Wall hanger 48" control line flaps P-51 with locked up Fox .35
Some might remember this, Mark found it at a flea market and called me to see if I wanted it. Sent me a picture. Buy it!!! I was hoping that it had an OS Max or Enya engine, or maybe even a Webra. But no, an off-the shelf castor locked Fox .35 with a loose propellor. Disappointed I stuck it on the wall and mostly forgot about it. Snowed in today, to windy to burn so I gave it a little love.
Ok installation on the engine but elongated mounting holes. Ok, it's a Fox. Apologies to Fox fans. Totally locked up including the needle. Got out the heat gun. Don't yell at me about the vice. I know the difference between snug and OMG!!! Just going to heat it up and spin the prop. Took some doing, didn't want to free-up easily. Used a little Remoil down the holes to spin it, then some drops of my horded Prather after run that is older than many here. I know it's older than Cribbs, he's such a kid.
I think this Fox .35 isn't enough engine for this 48" plane????????????? I forgot to weigh it, but it's no lightweight.
Re: Wall hanger 48" control line flaps P-51 with locked up Fox .35
The Fox is enough power for that plane. The Fox makes it's best power flying planes that size in fact my Oriental is over 55". The Fox also provides the best power when it's either mounted upright or inverted. The Fox you show can be questionable though. Yours is a 1980 version in which some were ok, some wore out before breaking in and some were short lived. In the later 80's around 1988 is when the 40th anniversary was introduced. These were some of the best of the best as these had slight taper in the cylinder and the fits were quite tight. In fact many were too tight rendering most to get rid of them. I have found many of these to be my best runners. Don't know why the needle valve is on the same side as the exhaust. I suppose the builder enjoys burning the hell outta his fingers.
Just curious Ken, on that 55" Oriental. How do you fly it? I'm thinking 52-60' braided steel lines and a solid handle. Also how is it set up? Minimum engine/rudder off-set for little line pull going straight rather that crabbing to the outside of the circle? Seems like it would be a bear to fly if it was always pulling you hard to the outside of the circle using more options than just centrifugal force.
Seems like it would take a big well planted man. Rusty (RIP) and I would be at a disadvantage.
» control line P-38
» Instant Control Line Flying! T-38 Talon Whip-Line from 2/70 M.A.N.
» Cox control line three line throttle
» fishing line to use for control line
» All day Control line fun!
