Missing lugs on tank backplate Cox_ba12
Missing lugs on tank backplate Pixel
by getback Today at 7:14 am
by getback Today at 7:02 am
Missing lugs on tank backplate Empty
Missing lugs on tank backplate Empty Missing lugs on tank backplate
Post  WingingIt74 Sun Feb 26, 2012 8:07 am
Has anyone ever come up with a solution to missing lugs, besides buying a new backplate?
WingingIt74
WingingIt74
Missing lugs on tank backplate Empty Re: Missing lugs on tank backplate
Post  Kim Sun Feb 26, 2012 8:13 am
WingingIt74 wrote:Has anyone ever come up with a solution to missing lugs, besides buying a new backplate?
Seemed like that subject came up somewhere here or on the other group. Involved making up an aluminum plate with lugs to bolt to the back of the original backplate with screws through it from inside. OR...I just dreamed I read it...hard to tell sometimes...
Post  WingingIt74 Sun Feb 26, 2012 8:21 am
I was thinking of something along those lines...
WingingIt74
WingingIt74
Post  Kim Sun Feb 26, 2012 8:27 am
yeah...I got a really messed up backplate...was gonna try that...not like there's anything to lose. I was gonna go with an oval shape with two holes like the Atwoods and Hornets...
Post  SuperDave Sun Feb 26, 2012 8:30 am
If there is a remaining fragment of the lug a small flat washer could grip the remaining portion then attach the washer/lug with a screw or bolt.
Or just pretend the broken lug doesn't bother you. Laughing
SuperDave
SuperDave
Post  Kim Sun Feb 26, 2012 8:41 am
SuperDave wrote:If there is a remaining fragment of the lug a small flat washer could grip the remaining portion then attach the washer/lug with a screw or bolt.
Or just pretend the broken kug doesn't bother you. Laughing
Yeah...that'd work as long as there IS a nub, and the others are in fairly good shape. I got a REALLY tortured backplate (not the one in the photo) that may get messed with. Looks like there IS space on either side, outside the webbing between the screw holes, where a small screw could fit...
Missing lugs on tank backplate Pee_we10
Post  SuperDave Sun Feb 26, 2012 8:48 am
It should be noted by our "newbs" that the pickup tube in Kim's photo is in the control line position.Missing lugs on tank backplate 3929217648
SuperDave
SuperDave
Post  Kim Sun Feb 26, 2012 8:50 am
Yo Travis...trying to join your forum...there's no verification code coming up...is it me or the site? Also, if you'll PM your name over there...I'll give you credit for directing me there !
Post  Kim Sun Feb 26, 2012 8:53 am
SuperDave wrote:It should be noted by our "newbs" that the pickup tube in Kim's photo is in the control line position.Missing lugs on tank backplate 3929217648
Good Point !!!
Post  WingingIt74 Sun Feb 26, 2012 9:14 am
Good Point !!!
Your right, never thought of it being that way.
WingingIt74
WingingIt74
Post  Cribbs74 Sun Feb 26, 2012 9:26 am
Seems to me that an aluminum backplate affixed with the tank securing screws would work. The problem would be making it leak proof and drilling a venturi hole. I have some clapped out pee wee backplates that could benefit from this type of mod. Some are a bit warped so sealing the new mount to the backplate may be tricky.
Post  Kim Sun Feb 26, 2012 9:52 am
cribbs74 wrote:Seems to me that an aluminum backplate affixed with the tank securing screws would work. The problem would be making it leak proof and drilling a venturi hole. I have some clapped out pee wee backplates that could benefit from this type of mod. Some are a bit warped so sealing the new mount to the backplate may be tricky.
Yeah, maybe a piece of tubing on the screws between the new plate and backplate...
Post  RknRusty Sun Feb 26, 2012 9:58 am
Kim wrote:Missing lugs on tank backplate Pee_we10
I've never seen a backplate with internal webbing like that. It's not a Babe Bee is it?
Post  Kim Sun Feb 26, 2012 9:59 am
Nope, it's an .020 all right...
Post  Mike1484 Sun Feb 26, 2012 10:31 am
Clamp it in a vice and screw the vice on the plane.
Mike1484
Mike1484
Mike1484
Post  Kim Sun Feb 26, 2012 10:33 am
Mike's seen my handiwork....
Post  Mike1484 Sun Feb 26, 2012 10:56 am
Just kidding around about the vice . For all the trouble and cost in time and money of trying to rectify the broken lugs it would seem that a spare motor or two ( parts motors ) picked from a swap shop or fellow modelers would be a better solution. I don't remember the thread of the back plate screws but maybe threaded rod with nuts silver soldered on to the proper lenth and leaving extra threaded rod past the nut would give you something to hang the motor with. Or clean the back plate surface well and rough it up and glue on some 1/16" aluminum with a good structural epoxy and make new holes. Allow for the tank screws and venturi hole.I would look for the parts motor myself.
Mike1484
Mike1484
Mike1484
Post  Kim Sun Feb 26, 2012 11:08 am
Mike1484 wrote:Just kidding around about the vice . For all the trouble and cost in time and money of trying to rectify the broken lugs it would seem that a spare motor or two ( parts motors ) picked from a swap shop or fellow modelers would be a better solution.
Mike1484
Ah...t'would be a better choice...where it not for my Calvin & Hobbs 'esk disdain for Linear Logic !
Post  SuperDave Sun Feb 26, 2012 11:15 am
With I modeling vice attached I'd opine that there would be serious CG concerns. Wink
SuperDave
SuperDave
Post  Kim Sun Feb 26, 2012 11:48 am
SuperDave wrote:With I modeling vice attached I'd opine that there would be serious CG concerns. Wink
True...AND the flight would definitely require at least 35% fuel !
Post  fit90 Sun Feb 26, 2012 12:01 pm
Yeah, but think about how strong your arm would be after a season of hand launching it.
fit90
fit90
Post  dckrsn Sun Feb 26, 2012 1:43 pm
Travis,
Pm your address and it's yours.
Missing lugs on tank backplate 00118
Post  WingingIt74 Sun Feb 26, 2012 1:50 pm
Thanks Bob, I owe you one!
WingingIt74
WingingIt74
Post  fredvon4 Sun Feb 26, 2012 2:54 pm
Decades ago on Taiwan Island young me managed to dig dirt with most 049 powered airships. Broken ears were common. Took a very long time for new $3.50 Cox stuff to row the boat to our door front. My dad made a Image of the 049 back plate on a block of wood and carved out the shape. He sanded the back of the plate, cleaned it very good with MEK, mixed up some JB weld, used bees wax for release in the carved wood block, added the JB weld to each corner in the mold, and set the broken backplate in to the mold. sand paper, Small files, drill out hole, and poof...new ears!
Or you could buy these for $5.00, sand/grind smooth and JB weld to back of broken backplate
[img]Missing lugs on tank backplate Cox_0411[/img]
Ebay
http://www.ebay.com/itm/Cox-049-Space-Bug-Model-Airplane-Engine-Backplate-Cover-/380402640317?pt=LH_DefaultDomain_0&hash=item5891c3a5bd
Last edited by fredvon4 on Mon Feb 27, 2012 11:37 am; edited 1 time in total (Reason for editing : spelling)
Post  civillian Sun Feb 26, 2012 3:25 pm
Very resourceful and clever![b][i][u]
civillian
civillian
Beginner Poster
Beginner Poster
