DIY: Disposable Epoxy Brush
Levent Suberk- Diamond Member
Re: DIY: Disposable Epoxy Brush
Where did you find such small foam tubes? I just installed a fuel line down the tunnel of a Volkswagen bug, and need to provide some "anti-rattle" material to the line. Your foam tube looks like just the right size!
TIA
TIA
I bought that pipe foam insulation from an ironmonger. You can find it:
https://www.homedepot.com/p/Everbilt-3-4-in-x-6-ft-Foam-Semi-Slit-Polyethylene-Pipe-Insulation-ORP07812/204760801
I think that they made from same material.
Re-purposing! I'm a fan of that. Would probably form a nice neat fillet too.
I save small plastic lids to use as epoxy mixing palettes. The ones shown below are from potato-chip tubes.
Leftover cured epoxy peels-off easily. I like to mix epoxy with a dowel. Rotating and rolling the dowel while mixing helps to mix more completely. A round wooden toothpick and the small plastic lid are great for mixing small batches.
Plastic covers are good idea Roddie. Thanks for this tip.
I use bamboo skewers for mixing.
Levent,
The stuff you linked is 3/4" ID, and about 1-1/2" OD. The stuff in your fingers looks to be about 1" OD, and 3/8" ID...unless you are holding it with a Thoe!
OhBee- Platinum Member
944_Jim wrote:Levent,
You are right It is 5/8 x 5/16 ins. However I couldn't find it in any website.
Perhaps you want to try nearest size:
https://www.amazon.com/URBEST-Insulation-Tubing-Preservation-Insulated/dp/B01MDNCVMB
» devarnishing brushes
» Good air brush set at Harbor Frieght for $80
» Sig R/C Fly-In...June 12-14...Montezuma, Iowa The Wrap-Up...
» 30, 15, 5 Epoxy
» What to use to clean paint brush after using BALSARITE ?
» 30, 15, 5 Epoxy
