» Jim Walker Bonanza etc.
by Ken Cook Today at 5:03 pm
by rdw777 Today at 2:52 pm
by rsv1cox Today at 10:52 am
by roddie Today at 10:30 am
by roddie Today at 10:02 am
by TD ABUSER Today at 9:25 am
» 1940's?...............
by rsv1cox Today at 7:46 am
» Lesson learned
August-2024
reduce rpm with carb restictor?
I am currently performing some experiments with my testors mccoy 049 and I need to slow it down some. Its over reving even with a 6x3 windsor prop. Has anyone had any experience on this?
chevyiron420- Gold Member
Re: reduce rpm with carb restictor?
I've often thought of doing the exact same thing..maybe a small washer over the venturi opening and then retune the needle.
Michpatriot- Gold Member
chevyiron420 wrote: I am currently performing some experiments with my testors mccoy 049 and I need to slow it down some. Its over reving even with a 6x3 windsor prop. Has anyone had any experience on this?
I don't know what the venturi looks like on a Testors McCoy 049 but on the Enya engines there is a sleeve tht slips into the inside if the venturi to reduce the intake size.
Maybe this could be done with your McCoy 049 with a piece of brass tubing?
See or find a way to slip a brass sleeve into the venturi?
If I remember correctly the needle valve assembly doesn't come out of the venture because it's press in?
Cut a slot in the brass tubing to maybe slip over the needle valve assembly in the venturi?
You could leave the tubing sticking out from the venturi and add smaller brass tubing in the section sticking out until you get the speed you want while inserting small and smaller tubing in the original tubing sticking out of the venturi?
sosam117- Diamond Member
Try and add a head gasket or two. Drop your nitro to 10% and increase your oil to 25%. It will certainly drop the rpm's without compromising the fuel running through the engine that keeps it cool.
» How to pre-heat NV cylinder in the field to reduce TDC pinch
» WTB TD .09 RC Carb
» Tarno 1/2 AR details
» tee dee carburator
» alu. carb body
» alu. carb body
