedude Tue Mar 13, 2012 6:41 pm
Educate the newbies!
And that includes me. Very Happy
microflitedude
microflitedude
Post  dckrsn Tue Mar 13, 2012 6:41 pm
I guess it depends on the reader.
I'm sure there are some newbies who gleaned plenty
of info that was new to them.
I like Dave's idea of getting more Cox knowledge out
there for everyone to absorb, even if it seems pedestrian
to some of us. Smoking
Mission acomplished. Beer Cheers
Post  mitchg95 Tue Mar 13, 2012 6:46 pm
microflitedude wrote:Educate the newbies!
+1, i want to find out more
mitchg95
mitchg95
Post  nitrosmeller Tue Mar 13, 2012 8:38 pm
try this link for more information:
http://en.wikipedia.org/wiki/Cox_model_engine
it is warrens site
nitrosmeller
nitrosmeller
