» Tee Dee .020 combat modelby getback Today at 7:14 am
by getback Today at 7:02 am
Need help with Cox .049 engine
Hello everyone, a friend of mine gave me some old control line models that came with a cox .049 engine but it is seized, any way I can fix this? I have taken it apart and oiled it but it still won't work.
DeHavilland- New Member
Re: Need help with Cox .049 engine
Here is a link to some engine guides, incl. a troubleshooting chart:
http://coxengines.ca/pages.php?pageid=19
DeHavilland wrote:Hello everyone, a friend of mine gave me some old control line models that came with a cox .049 engine but it is seized, any way I can fix this? I have taken it apart and oiled it but it still won't work.
Apart from the troubleshooting guide from CI you may want to familiarize yourself with the engine type as to the specific starting method, most Cox engines start the same though. Engine manuals also found at the aformentioned link.
Suggest going to the Trouble Shooting Guide provided by Cox International. The topic has been covered many times in our "search" file.
The engine is likely seized by castor oil residue which is not at all uncommon in engines that haven't been run in some time. Hoppe's #9 gun cleaning solvent works very well to loosen "frozen" Cox engines. Let it soak in then turn the crankshaft back and forth in small increments.
Would need to know the type and displacement of the Cox engine to give further details.
SuperDave- Rest In Peace
Ok thanks for the help, The troubleshooting guide said to soak it in fresh fuel overnight so I think I will try that.
Is the engine still seized? You said you took it apart.
DeHav:
The key is to let the solvent SOAK in and that takes time possibly days. Be patient.
The good news is that, depending on the type of Cox engine you have, there are an abundance of parts available from our several vendors.
I did take apart mostly, the only problem is I can't get the piston out of the cylinder.
DeHavilland wrote:I did take apart mostly, the only problem is I can't get the piston out of the cylinder.
Don't use force to get it out. Put solvent in the cylinder an let it soak. The crankshaft may be frozen too, same problem same solution. Do you have Cox wrench to remove the cylinder head? Don't try it without or you'll likely damage a cooling fin. Do NOT use pliers!
(We can get you through this if you follow our suggestions)
The piston might loosen up with a heat gun or a hair dryer. Soaking is probably best. Hopefully the piston hasn't shared any oxidation with the steel cylinder. If it has rust, it'll be best to get a new piston/cylinder set.
Scroll down this page for choices:
http://coxengines.ca/home.php?cat=27
This is a Cox .049 wrench need to disassemble them properly:
See details
Cox .049 Wrench
SKU: 490WREN
Our price: $ 3.95
Buy Now
See details
Cox .049 Wrench
SKU: 490WREN
Our price: $ 3.95
Buy Now
» *Cox Engine of The Month* Submit your pictures! -June 2018- *ENGINE GIVEAWAY*
» **Black Lynx Engine Giveaway June 2017** Cox Engine of the Month
» **Black Lynx Engine Giveaway June 2019** Cox Engine of the Month
» **Black Lynx Engine Giveaway Jan-June 2022** Cox Engine of the Month
» *Cox Engine of The Month* Submit your pictures! -December 2016- *ENGINE GIVEAWAY*
