Good air brush set at Harbor Frieght for $80 Cox_ba12
Good air brush set at Harbor Frieght for $80 Pixel
by getback Yesterday at 11:52 am
by GallopingGhostler Fri Nov 22, 2024 3:04 pm
Good air brush set at Harbor Frieght for $80 Empty
Good air brush set at Harbor Frieght for $80 Empty Good air brush set at Harbor Frieght for $80
Post  SuperDave Wed Nov 16, 2011 7:29 pm
Part # 95630 complete with 1/5 hp compressor, air brush, hose, mixing cup etc.
Check the HF web-site for more information. An EXCELLENT value IMO!
SuperDave
SuperDave
Good air brush set at Harbor Frieght for $80 Empty Re: Good air brush set at Harbor Frieght for $80
Post  Cribbs74 Wed Nov 16, 2011 10:04 pm
Did you grab it? Harbor frieght isn't always known for the best quality. Sometimes they do have good quality items though. I bought a small wire feed mig welder from there a few years back and I have used it exhaustively and it still works wonderfully.
I will check it out thanks SD!
Post  andrew Wed Nov 16, 2011 11:32 pm
SuperDave ---
There are a few things you need to consider when looking at compressors and airbrushes. This particular compressor must run continuously to provide air -- with a direct connection to the airbrush, both piston and diaphram compressors will supply pulsating air pressure. This can be overcome by pumping into a secondary tank, say 3 to 5 gallon capacity. The tank acts as a buffer and outlet air will have less of a pressure variation.
It really helps to have a means of regulating air pressure -- I did not notice a pressure regulator on this setup. You can get small in-line pressure regulators that may be mounted close to the airbrush. Lastly, you need a good water trap that mounts as close to the sprayer or airbrush as possible. Unless you're spraying water soluable paint, any moisture in your paint will either leave spots or cause dope to blush.
For small models, airbrushes work well. At the size of the spray area increases, it can take long time to cover. Some of the small capacity touchup guns may work better in these applications.
