» Tee Dee .020 combat modelby getback Today at 7:14 am
by getback Today at 7:02 am
The truth about .051 Medallion pistons
I promised to research the subject so I took apart a Tee Dee .051 and a Medallion .051 and, yes, the pistons are different from each other.
Piston height:
TD - 10.26mm
MD - 10.20mm
Score at bottom:
TD – Wide
MD – Narrow
Piston diameter:
10.40mm on both
However, the MD piston has an OD marginally bigger than that of the TD one as the MD piston jams ½ way up the TD cylinder. My electronic callipers only measure to 1/100th of a mm tolerance.
What the above means is that the Medallion .051 pistons will only fit the .051 Medallion cylinder and not the .051 Tee Dee or .051 Killer Bee cylinders.
Piston height:
TD - 10.26mm
MD - 10.20mm
Score at bottom:
TD – Wide
MD – Narrow
Piston diameter:
10.40mm on both
Re: The truth about .051 Medallion pistons
thanks for the info
mitchg95- Diamond Member
Damn when mine arrives I'll have to get the Hammer out.
John Goddard- Diamond Member
Thanks for following up Bernie,
I have to ask though... Why?
Piston height I get, compression ratio mediallion TD etc. but, why the diameter difference for a sub 300 unit production run it doesn't make sense to do anything differently.
Just wondering, not questioning your findings.
John Goddard wrote:Damn when mine arrives I'll have to get the Hammer out.
Na, just have your machinist buddy modify the cylinder or piston. Or run a small wheel cylinder hone through the cylinder until it doesn't bind and do a good break in.
cribbs74 wrote:Thanks for following up Bernie,
My best guess is that the MD pistons and cylinders were honed in a special production run. I suspect the difference is only like 1/10,000" but enough to make the MD pistons incompatible. I tried a few times really hard to jam the piston in but no go. The TD pistons fits in nicely with the MD cylinder but I suspect compression will be lower.
Cox International wrote:cribbs74 wrote:Thanks for following up Bernie,
So I guess the advice I gave John will work then......
Makes sense Bernie especially if they were all hand made. Thanks!
» What are the differences (if any) between Cox .09 TD and Medallion pistons/cylinders?
» The Most powerful Cox engine EVER
» The postman came today
» Need your help with new product suggestions
» Resetting Pistons
» Resetting Pistons
