Cox special 045 tether car question Cox_ba12
Cox special 045 tether car question Pixel
by rdw777 Today at 5:07 pm
by rdw777 Today at 4:51 pm
by getback Today at 12:05 pm
Cox special 045 tether car question Empty
Cox special 045 tether car question Empty Cox special 045 tether car question
Post  Rosco Thu Jan 07, 2021 10:32 am
Hi all, I have a cox 045 engine case I purchased recently. The crankshaft is really seized. The cylinder, piston and planetary gears are removed. It looks like the crankshaft and flywheel should come out as a complete unit from the planetary side. Is that correct? Nothing appears to want to move. Can't seem to get it to move yet with soaking and heat. Just wondering if anyone has taken the crankshaft out. Not sure if it"s an old castor oil siez or overheat no oil seize. Help!
Rosco
Rosco
Moderate Poster
Moderate Poster
Cox special 045 tether car question Empty Re: Cox special 045 tether car question
Post  davidll1984 Thu Jan 07, 2021 11:34 am
Ok lets start have u try wd40 let sit in fuel Somting like that boill in preston engines coolent?? Dont aply force gentle Not only one side try difrent direction
Post  davidll1984 Thu Jan 07, 2021 11:39 am
Inspection on exaust port wat look like ? U have large thimble drome engines wit one smal gear on crankchaft or the one To place under the back of the cars wit sort of dif gear try turn once engine in one part cox o forty five tink Posible castor oil let him rest in fuel for the night try boil in preston
Cox special 045 tether car question Empty Cox o forty five
Post  davidll1984 Thu Jan 07, 2021 11:49 am
Cox special 045 tether car question Screen68
Post  Mudhen Thu Jan 07, 2021 3:58 pm
Mudhen
Mudhen
Post  Mudhen Thu Jan 07, 2021 4:22 pm
Mudhen
Mudhen
Post  crankbndr Thu Jan 07, 2021 4:52 pm
The only one I have was stuck big time, the hardest to free up of any of my Cox engines. I did not dissemble it other than the glow head and tires. It took multiple light oil and heat cycles with a heat gun. Just when I thought it would never free up it did and spins freely now. Good luck.
PS I think antifreeze will darken the cast case.
Post  Rosco Fri Jan 08, 2021 9:00 am
I will try heating the flywheel. I was heating the case. It's been soaking for a week in ATF and acetone mix. I wasn't sure how the flywheel attached to the crank. I can see now it's splined from your description and pics. I did a couple coolant boils and cools. no progress yet. I will try the alcohol and heat procedure you have recommended. It's a tough one. There quite the engine as for design. A neat little package. I purchased the case on e-bay just for some spare parts. Lots of parts missing, but the price was right. I may work on it today. Will give an update when it turns. Thank you all!
Rosco
Rosco
Moderate Poster
Moderate Poster
Post  Rosco Fri Jan 08, 2021 2:51 pm
OK, I put my little Torch On the flywheel this time, put a 1/4" dowel with a hole in the end of it and she started to move. Had to do this a couple of times because it was so gummy. flushed it with some acetone, blew it out, oiled and it spins like "new" What is the best way to remove the flywheel? Is the gear on the end of the flywheel part of the flywheel? I see splines on the crank. Not sure how to remove the flywheel safely. Some engineer put alot of time and effort into this little motor.
Rosco
Rosco
Moderate Poster
Moderate Poster
