by gkamysz Today at 9:29 pm
by roddie Today at 9:22 pm
by rsv1cox Today at 3:38 pm
Modifying Medallion .09 & .15 Venturi to fit an Enya needle valve assem.
Things for modification:
For Cox .09 Medallion, you’ll need to order an Enya needle valve assembly, Part number 06211
That needle valve assembly is for the small Enya .06 engines.
For Cox .15 Medallion, you’ll need to order an Enya needle valve assembly, Part number 09220
This needle valve assembly is for the Enya .09-III engines.
Modifying the Cox .09 Medallion venturi
We’ll 1st start with the easiest venturi to do.
As you take out the .06-II needle valve assembly from the package, you’ll notice that it has two spray bar holes.
We want the holes 90° to the air flow coming into the venturi. So, we don’t see the holes when we look into the venturi.
Now we have two options here.
One is to carefully file into the one end of the spray bar into an octagon like how Cox has it in the venturi for a nice fit.
But remember you’ll have to file the correct orientation on that end (shoulder) to have the holes facing horizontal in the venturi.
I have used a pin-vice to hold the spray bar as I file the flats into the shoulder.
It is easy because my pin vice is octagon shaped and I can orientate it easy to the next face to file.
I have had this pin-vice for years and it was made by X-acto.
The other simpler way is to taper that shoulder so as you tighten on the nut on the other side it will lock it in and while tightening the nut you can orientate the spray bar holes the way they should be.
If you’re doing this method don’t forget the needle valve retainer spring.
I don’t like the 2nd method that much because you’re putting undue stress on the plastic venturi?
And may crack years down the road.
After you completed that side and “if” you did the taper of the other side you should see that the small groove part on the spray bar should be in the middle? I hope it is --- if done right?
Last is now to screw in the needle valve.
Now for the Cox .15 Medallion:
1st is which side the needle valve will be on?
That is the side where we completely remove the plastic “boss”.
Next is to remove the Enya .09-III needle valve assembly from the package.
Now for the other side of the venturi, we will cut a notch in it to accept the Enya spray bar.
This too you’ll have to watch for the orientation of the spray hole.
This one should be where the hole in the spray bar is facing down the venturi.
Next is to cut into the boss to make a slot for the Enya spray bar to fit into. As shown in the photo below.
Remove the plastic all the way down like in the other side where the spray bar will fit.
**** leave the little plastic "ears" as this will lock in the spray bar from turning when the nut is tightened on the other side.***
When done you should have two little plastic ears to orientate the spray bar and also to keep it from rotating when you tighten the nut on the other side.
The last thing to do now is to insert the needle valve retainer spring, screw on the nut and tighten it up and then screw in the needle valve.
If you have remove enough of the plastic "boss" (on both sides) the spray bar hole is in the middle of the venturi?
Modified venturi alongside OEM venturi:
The Enya .06-II and the Enya .09 spray bars are available from Bob Brooks.
Contact him directly at:
Bob Brooks
shtterman@aol.com
954-234-0863
If you purchase items from his store *bay charges him 10% so save you that 10% and contact him directly.
Bob takes Paypal and checks.
Last edited by sosam117 on Wed Feb 02, 2022 12:40 pm; edited 5 times in total (Reason for editing : added info on Bob Brooks (shtterman@aol.com & misspellings)
sosam117- Diamond Member
Re: Modifying Medallion .09 & .15 Venturi to fit an Enya needle valve assem.
How about he .49 Medallion?
Ummm...Sosam,
What about the .049 Medallion? Any good news there?
Thanks in advance.
Thanks in advance.
944_Jim wrote:Ummm...Sosam,
Thanks in advance.
I don't know if the same thing can be done on the .049 /.51 Medallion.
Never had to do one on an Cox .049 Medallion?
You might want to try to purchase the Enya .049 needle valve assembly?
That part number is the same as the Enya.06 assembly and see if you can replicate the same thing as the .09 and .15?
The Enya part number is: 06211
You should be able to order it from Bob Brooks (shtterman)
Or straight from Ken Enya's website?
Why would you do this though? Genuine question!
LostServoScrew- Bronze Member
Why? Because no where can these NVAs be purchased new, nor as just a used part. I just bought a stripped .09 Medallion specifically for the NVA. I'm quite embarrassed by how much I spent for a useless case, red venturi body and NVA. The guy tossed in the piston (or I didn't see it in the ad), but it is so useless that it's next life is as a key fob.
The 049 and 09 Medallions use the same spraybar and needle valve -and there seems to be an ongoing demand. Is it appropriate at this point to ask our masters..ie Cox International-if they have any plans to do a run of spraybars and needles?
There area LOT of Medallions out there.....and of course apparently sufficient demand for Mecoa to be making the actual plastic venturi housings....so why not the rest of the assembly? For example-any crash bad enough to break or damage the plastic venturi is almost certain to bend the needle valve at least-and these are usually hard or impossible to straighten accurately.....
ChrisM
'ffkiwi'
ChrisM
'ffkiwi'
ffkiwi- Gold Member
Chris,
You have no argument from me. But I would suggest the needle and or red body is what gets damaged during a lawn dart maneuver, not the spray bar. As you say, needles and bodies are still available.
My ignorance caused me to double down on twin RC engines, both .09 and .15. The price was too good, so I jumped at them very quickly. I really thought I beat the other guy.
While bench testing, my not-so-young eyes couldn't see the spray bar turning in one of the .09s. It just wouldn't adjust and run right. So I started working one of the .15s, and it behaved the same. I couldn't believe I had two duds back to back, so I stripped both down only to really see what I had. DOH! Face-Palm...not once, not twice...but all four. That's a pair of .09s, and .15s!
Thanks for the detailed instructions and cautions to retrofit an Enya NVA to the Medallions, @sosam117, and reason why @ffkiwi. I didn't know Cox was out-of-stock. In future when I need, now have the hip pocket info to do.
Recently I replaced a Testor's .049 front rotor NVA with a Cox Surestart horseshoe back NVA, but haven't tested it yet. It was the only way I knew how to fix a bungled NVA.
Converted a couple Testor's McCoy .35 Red Heads to rear NVA with an Evolution .46 rear NVA (1-inch bolt spacing fits the RH's & K&B .35 Stallion backplate spacing perfectly). Love the much finer threading, easier to dial in the right mixture.
But lo and behold, these are no longer available. China's Sanye factory closed its model engine manufacturing doors 2 years ago.
GallopingGhostler wrote:Thanks for the detailed instructions and cautions to retrofit an Enya NVA to the Medallions, @sosam117, and reason why @ffkiwi. I didn't know Cox was out-of-stock. In future when I need, now have the hip pocket info to do.
You can get the NVA very easy from Ken Enya (Enya website -- with part number), or MECOA or shtterman. (That's a good thing.)
» Medallion 09 Venturi + needle valve assembly
» Venturi Size .049
» Tee Dee & Medallion Venturi replacement
» need Tee Dee .15 venturi and needle valve assembly
» 049 reed valve venturi throttle
» Venturi Size .049
