5-40 1 inch torx allen head phillips Cox_ba12
5-40 1 inch torx allen head phillips Pixel
by batjac Today at 9:47 pm
by roddie Today at 8:50 pm
by rdw777 Today at 5:07 pm
by rdw777 Today at 4:51 pm
by getback Today at 12:05 pm
5-40 1 inch torx allen head phillips Empty
5-40 1 inch torx allen head phillips Empty 5-40 1 inch torx allen head phillips
Post  nitrosmeller Fri Mar 09, 2012 5:28 pm
hey guys what links do you have for bulk purchases of 5-40 prop bolts for cox?
nitrosmeller
nitrosmeller
5-40 1 inch torx allen head phillips Empty Re: 5-40 1 inch torx allen head phillips
Post  PV Pilot Fri Mar 09, 2012 5:42 pm
Tonys screws llc. Pick up the buttonheads, the give a better profile to the oem alum cox spinners. Grade 8+ and top quality black oxide.
PV Pilot
PV Pilot
High Tech Balsa Basher
Post  andrew Fri Mar 09, 2012 7:41 pm
I use McMaster-Carr for lots of different things, screws, taps, dies, bits. You name it and they usually have it. Good pricing and reasonable shipping.
http://www.mcmaster.com/#socket-head-cap-screws/=glf426
Post  RknRusty Fri Mar 09, 2012 8:51 pm
andrew wrote:I use McMaster-Carr for lots of different things, screws, taps, dies, bits. You name it and they usually have it. Good pricing and reasonable shipping.
That's a good link thanks. Anybody know what's the longest that will fit through the spinner and prop without bottoming out in the crank?
Post  andrew Fri Mar 09, 2012 9:53 pm
Rusty --
I've got a metal backplate BW with OEM red spinner --- the prop screw is 1". With a prop in place, it will tighten down w/o bottoming out, but does screw almost all the way in.
For several years, I've been replacing the OEM prop screws on both my COX and NORVEL engines with socket head bolts and I cut them to length so that they nearly bottom out when the prop is tight. I bulk buy one longer length and resize as needed. My reasoning was that it reduced the tension stress on the end of the crank and also helped fill the void from the screw hole in the crank. After reading that Paul G. used a stud that bottomed out, I felt vindicated from being a little weird about it.
I also like partially threaded bolts (where the shank near the head is not threaded) because the spinner (COX and NORVEL) fits a little more tightly and the prop is also snug.
Post  RknRusty Fri Mar 09, 2012 10:27 pm
andrew wrote:
Rusty --
I agree, that's why I asked about it. I think I'll get some 1.25" hex bolts. I would rather have hex button heads, but the heads would be too wide, and I don't want to mess with prop screw heads on my clumsy bench grinder.
Post  PV Pilot Sat Mar 10, 2012 1:38 am
Tonys screws buys in bulk from Mcmaster-carr. He can get the shouldered screws as well.
Fwiw
PV Pilot
PV Pilot
